Heated floors
09-14-2008, 08:13
Heated floors
If you are contemplating heated floors in your coach:
Ernie Ekberg 83PT40 Livingston, Montana Psssst...Have you heard the news? There's a new fashion blog, plus the latest fall trends and hair styles at StyleList.com. |
I subscribe to National Flooring Trends magazine. These companies advertise there. www.ntlfloortrends.com
Check them out and see if they come close to what you are looking for.
Ernie- Psssst...Have you heard the news? There's a new fashion blog, plus the latest fall trends and hair styles at StyleList.com. |
09-14-2008, 09:43
Heated floors
probably the warm floors products.
09-14-2008, 13:42
Heated floors
Ernie,
Your the pro here. Which system do like best, I see that Warm Floors has a dedicated RV product. If it was your coach what would you put in it. Kurt Horvath 95 PT-4210AC --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > > If you are contemplating heated floors in your coach: > > check out these sites: _www.thermosoft.com_ (http://www.thermosoft.com/) > _www.quietwalk.com_ (http://www.quietwalk.com/) _www.warmfloor.com_ > (http://www.warmfloor.com/) > I subscribe to National Flooring Trends magazine. These companies advertise > there. _www.ntlfloortrends.com_ (http://www.ntlfloortrends.com/) > Check them out and see if they come close to what you are looking for. > Ernie- > > > > > > Ernie Ekberg > 83PT40 > Livingston, Montana > > > > **************Psssst...Have you heard the news? There's a new fashion blog, > plus the latest fall trends and hair styles at StyleList.com. > (http://www.stylelist.com/trends?ncid=aol...0000000014) > > Bob- check out these sites: _www.thermosoft.com_ > (http://www.thermosoft.com) _www.quietwalk.com_ (http://www.quietwalk.com) _www.warmfloor.com_ > (http://www.warmfloor.com) > I subscribe to National Flooring Trends magazine. These companies advertise > there. _www.ntlfloortrends.com_ (http://www.ntlfloortrends.com) > Check them out and see if they come close to what you are looking for. > Ernie- > > > > **************Psssst...Have you heard the news? There's a new fashion blog, > plus the latest fall trends and hair styles at StyleList.com. > (http://www.stylelist.com/trends?ncid=aol...0000000014) > |
09-14-2008, 20:30
Heated floors
Kurt (and others)
I recently installed the "Warm Tiles" with the FTS-1 Time of Day thermostat. They are wired through my inverter and use only about 12 amps DC when they energize (about as much as a 120 watt bulb). Of course when I'm parked at a campground or at home, they run off the shorepower. It is amazing how warm the floor will get- I usually have the thermostat set for 85 degrees from 5AM to 10AM and then scale it back to 70 during the day. It will ramp back up to 85 from 8 to 10 PM and then power back overnight. 85 is a little warm for some, but I like a nice toasty floor in the morning. You have to remove the existing tile or laminate floor and get back down to the plywood subfloor. Then you attach the heat tape in a serpentine grid fashion, encapsulate it in a concrete/thinset base and once that dries- you're ready to lay tile. It will add about 1/4 to 3/8 inch to the existing floor- much the same as a carpet pad. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath" > > Ernie, > > Your the pro here. Which system do like best, I see that Warm Floors > has a dedicated RV product. If it was your coach what would you put > in it. > > Kurt Horvath > 95 PT-4210AC > > > > --- In WanderlodgeForum@yahoogroups.com, erniecarpet@ wrote: > > > > > > If you are contemplating heated floors in your coach: > > > > check out these sites: _www.thermosoft.com_ > (http://www.thermosoft.com/) > > _www.quietwalk.com_ (http://www.quietwalk.com/) > _www.warmfloor.com_ > > (http://www.warmfloor.com/) > > I subscribe to National Flooring Trends magazine. These companies > advertise > > there. _www.ntlfloortrends.com_ (http://www.ntlfloortrends.com/) > > Check them out and see if they come close to what you are looking > for. > > Ernie- > > > > > > > > > > > > Ernie Ekberg > > 83PT40 > > Livingston, Montana > > > > > > > > **************Psssst...Have you heard the news? There's a new > fashion blog, > > plus the latest fall trends and hair styles at StyleList.com. > > (http://www.stylelist.com/trends?ncid=aol...0000000014) > > > > Bob- check out these sites: _www.thermosoft.com_ > > (http://www.thermosoft.com) _www.quietwalk.com_ > (http://www.quietwalk.com) _www.warmfloor.com_ > > (http://www.warmfloor.com) > > I subscribe to National Flooring Trends magazine. These companies > advertise > > there. _www.ntlfloortrends.com_ (http://www.ntlfloortrends.com) > > Check them out and see if they come close to what you are looking > for. > > Ernie- > > > > > > > > **************Psssst...Have you heard the news? There's a new > fashion blog, > > plus the latest fall trends and hair styles at StyleList.com. > > (http://www.stylelist.com/trends?ncid=aol...0000000014) > > > |
09-15-2008, 14:17
Heated floors
Ernie,
Checked with Thermosoft and warmfloor...thermosoft needs a GFI circuit, which I don't have and warmfloor is waterfilled (which doesn't work for me either). Will probably have to forgo the heated floors and just have you put in wood floors....bummer... Bob Lawrence 84 PT 36 Workcamping in Branson, Mo. > If you are contemplating heated floors in your coach: > > check out these sites: _www.thermosoft.com_ (http://www.thermosoft.com/) > _www.quietwalk.com_ (http://www.quietwalk.com/) _www.warmfloor.com_ > (http://www.warmfloor.com/) > I subscribe to National Flooring Trends magazine. These companies advertise > there. _www.ntlfloortrends.com_ (http://www.ntlfloortrends.com/) > Check them out and see if they come close to what you are looking for. > Ernie- > > > > > > Ernie Ekberg > 83PT40 > Livingston, Montana > > > > **************Psssst...Have you heard the news? There's a new fashion blog, > plus the latest fall trends and hair styles at StyleList.com. > (http://www.stylelist.com/trends?ncid=aol...0000000014) > > Bob- check out these sites: _www.thermosoft.com_ > (http://www.thermosoft.com) _www.quietwalk.com_ (http://www.quietwalk.com) _www.warmfloor.com_ > (http://www.warmfloor.com) > I subscribe to National Flooring Trends magazine. These companies advertise > there. _www.ntlfloortrends.com_ (http://www.ntlfloortrends.com) > Check them out and see if they come close to what you are looking for. > Ernie- > > > > **************Psssst...Have you heard the news? There's a new fashion blog, > plus the latest fall trends and hair styles at StyleList.com. > (http://www.stylelist.com/trends?ncid=aol...0000000014) > |
09-15-2008, 14:28
Heated floors
Forget I said Warmfloor is waterfilled. After getting further into
the site, found the rv portion. Will have to look at it further. Bob > Ernie, > Checked with Thermosoft and warmfloor...thermosoft needs a GFI > circuit, which I don't have and warmfloor is waterfilled (which > doesn't work for me either). > Will probably have to forgo the heated floors and just have you put > in wood floors....bummer... > Bob Lawrence > 84 PT 36 > Workcamping in Branson, Mo. > > > If you are contemplating heated floors in your coach: > > > > check out these sites: _www.thermosoft.com_ > (http://www.thermosoft.com/) > > _www.quietwalk.com_ (http://www.quietwalk.com/) > _www.warmfloor.com_ > > (http://www.warmfloor.com/) > > I subscribe to National Flooring Trends magazine. These companies > advertise > > there. _www.ntlfloortrends.com_ (http://www.ntlfloortrends.com/) > > Check them out and see if they come close to what you are looking > for. > > Ernie- > > > > > > > > > > > > Ernie Ekberg > > 83PT40 > > Livingston, Montana > > > > > > > > **************Psssst...Have you heard the news? There's a new > fashion blog, > > plus the latest fall trends and hair styles at StyleList.com. > > (http://www.stylelist.com/trends?ncid=aol...0000000014) > > > > Bob- check out these sites: _www.thermosoft.com_ > > (http://www.thermosoft.com) _www.quietwalk.com_ > (http://www.quietwalk.com) _www.warmfloor.com_ > > (http://www.warmfloor.com) > > I subscribe to National Flooring Trends magazine. These companies > advertise > > there. _www.ntlfloortrends.com_ (http://www.ntlfloortrends.com) > > Check them out and see if they come close to what you are looking > for. > > Ernie- > > > > > > > > **************Psssst...Have you heard the news? There's a new > fashion blog, > > plus the latest fall trends and hair styles at StyleList.com. > > (http://www.stylelist.com/trends?ncid=aol...0000000014) > > > |
09-15-2008, 20:21
Heated floors
Ralph mentioned an outlet in the refer compartment that may be GFI. Don't despair, we'll figure it out.
09-16-2008, 04:01
Heated floors
The "warm tiles" system has a thermostat with a built-in GFCI. All you
need to supply is a clean 110V AC source w/ground. I pulled power from the outlet for the TV in my bedroom closet and located the GFCI thermostat in the old 12V outlet opening in the bathroom. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Ralph mentioned an outlet in the refer compartment that may be GFI. Don't > despair, we'll figure it out. > > Ernie Ekberg > 83PT40 > Livingston, Montana > > > > > **************Psssst...Have you heard the news? There's a new fashion blog, > plus the latest fall trends and hair styles at StyleList.com. > (http://www.stylelist.com/trends?ncid=aol...0000000014) > |
