FYI
09-17-2008, 16:22
FYI
I have an 82 fc 35 with 3208 cat. After my last trip, it was running
real rough at idle then quit and it wouldn't start again. I noticed
the Racor guage was near the red (low fuel flow). So I replace all
fuel filters including the Racor, filled the racor bowl with fuel and
bled the injectors. It started and ran ok for a few minutes then
started the same thing. The racor filter bowl was dry. Then I
remembered about an electric lift fuel pump mounted near the fuel tank
in the rear. I checked for voltage with ignition on and there was 12
volts. I replaced the pump. Not an easy job lying under the coach
with very little room to move. As soon as turned on the ignition it
started pumping, filled the filter, I bled the injectors and all is
well.
Jim Marsh
82fc 35
Serendipity
01-21-2010, 06:05
FYI
Neighbor just called...he saw an older yellow/beige 'Bird with bright green foreign toad heading out of town on the 91 fwy in Anaheim, CA...got to be Lucas & Linda.
Curt Sprenger
Anaheim Hills, CA
01-21-2010, 06:11
FYI
Good to know Curt. Now we just have to get him in here and parked safe
2010/1/21 Curt Sprenger <"curtsprenger@gmail.com">
Curt Sprenger
Anaheim Hills, CA
Rob, Sue and Joey Robinson
94 WLWB
01-21-2010, 09:28
FYI
Hi Curt
Should be leaving for Q Friday morning . Save me a spot . Great to be back on
the west coast the weather is still better .
mario 1985fc35 carlsbad ca.
> Lucas & Linda.
> Curt Sprenger
> Anaheim Hills, CA
01-21-2010, 09:43
FYI
Mario
Awaiting your arrival here@ tha Q pond!!
This moisture is very welcome to us desert folks, but disappointing to the majority.
Hope you have a safe trip.
Fred & Jeanne Hulse
Morristown,Arizona
1997 Wanderlodge WB41
01-21-2010, 09:54
FYI
Mario- bring some sunshine
Ernie- me and the girls are watching the river in front of the bus at Q
83PT40
Wanderlodge
Weatherford, Tx 817-475-3991
--- On Thu, 1/21/10, mariopatti1 wrote:
Subject: [WanderlodgeForum] Re: FYI
Date: Thursday, January 21, 2010, 3:28 PM
Hi Curt
Should be leaving for Q Friday morning . Save me a spot . Great to be back on the west coast the weather is still better .
> Lucas & Linda.
> Curt Sprenger
> Anaheim Hills, CA
01-21-2010, 15:34
FYI
Don'[t know if we can bring any sunshine but we might bring some snow.
Jim and Linda Marsh 97 wlwb 41.
> Ernie Ekberg
> 83PT40
> Wanderlodge
> http://www.ernieekbergflooring.net
> From: mariopatti1
> Â
> Hi Curt
> > Lucas & Linda.
> > Curt Sprenger
> > Anaheim Hills, CA
Loading...
