Trailer Lighting
09-21-2008, 03:28
Trailer Lighting
I am currently having a trailer built to haul my 1 ton van. I bought all the wiring and new plugs. Fortunately, my coach is wired correctly. Whew!
83PT40
Livingston, Montana
getting ready to come back to Texas
Looking for simple solutions to your real-life financial challenges? Check out WalletPop for the latest news and information, tips and calculators.
09-21-2008, 03:41
Trailer Lighting
Last night, I plugged a borrowed trailer into my bus. The tail and
turn lights worked fine, but whenever I would step on the brake, the
circuit breaker for the brake lights circuit would trip after a second
or so. I also had a reading of +50 amps on the ammeter, which went
away the moment I unplugged the trailer.
The trailer has LED lights and did not cause any trouble behind my
truck. It does not have trailer brakes.
I suspect I have a problem in my trailer socket. Anyone have a
suggestion of where to start looking?
Scott Forman
86 PT38
Memphis
09-21-2008, 04:02
Trailer Lighting
Scott,
I would take a good close look at which wires are going into the
connector plugs (male and female) to see that you are making the
correct feeds on everything. You may be running a hot power supply
from the bus to the ground (frame) of the trailer, causing the high
drain.
Gary
SOB
--- In WanderlodgeForum@yahoogroups.com, "Scott Forman"
second
> Scott Forman
> 86 PT38
> Memphis
09-21-2008, 04:31
Trailer Lighting
Scott,
This is one of BB notorious screw ups. For several years the
blueprints showed an incorrect sequence in wirering the trailer plug.
Basically it is wired backwards. Called my BB Guru and he told me
that happened on and off for several years. The first time I plugged
in my car trailer the brakes lock with the headlights on the running
lights activated with the brakes and the tail lights were hooked up
as the running lights. I had to remove the plug and rewire all the
connections the were the mirror image to their correct position. Just
follow the standard wirering pattern and you should be OK.
Kurt Horvath
95 PT-42
10AC
# Circuit Function
1 White Common ground
2 Blue Electric brake
3 Green Tail / Running lights
41 Black Battery charge (+) or 'hot'
5 Red Left turn / Stop
6 Brown Right turn / Stop
72 Yellow Auxiliary / Backup
Detailed info
http://www.bargman.com/Wire/PDF/Ceq-Wiri...-2006f.pdf (
Page 32 )
http://www.sunriserv.ca/pages/downloads/...argman.pdf
second
> Scott Forman
> 86 PT38
> Memphis
09-21-2008, 06:39
Trailer Lighting
Like Kurt said. but if the wires match,
sounds like the bus brake is either seperate wire like the european
setup or an E brake. when you hit the bus brakes it is picking up a
electric brake addon actuator signal and sending it to the trailer. at
the trailer the e brakes are shorted out or the wire it connected to at
the trialer plug is the trailer ground. if the trailer ground is the
wire crossed, the ground you now have is that which is made via the ball
and chains. I would unhook the ball and chain and see if the proven
functions still work.
you dont need a brake wire on federal apps unless you have e brakes on
the trailer.
stop and brake are different lables. stop is the light and brake is the
e brake shoes. but some times if the diagram has not both, stop or brake
is the light!!!!!
You can test the trailer for a short by using a multimeter prior to
plugging it into the bus. use ohms or continuity function. ground one
lead to the trailer frame and poke at the plug to find the one pin that
sounds the buzzer or shows no resistance. that is ground. if you find
another pin without resistance, one of the two pins is not intended to
be continious to ground and is mostlikely the fault.
09-21-2008, 07:09
Trailer Lighting
Kurt hit it on the nose. I had to rewire both my 83 and 91 to
standard wiring configs. If you haven't rewired your plug yet, the
drawings are in RV Trailer Plug Wiring Diagrams in the Files since
this is such a common problem on the early BB's.
1991 WB40 "Texas Minivan"
--- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath"
> Scott,
> Kurt Horvath
> 95 PT-42
> 10AC
> # Circuit Function
> Detailed info
> Page 32 )
> the
> second
> > Scott Forman
> > 86 PT38
> > Memphis
09-26-2008, 06:28
Trailer Lighting
We're discussing driving down the Blue Ridge Parkway with our coach.
It appears that the North Carolina section is "out" due to low
tunnels (some with clearance of only 11'1"). However, the road was
built in 1935, so I wonder just how wide and comfortable we'd be in
our PT-42 ... or would we be better off parking the bus and driving
our toad along the parkway?
aeonix1@...
On the road near Scranton, PA
09-26-2008, 06:55
Trailer Lighting
Pete,
Drive the toad. Smokey Mtn. Nat. Park is also very tight. Should be
nice this time of year. Do you want a CD? I have one with your name on
it. I have one left from the first batch of 25 so if someone wants one
send your address ASAP!!!!! They are going out today by 3:45 Central
time.
Kurt Horvath
95 PT-42 WLWB
10AC
> Pete Masterson
> aeonix1@...
09-26-2008, 07:36
Trailer Lighting
I would not attempt that highway in the coach. I was in the Cherokee Asheville area a couple of weeks ago to scope out where to take the bus for a weekend. It ain't easy to get there from here. Even here in the NE GA mountains there are beautiful State and Corp of Engineers parks some of which have a few spots to fit the bus. The roads are adequate but many have long steep hairpin pulls with virtually no shoulders or no guard rails and steep down slopes which if you went down one it would ruin the whole day. It would also take awhile for someone to find you. I do drive them but rarely exceed 40 mph and not at night.. You do not want to take 441 from Cherokee to Gatlinburg in the coach either. It is a beautiful area and worth the trip.
A word of caution. If you follow the GPS in these parts it can put you on a dirt road or a thin secondary road in the forest
with no place to turn around. The old map way is helpful 'round here.
Leroy Eckert
1990 WB-40 Smoke N Mirrors
Dahlonega, GA
Royale Conversion
--- On Fri, 9/26/08, Pete Masterson wrote:
Subject: Re: [WanderlodgeForum] Re: Trailer Lighting
Date: Friday, September 26, 2008, 2:28 PM
"aeonix1%40mac.com"
09-26-2008, 08:19
Trailer Lighting
One other thing Pete. In this area there is a fuel shortage. No fuel for a week now with no end in sight apparently. It's supposedly Hurricane related but they will tell you anything to keep the price at $4.25. I have a friend in Charlotte and same thing there.
"aeonix1%40mac.com"
