Road help - sump dump and gen door lock lights on
09-21-2008, 16:59
While negotiating a service station apron to get some $3.63 diesel, we
had a minor "scrapping". No major "thump" just a light "screeeee".
It appears we dragged the lock bar for the generator slide. Fiddled
with the lock lever a bit and then the light came on never to go off
again.
It also appears we're running low in the right rear.
The best inspection we can do with the bus down in the rear doesn't
seem to show anything serious, just a light scratching.
Any thoughts?
Reards,
Hippieforever and GPSGary
09-22-2008, 14:38
Gold star for Ralph F. Private email with good diags on both topics.
The right "butt drag" was a dead load leveler valve. Interestingly
enough it probably was failing for a while because we had a pull to the
right that has disappeared with the new rear load leveler.
Butler Cat is all over the Wy, MT, ND, SD area. Good service not too
bad on price. 75 gals of diesel for diags and the $70 part.
Let the adventure continue.
H4E & GPSGary
