VMSpc 2.4 New Software
09-27-2008, 19:14
Looks like Silverleaf finally have some nice upgrades. Integrated
Pressure Pro looks like a good idea. I just upgraded to the new version and it's working better than the last version. I like the idea of having everything on one monitor, less clutter on the dash. I pasted this from their web site. VMSpc 2.4b2 is now released for General Availability (GA) What's new in VMSpc 2.4? - Easier gauge creation. - Integrated Parameter Editor - Create gauge parameters automatically in PID sniffer. - PressurePro support. (Requires receiver.) - Message Box feature. Create color-code text messages like "High Coolant Temp". VMSpc 2.4 is ready for GA. This is the biggest upgrade we've had in years. We've made gauge creation and parameter definition easier than ever, and added the "Message Box" feature. The Message Box is something like a text equivalent to the Audible Alarms. You define alarms based on any parameter, and create a Message Box to display those alarms. You can define items like "Check Engine", "Hot Coolant", or "Cruise Set", and they will display as color-coded text items when appropriate. PID Sniffing and Parameter Editing is now much easier. You can run the PID Sniffer and immediately define gauge parameters for almost any new PID you discover your engine supports. The Parameter Editor is not built in - you don't need to run a separate program to set your yellow and red lines, or change units on your gauges. Perhaps the most exciting new feature is the PressurePro support. We now have a receiver package that ties your PressurePro sensors directly to VMSpc. You can use VMSpc in conjunction with or as a replacement for the standard PressurePro monitor. Setup is easy and flexible. What's new in VMSpc 2.4b2? Loose your COM Port?? One-Click Button to start the Device Manager in Win 2000, Win XP and Win Vista. You can download VMSpc 2.4b2 (GA) from the VMSpc Downloads Page. ______________________________________________________________________ _____ Kurt Horvath 95 PT42 10AC |
