Update On Air System Issues
09-28-2008, 09:56
Progress since last post regarding air system issues.
Air pressure was bleeding off at the rate of 60 pounds in 5 minutes (120 to 60). When I bought the coach 3-1/2 years ago it was leaking 60 pounds in 20 minutes. I monitor this by the holding tank dump station pressure gauge. Also, the drive/tag suspension would go down in 24 hours. My son has great hearing. He found a couple more air leaks, namely two of the three Pilot Control Valves on the drive and tag axles. The curb side drive and the tag were leaking. All three valves were replaced. Several more leaks were found and resolved by tightening up line fittings. The leaking was now 40 pounds in 17 minutes, much better, but not to the point I was happy. And the drive/tag would still go down in 24 hours. Next was to determine which part of the system is leaking. Blocking off the dump valves and airing up the suspension, the suspension would still go down in 24 hours. So it's either the air springs or the hard lines. The air springs were new three years ago. Decided to replace the hard lines to the bags with plastic lines. The result is the suspension stands for days, and the air leak(s) is now at 50 pounds in 5 hours. I'll stop working this project for now. May need to revisit over time as I'm sure more hard lines will rub together creating more leaks. A pit sure would be nice.. .I would change out the hard lines for the plastic. |
09-28-2008, 10:45
Curt: I found a leak on the Pressure Protection Valve
http://www.ryderfleetproducts.com/cgi- bin/ryderfp/products/srm/oid/48389/erm/product_detail.jsp on top of my wet tank...Bill Pape told me to check the 4 cap screws on the valve and shure enough after tightening the 4 bolts the leakdown rate is greatly reduced. My air throttle still works immediately after 24 hrs but chasing leaks is still an ongoing ordeal. Dick Gideon 1989 35FC Rolla, MO --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > Progress since last post regarding air system issues. > > Air pressure was bleeding off at the rate of 60 pounds in 5 minutes > (120 to 60). When I bought the coach 3-1/2 years ago it was leaking 60 > pounds in 20 minutes. I monitor this by the holding tank dump station > pressure gauge. Also, the drive/tag suspension would go down in 24 > hours. My son has great hearing. He found a couple more air leaks, > namely two of the three Pilot Control Valves on the drive and tag > axles. The curb side drive and the tag were leaking. All three valves > were replaced. Several more leaks were found and resolved by > tightening up line fittings. The leaking was now 40 pounds in 17 > minutes, much better, but not to the point I was happy. And the > drive/tag would still go down in 24 hours. > > Next was to determine which part of the system is leaking. Blocking > off the dump valves and airing up the suspension, the suspension would > still go down in 24 hours. So it's either the air springs or the hard > lines. The air springs were new three years ago. Decided to replace > the hard lines to the bags with plastic lines. The result is the > suspension stands for days, and the air leak(s) is now at 50 pounds in > 5 hours. > > I'll stop working this project for now. May need to revisit over time > as I'm sure more hard lines will rub together creating more leaks. A > pit sure would be nice.. .I would change out the hard lines for the > plastic. > |
09-28-2008, 15:14
Dick,
Thanks. On the PT's (ours anyway) there are a couple PPVs and the one mounted between two manifolds was replaced along with the one for the tag axle. But, in the end, that was not the only air issue. With out writing a book, it's sometimes difficult to explain what was done to resolve these air issues. I hope my previous post helps to clarify. Our coach also has an air leak at the air throttle. It goes away and the cruise control does the same after the air system is up to about 50% and then the air leak remains at a soapy bubble or two every 15 seconds. I'm happy with that for now. Dont' want to push my luck here as these old systems continue working. On Sun, Sep 28, 2008 at 3:45 PM, Richard Gideon <"giderich@fidnet.com"> wrote:
