Fuse location
10-03-2008, 01:57
Fuse location
Can anyone tell me where the fuse for the rear closet lights in a 96 PT
42 is. My prints are at my Brother in laws and I can't get to them right now. Thanks, MIke Mcmahan 96 PT 42 |
10-03-2008, 04:17
Fuse location
Greg, Just got the disc in the mail. I'll go look at it. Mike
McMahan 96 42 Wanderlodge --- In WanderlodgeForum@yahoogroups.com, "Mike McMahan" <mmcmahan@...> wrote: > > Can anyone tell me where the fuse for the rear closet lights in a 96 PT > 42 is. My prints are at my Brother in laws and I can't get to them > right now. Thanks, MIke Mcmahan 96 PT 42 > |
10-03-2008, 05:46
Fuse location
In my haste to get this disk done there is no index on the disk.
The Index of the Diagrams are pasted below. The PDF files are under Adobe Acrobat Document and are designated by SCAN 439 to 527 also a file 16 page Ref. The TIFF files coincide with the PDF #'s This is better than trying to sort through 4.85 lb. Blueprints. The rest of the inf. & files you'll just have to open it and decided if it is of any use. BAD SCANS are incomplete scans that are viewable, an edge or a side wasn't scanned. There will be several duplicates. Some are duplicates some are revisions or updates. _______________________________________________ INDEX OF 1995 -1996 PT 42 & some 1997 PT 43 FILES ________________________________________________ 16 pgs. Ref. - Wire Reference -From - To - Color - # SCAN NUMBERS 439 to 527 439 Diagram Asst., Plumbing, Fresh Water, bad scan 440 1729813EEEDiagram, WRG. Chassis, DDEC III, End BRK 4203WL bad scan 441 6083778 Diagram, Wiring, Load Center, Lower Front 442 6083729 Diagram Wiring, Charging Circuit 444 6080956 Diagram, Installation, Aquahot 445 6083729 Diagram, Wiring, Charging Circuit 446 6088652 bad scan 447 1782267A 2 of 2 bad scan 449 1782259 1 of 2 Diagram, Dual, Air Brake, 448 Bad Scan 450 Bad Scan 451 Bad Scan 452 Bad Scan 455 1729813EEE Diagram, WAG, Chassis, DDEC III, Eng. Brake. BS 456 Bad Scan 457 Diagram Fresh Water System Legend not scanned 458 6083711 Diagram Electrical System bad scan 459 6051999 Diagram Assy, Electrical Component Panel, Rear, 12V 460 6080956 Diagram, Installation, Aquahot 461 6080956 Same As Above 462 6053227 Diagram Assy, Electrical Component Panel, Overhead Front 463 6068670 Diagram, L.P. Gas Piping, State 464 6053227 Diagram Assy, Electrical Component Panel, Overhead Front 465 6046422 Diagram Wiring, Charging Circuit 466 6068670 Diagram, L.P. Gas Piping, State 467 6046445 Diagram, Electrical Systems top edge bad scan 468 6083729 Diagram Charging Circuit, Bad Scan 469 6049100 1 of 11Diagram Harness, Wiring, 12VDC. RH 470 2 of 11 471 3 of 11 472 4 of 11 473 5 of 11 474 6 of 11 475 7 of 11 476 8 of 11 477 9 of 11 478 10 of 11 479 11 of 11 480 Copy 5 of 11 481 Copy 5 of 11 482 6049076 2 of 3 Harness, Wiring 120VAC, LH 483 3 of 3 484 1 of 3 485 2 of 3 486 3 of 3 487 3 of 3 488 6049092 1 of 14 Harness, Wiring, 12VDC, LH 489 2 of 14 490 3 of 14 491 4 of 14 492 5 of 14 493 6 of 14 494 7 of 14 495 8 of 14 496 9 of 14 497 10 of 14 498 11 of 14 499 6049100 7 of 11 Harness, Wiring, 12VDC, RH 500 " " 6 of 11 501 1729813 Diagram, Wiring, Chassis, DDEC III, Engine Brake 502 1729813 Diagram, Wiring, Chassis, DDEC III, Engine Brake 503 6051981 Diagram, Assy, Electrical Component Panel, Overhead Front 504 1729813 Diagram, Wiring, Chassis, DDEC III, Engine Brake 505 6083778 Diagram, Wiring, Load Center, Lower Front - Superseded by # 6087878 506 Same As Above 507 6083075 Diagram, Assy, Plumbing, Fresh Water 508 6080956 Diagram, Installation, Aquahot 509 6083729 Diagram, Wiring, Charging Circuit 510 1782259 Diagram, Dual Air Brake, Sheet 1 of 2 511 6083711 Diagram, Electrical Systems 512 6053227 Diagram, Assy, Electrical, Overhead Front 513 6083711 Diagram, Electrical Systems 514 1782259 Diagram, Dual Air Brake, Sheet 1 of 2 515 6053227 Diagram, Assy, Electrical Component Panel, Overhead Front 516 1782267 Diagram, Dual Air Brake, Sheet 2 of 2 517 6068670 Diagram, L.P. Gas Piping, State 518 Unknown Diagram, Electrical Systems 120/220????? 519 6083729 Diagram, Wiring, Charging Circuit 520 6053227 Diagram, Assy, Electrical Component Panel, Overhead Front 521 6046122 Diagram, Wiring, Charging Circuit 522 6083075 Diagram, Assy, Plumbing, Fresh Water 523 6051999 Diagram Assy, Electrical Component Panel, Rear, 12VDC 524 6080956 Diagram Installation, Aquahot 525 6080956 Duplicate Print 526 6068670 Diagram, L.P. Gas Piping, State 527 6053227 Diagram Assy, Electrical Component Panel, Overhead Front TIFF FILES ARE NUMBERED THE SAME AS THE PDF FILES. Kurt Horvath 95 PT 42 WLWB 10AC --- In WanderlodgeForum@yahoogroups.com, "Mike McMahan" <mmcmahan@...> wrote: > > Greg, Just got the disc in the mail. I'll go look at it. Mike > McMahan 96 42 Wanderlodge > > --- In WanderlodgeForum@yahoogroups.com, "Mike McMahan" <mmcmahan@> > wrote: > > > > Can anyone tell me where the fuse for the rear closet lights in a 96 > PT > > 42 is. My prints are at my Brother in laws and I can't get to them > > right now. Thanks, MIke Mcmahan 96 PT 42 > > > |
10-03-2008, 06:11
Fuse location
01-11-2009, 10:03
Fuse location
Does anyone know where the fuse is for the camera monitor on 2005 LXI?
Jerry Smith 2005 450 LXI |
01-11-2009, 11:21
Fuse location
--- In WanderlodgeForum@yahoogroups.com, "medpro28" <medpros@...> wrote:
> > Does anyone know where the fuse is for the camera monitor on 2005 LXI? > > Jerry Smith > 2005 450 LXI > Jerry, remove the panel behind the driver seat, between seat and slide. Ken Rife 2006 450 LXI |
01-12-2009, 04:07
Fuse location
Thanks, Ken.
On Sun, Jan 11, 2009 at 6:21 PM, Ken Rife <"kenrife48@aol.com"> wrote:
