HELP - stuck in State Park w/ gen tray out
10-05-2008, 05:32
We finally got the generator working yesterday.
Started and stopped like a champ. Slid in and out multiple times. This morning I can't get it back in. Generator door light used to be on. Now it's off. Gen door micro switch is broken. Physically, button came off and center spring came out. But yesterday the gen light was still on even with the switch broken. Tried jumpering the switch --- NG. The gen tray switch doesn't produce any activity at the air piston. Step works fine so we have pressure. Jiggled the tray. Generator starts and stops via switches. How can I get the tray in? Regards, GPSGary |
10-05-2008, 05:55
Dumb question...your air is up, right?
Scott Forman 86 PT38 Memphis --- In WanderlodgeForum@yahoogroups.com, "hippieforever3" wrote: > > We finally got the generator working yesterday. > > Started and stopped like a champ. Slid in and out multiple times. > > This morning I can't get it back in. > > Generator door light used to be on. Now it's off. Gen door micro switch > is broken. Physically, button came off and center spring came out. But > yesterday the gen light was still on even with the switch broken. Tried > jumpering the switch --- NG. > > The gen tray switch doesn't produce any activity at the air piston. > Step works fine so we have pressure. Jiggled the tray. Generator starts > and stops via switches. > > How can I get the tray in? > > Regards, > GPSGary > |
10-05-2008, 06:36
Yes. Step goes in and out. Suspension is completely up.
Regards, GPSGary --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <scottforman75@...> wrote: > > Dumb question...your air is up, right? > > Scott Forman > 86 PT38 > Memphis > > --- In WanderlodgeForum@yahoogroups.com, "hippieforever3" > wrote: > > > > We finally got the generator working yesterday. > > > > Started and stopped like a champ. Slid in and out multiple times. > > > > This morning I can't get it back in. > > > > Generator door light used to be on. Now it's off. Gen door micro > switch > > is broken. Physically, button came off and center spring came out. > But > > yesterday the gen light was still on even with the switch broken. > Tried > > jumpering the switch --- NG. > > > > The gen tray switch doesn't produce any activity at the air piston. > > Step works fine so we have pressure. Jiggled the tray. Generator > starts > > and stops via switches. > > > > How can I get the tray in? > > > > Regards, > > GPSGary > > > |
10-05-2008, 06:36
