Engine Room Temperature
10-05-2008, 07:59
My next project is to correctly wire the 7 flat pin trailer receptacle. I'd like to install circuit breakers and relays in the engine room. I have on hand circuit breakers rated up to 150 (F). They will be installed on a panel, and the panel will be located just reward of the junction box that contains the battery heater wiring. In using these CBs, am I heading for trouble due to the heat in the engine room?
Curt Sprenger
Anaheim Hills, CA
10-05-2008, 14:16
The 94 engine compartment is loaded up with about 10 cb's the
problem I found was water passing the hermetic seal on the cb. I can
see where heat will be an issue because there is a thin piece of
metal that holds the contact point against a lug in the cb. I
believe it is heat that causes the metal to distort and move away
from the lug.
I wonder if fuses are not a better protection. with a fuse, a ground
short will pop it and you will have proof when you do the 10 second
pretrip taillight test. it could be that a cb opens up 30 seconds
after you set out on the road and resets itsself for your next
pretrip check.
gotta be a reason they (auto engineeres) use some cb's and some
fuses???
I like the way you isolated my trailer light power from throwing my
bus tail light power.
Greg94ptCa
--- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger"
receptacle. I'd
have on
on a
box that
heading for
> Curt Sprenger
> Anaheim Hills, CA
10-05-2008, 15:19
Greg, Thanks. Good thought using fuses instead of CBs. I'll add your suggestion to my project consideration list. I need to get this project done before the SWBB Flying Flags rally at the end of October. I plan to take the trailer/bike up there and do a little touring.
from the lug.
pretrip check.
fuses???
Greg94ptCa
--- In "WanderlodgeForum%40yahoogroups.com", "Curt Sprenger"
receptacle. I'd
have on
on a
box that
heading for
> Curt Sprenger
> Anaheim Hills, CA
Curt Sprenger
Anaheim Hills, CA
10-05-2008, 15:41
Curt,
Have you considered putting the cb's in the charger/shunt bay just ahead of the curb side e.r. louvers? Might get a little warm there being just above the tail pipe, but there is plenty of room on the rear wall of that compartment. I don't think that it is any warmer than above the batteries. Either would be fine I suppose but I wouldn't want to make servicing the batteries a problem.
Sent: Sunday, October 05, 2008 8:19 PM
Subject: Re: [WanderlodgeForum] Re: Engine Room Temperature
from the lug.
pretrip check.
fuses???
Greg94ptCa
receptacle. I'd
have on
on a
box that
heading for
> Curt Sprenger
> Anaheim Hills, CA
Curt Sprenger
Anaheim Hills, CA
10-05-2008, 18:15
Hi Curt,
I placed a small breaker panel in the charging compartment behind
the tag axle, just forward of the tailpipe. My coach has a removable
louvered door that allows access to the charger/inverter, shunts and
some small fuse holders that were in there. The compartment rarely
sees more than 150 degrees since I put a cooling fan on it & the
breakers have been working fine and stay dry in there.
The temperature probe on my battery bank rarely exceeds 145 degrees,
so you would probably be safe locating them above the batteries too. I
would just make sure that they are in a protective box to keep out
moisture.
Shane Fedeli
85PT40
Hershey PA
--- In WanderlodgeForum@yahoogroups.com, "Joyce and Richard Hayden"
> Curt,
> From: Curt Sprenger
> To:
can
> from the lug.
ground
> pretrip check.
> fuses???
> Greg94ptCa
> --- In
"Curt Sprenger"
> receptacle. I'd
> have on
> on a
> box that
> heading for
> > Curt Sprenger
> > Anaheim Hills, CA
> Curt Sprenger
> Anaheim Hills, CA
10-06-2008, 00:29
Dick, Shane,
Thanks. I've thought about the charger compartment. It's a bit tight to work in there as I've already used some of the rear wall. Another option is a hinged plate mounted just inside the door, hinged at the bottom, letting it hinge down/out to get at the added CBs/relays when necessary or to get at all the other components.
On Sun, Oct 5, 2008 at 11:15 PM, sfedeli3 <"sfedeli3@comcast.net"> wrote:
Hi Curt,
moisture.
Shane Fedeli
85PT40
Hershey PA
--- In "WanderlodgeForum%40yahoogroups.com", "Joyce and Richard Hayden"
> Curt,
> From: Curt Sprenger
> To:
can
> from the lug.
ground
> pretrip check.
> fuses???
> Greg94ptCa
> --- In
"Curt Sprenger"
> receptacle. I'd
> have on
> on a
> box that
> heading for
> > Curt Sprenger
> > Anaheim Hills, CA
> Curt Sprenger
> Anaheim Hills, CA
Curt Sprenger
Anaheim Hills, CA
