ZF ECU on Ebay
10-09-2008, 10:18
ZF ECU on Ebay
If I had a zf transmission found in the 300hp Cat 3208 I would pick this up
ZF on Ebay
Greg94Ca
10-11-2008, 04:01
ZF ECU on Ebay
This is not the ZF electronic control module.
It is a box with 7 or 8 relays, that manages power to the ZF
circuits, cruise, indicator lights, high idle etc.
Bill 88 FC Michigan
this
> up
> ZF on Ebay
> <http://cgi.ebay.com/ebaymotors/ZF-5HP-50...ion-Relay-
Module-Bl\
> ueBird-Wanderlo_W0QQitemZ200261696115QQcmdZViewItem?
hash=item20026169611\
> 5&_trkparms=72%3A727%7C39%3A1%7C66%3A2%7C65%3A12%7C240%
3A1318&_trksid=p3\
> 911.c0.m14> Greg94Ca
10-14-2008, 15:01
ZF ECU on Ebay
Bill,
Then is the bid price worth $89.00? Or can you change out relays as
needed? The auction ends on Wed. eve.
Dan Leftwich
Somers NY
1987 35FCSB 300HP ZF 5SPD Trani
> Bill 88 FC Michigan
pick
> this
> > up
> > ZF on Ebay
> Module-Bl\
> 3A1318&_trksid=p3\
