Allison Transmission OEM Troubleshooting guide for WT trouble codes
10-12-2008, 11:15
This has a guide to clear "do not shift" may not apply to the '90 pt
but may be use full for later models. ? I think WT is ack for "WOrld
Transmission"
http://westernstatestransmissions.com/ht...uble1.html
Greg
10-12-2008, 11:25
below is if/than tree for found codes
http://westernstatestransmissions.com/ht...e2.html#23
OEM TROUBLESHOOTING GUIDE
FOR ALLISON WT TROUBLE CODES
TROUBLESHOOTING WITH DIAGNOSTIC CODES
(Additional troubleshooting information can be found in the appropriate
Allison Troubleshooting Manual.)
CODE LISTINGS AND PROCEDURES
IF CODES READ
RECOMMENDED PROCEDURES
Main
Code
Sub
Code
13
12
1. Check:
a. Battery direct ground and power connections are tight and clean.
b. Vehicle batteries are charged.
c. Vehicle charging system is not over- or under - charging.
d. VIM fuse is good.
e. VIM connections are tight, clean, and undamaged.
f. Vehicle manufacturer supplied wiring is correct.
g. ECU connectors are tight, clean and undamaged.
2. If all points check, call Western States Converters and Transmissions.
ECU Input
Voltage Low
13
13
ECU Input
Voltage Low
(Medium)
13
23
ECU Input Voltage High
14
12, 23
1. Check:
a. Is transmission equipped with oil level sensor?
b. Engine speed sensor, output speed sensor, temperature sensor, and oil level sensor are working correctly.
c. Wiring harness has no opens, shorts to ground, or shorts to battery.
2. If all points check, call Western States Transmissions and Converters.
Oil Level Sensor
21
12, 23
1. Check:
a. TPS connector is properly connected.
b. End of TPS cable is pulled out properly.
c. Engine fuel lever is in idle position.
d. Engine fuel lever provides proper amount of stroke on TPS cable.
e. Wiring harness to TPS has no opens, shorts between wires, or shorts to ground.
2. If able, replace TPS.
3. If all points check, call Western States Converters and Transmissions.
Throttle Position Sensor
22
14, 15, 16
1. Check:
a. Speed sensor connectors are tight, clean and undamaged.
b. Speed sensor mounting bolts are properly torqued (24-29 N.m (18-21 lb ft))
c. Wiring harness to sensors has no opens, shorts between wires, or shorts to ground.
Speed Sensors
23
12, 13, 14, 15
1. Check:
a. ECU connectors are tight, clean, and undamaged.
b. Remote shift selector connector is tight and jumper wire is cut.
c. Wiring harness on remote has no opens, shorts between wires, or shorts to ground.
2. If able, replace shift selector(s).
Shift Selectors
24
12
1. Check:
a. Air temperature is below -32°C (-25°F).
1) If yes, this is a correct response for temperature.
2) If no, check that main transmission connector is tight, clean, and undamaged.
b. ECU connectors are tight, clean, and undamaged.
Sump Oil Temperature Cold
24
23
1. Let vehicle idle with parking brake applied, wheels chocked, and vehicle level. Check:
a. Correct dipstick is installed.
b. Fluid level is correct.
1) If fluid level is incorrect -- correct fluid level.
2) If fluid level is correct -- check for engine system overheating, causing transmission to overheat.
2. Check if ECU and transmission connectors are tight, clean, and undamaged.
Sump Oil Temperature Hot
25
00, 11, 22, 33, 44, 55, 66, 77
1. Check:
a. Speed sensor connector is tight, clean and undamaged.
c. Fluid level is correct.
d. Sensor mounting bolt torque is correct (24-29 N.m (18-21 lb ft)).
e. Wiring harness to sensor has no opens, shorts between wires, or shorts to ground.
Output Speed Sensor and Reading
32
00, 33, 55, 77
2. Check:
a. Main transmission connector is tight, clean, and undamaged.
c. Wiring harness has no opens, shorts between wires, or shorts to ground.
C3 Pressure Switch Open
33
12, 23
1. Check:
Sump Oil Sensor Failure
34
12, 13, 14, 15, 16
1. If able, recalibrate ECU; if not, replace ECU.
2. If unable to replace ECU, call Western States Converters and Transmissions.
EEPROM
35
00, 16
1. Check:
b. VIM connectors are tight, clean, and undamaged.
c. Vehicle manufacturer supplied wiring has correct power and ground connections.
d. Power connections are battery direct.
e. Ground connections are battery direct.
f. Ignition switch connections are correct.
Power Interruption EEPROM Write Interruption
3
00
1. If able, reprogram ECU.
2. If able, replace ECU.
3. If ECU cannot be reprogrammed or replaced, call Western States Converters and Transmissions.
Hardware / Software Not Compatible
41
12, 13, 14, 15, 16, 21, 22, 23, 24, 25, 26
1. Check:
c. Wiring harness is not pulled too tight, and there is no damage, chafing, or screws through harness.
d. Wiring harness has no opens, shorts between wires, or shorts to ground.
2. Change wiring harness (optional).
Open or Short to Ground in Solenoid Circuit
42
1. Check:
e. Unauthorized repairs have not been made.
2. Change harness (optional).
Short to Battery in Solenoid Circuit
43
21, 25, 26
1. Check:
a. Transmission connector is tight, clean, and undamaged.
b. ECU connectors are tight clean, and undamaged.
Solenoid Low Side Circuit, Open Driver, or Wire Shorted to Ground
44
1. Check:
Solenoid Circuit Short to Ground
45
1. Check:
c. Wiring harness has no opens.
Solenoid Circuit Open
51
01, 10, 12, 21, 23, 24, 35, 42, 43, 45, 46, 53, 64, 65
1. Check:
a. Output and turbine speed sensor connectors are tight, clean, and undamaged.
b. Speed sensor wiring harness has no opens, shorts between wires, or shorts to ground.
2. Let vehicle idle with parking brake applied, wheels chocked, and vehicle level. Check:
Offgoing Ratio Test (During Shift)
52
01, 08, 32, 34, 54, 56, 71, 72, 78, 79, 99
1. Check:
b. Speed sensor wiring harness has no opens, shorts between wires or shorts to ground.
c. Main wiring harness to transmission has no shorts between wires, or shorts to ground.
Check:
Offgoing C3 Pressure Switch (During Shift)
53
08, 18, 28, 29, 38, 39, 48, 49, 58, 59, 68, 69, 78, 99
1. Check:
a. Turbine and engine speed sensor connectors are tight, clean, and undamaged.
b. Fluid Level is correct.
Offgoing Speed Test (During Shift)
54
01, 07, 10, 12, 17, 21, 23, 24, 27, 32, 34, 35, 42, 43, 45, 46, 53, 54, 56, 64, 65, 70, 71, 72, 80, 81, 82, 83, 85, 86, 92, 93, 95, 96, 97
1. Check:
a. Turbine and output speed sensor connectors are tight, clean, and undamaged.
3. EEPROM calibration is correct for the transmission.
Oncoming Ratio Test (After Shift)
55
17, 27, 87, 97
2. Check:
3. Check:
c. C3 pressure switch wiring has no opens, shorts between wires, or shorts to ground.
4. If all points check, call Western States Converters and Transmissions.
Oncoming C3 Pressure Switch (After Shift)
56
1. Check:
c. Transmission connector is tight, clean, and undamaged.
d. ECU connectors are tight, clean, and undamaged.
Range Verification Test (Between Shifts)
57
11,22,44,
66,88,99
2. Check:
b. Speed sensor wiring harness has no shorts between wires or shorts to ground.
3. Check:
c. C3 Pressure switch wiring has no opens, shorts between wires, or shorts to ground.
Range Verification Test (C3)
61
00
1. Check:
a. Fluid level is correct.
b. Retarder apply system is not allowing retarder and throttle to be applied at the same time.
c. Fluid cooler is adequately sized for load.
Retarder Over Temperature
62
12, 23
1. Check:
a. Retarder temperature measured with DDR is consistent with code; or determine if code is active using shift selector.
b. Ambient temperature is above 178°C (352°F) or below -45°C (-49°F).
c. Sensor connector it tight, clean, and undamaged.
e. Temperature sensor circuit has no opens, shorts, or shorts to ground.
Retarder Temperature Sensor
63
00, 26, 40
1. Check input wiring, switches, and connectors to determine why input states are different.
Input Function Fault
64
12, 23
1. Use DDR to read retarder counts and identify problem wires. Check wiring for short to battery, ground wire open, or short to ground.
Retarder Modulation Request Device Fault
65
00
1. Check if engine rating or governor speed is too high for transmission.
Engine Rating High (Computer-Controlled Engines Only)
66
00
1. Check:
a. Serial connection to engine computer is tight, clean, and undamaged.
b. SCI wiring harness has no opens, shorts, or shorts to ground.
c. If DDR is not available, also be sure that transmission ECU connections are tight, clean, and undamaged.
Serial Communications Interface Fault
69
12, 13, 14, 15, 16, 21, 22, 23, 24, 25, 26, 32, 33, 34, 35, 36, 41
1. Clear diagnostic code and retry vehicle start.
2. If code recurs, reprogram ECU.
3. If able, replace ECU.
4. If code continues to recur, call Western States Converters and Transmissions.
ECU Malfunction
224 Jason Crt.
Corona, CA 91719
(951) 279-6393
(888) 463-3499
(951) 279-1847 Fax
> Transmission"
> Greg
