Perplies W/D Drain Trap Upgrade
10-12-2008, 14:38
Eric, I named this upgrade after your post last week about adding a small hose that you can add water to the W/D drain trap. I rerouted the water from the air flush system for winterizing into the water pump / tool box bay. I use ¼ poly tubing and quick connect fittings, air line type hardware. A small thumb screw valve to open and close the flow then routed it back into the water tank bay then up into the W/D closet. I then fashioned a elbow and attached the hose to a 90 degree quick connect that is screwed into the new elbows and pipe vent that I worked up. I works great. I've posted some photos Thanks for the idea. Kurt Horvath 95 PT 42 10AC |
