Silverleaf VMSpc Screen Cloning
10-14-2008, 15:36
To maximize the usefulness of the VMSpc Silverleaf I have a 7" inch touch screen monitor mounted on the top center of the dash the laptop is in front of the passenger seat, It is almost perfect, A slight glance and I have more Inf. than I really need. Very COOL! When I first installed it. It mirrored the laptop, but after several days use it stopped doing this and went to expanded screen mode. I liked the fact that the laptop and the 7" were in sync. I ran the VMSpc and Streets and Trips on one screen and have both programs running at the same time. It's set up as follows, click maximized on either program for a full screen view or click minimize on either program and 1/3 of the scene on the left has all the vital engine and speed gauges and the right 2/3 of the screen has the GPS and route tracking. It is set on rotate to coincided with the direction I'm driving, very easy to follow when your driving. Very good set up, and in clone mode the CO-pilot & passengers have the same Inf. As the driver. One draw back is if your CO-pilot has a tendency to help in anything other than directions it's hard to hide how fast your going. As an expanded desktop it isn't good for the passengers to view or help navigate and it will not run Streets and trips independently in the expanded screen mode, if I try to open it independently to each screen it will not function. It won't find the com. port for the GPS puck I have been using it this way for several months now. Today I decided to fix this problem. Well after a search for a solution and finding a lot of B.S. mostly gamer, graphic art, and presentation software and video card stuff that wasn't applicable to my problem or budget, I ran across a three sentence explanation on how to do this. It's simple, and it works perfectly. Here is how to Clone or Mirror the two monitors. Fn + F8 (CRT/LCD) functions On the F8 key, you will notice a blue CRT/LCD marking. By holding down the blue Fn key at the bottom left of the keyboard and pressing F8, you can change to which screen to send the output. Each time you hold Fn and press F8, you cycle through the options in the Output To list. The first cycle on my laptop remains as is. The second cycle moves the desktop to the second monitor and the first monitor goes blank. The third cycling of the CRT/LCD key both monitors function in clone mode the are the mirror image of each other and they are both fully functional. The touch screen works by touching or using the touch pad on the laptop or with a mouse. The laptop is also fully functional. Two other notes on the VMSpc: It would sometime freeze up when I would maximize the Streets and Trips screen then return to the VMSpc program. I would have to restart the VMSpc program. The fix for this is on the VMSpc toolbar. Click on ADVANCED when the window opens click on the box marked AutoRestart then click OK. The program will run flawlessly no matter what you open on top of it. When you go back to it. It will be running. The second and I think very important is that the powers to be at Silverleaf have finally added the 470HP version of the Series 60 engine paramiters to the list of engine types. It will be interesting to see the diffrence in data from the old recommended 500HP setting. You can find the new programe here. http://www.silverleafelectronics.com/?q=node/270 The best things in life are simple! __________________________________________________ Kurt Horvath 95 PT 42 10AC |
10-15-2008, 00:42
Kurt,facilitating passanger involvemt would require moving the
coffee maker to the dash. The one thing I miss with driving the bus is early warning engine noise. I dont miss the noise but fear not hearing trouble. Some time back there was a guy who posted looking for sound tracs of the 8v92 and tranny sounds?????? kinda got me thinking of what the benefits of sounds were. Wonder if you could math out a sound and have the computer compare realtime sound to prove normal and adnormal. this could help with the toad also. things like ;bad tire tread and ;squeeling bearings, ;hissing hoses etc are unique and adnormal. Sound is funny I can hear my cell phone and horns if I wear headphones while on my loader otherwise all I hear is the loader!!! Sound is an interesting early warning paramater. many large gensets have a vibration cadence shutdown system, who whould have considered that? Greg94ptCa --- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath" wrote: > > Silverleaf VMSpc Screen Cloning > > To maximize the usefulness of the VMSpc Silverleaf I have a 7" inch > touch screen monitor mounted on the top center of the dash the laptop > is in front of the passenger seat, It is almost perfect, A slight > glance and I have more Inf. than I really need. Very COOL! When I > first installed it. It mirrored the laptop, but after several days > use it stopped doing this and went to expanded screen mode. > > I liked the fact that the laptop and the 7" were in sync. I ran the > VMSpc and Streets and Trips on one screen and have both programs > running at the same time. It's set up as follows, click maximized on > either program for a full screen view or click minimize on either > program and 1/3 of the scene on the left has all the vital engine and > speed gauges and the right 2/3 of the screen has the GPS and route > tracking. It is set on rotate to coincided with the direction I'm > driving, very easy to follow when your driving. Very good set up, and > in clone mode the CO-pilot & passengers have the same Inf. As the > driver. One draw back is if your CO-pilot has a tendency to help in > anything other than directions it's hard to hide how fast your going. > > As an expanded desktop it isn't good for the passengers to view or > help navigate and it will not run Streets and trips independently in > the expanded screen mode, if I try to open it independently to each > screen it will not function. It won't find the com. port for the GPS > puck > > I have been using it this way for several months now. Today I decided > to fix this problem. > > Well after a search for a solution and finding a lot of B.S. mostly > gamer, graphic art, and presentation software and video card stuff > that wasn't applicable to my problem or budget, I ran across a three > sentence explanation on how to do this. It's simple, and it works > perfectly. > > Here is how to Clone or Mirror the two monitors. > > Fn + F8 (CRT/LCD) functions > > On the F8 key, you will notice a blue CRT/LCD marking. By holding > down the blue Fn key at the bottom left of the keyboard and pressing > F8, you can change to which screen to send the output. Each time you > hold Fn and press F8, you cycle through the options in the Output To > list. > > The first cycle on my laptop remains as is. The second cycle moves > the desktop to the second monitor and the first monitor goes blank. > The third cycling of the CRT/LCD key both monitors function in clone > mode the are the mirror image of each other and they are both fully > functional. The touch screen works by touching or using the touch pad > on the laptop or with a mouse. The laptop is also fully functional. > > Two other notes on the VMSpc: It would sometime freeze up when I > would maximize the Streets and Trips screen then return to the VMSpc > program. I would have to restart the VMSpc program. The fix for this > is on the VMSpc toolbar. > > Click on ADVANCED when the window opens click on the box marked > AutoRestart then click OK. The program will run flawlessly no matter > what you open on top of it. When you go back to it. It will be > running. > > The second and I think very important is that the powers to be at > Silverleaf have finally added the 470HP version of the Series 60 > engine paramiters to the list of engine types. It will be interesting > to see the diffrence in data from the old recommended 500HP setting. > > You can find the new programe here. > > http://www.silverleafelectronics.com/?q=node/270 > > The best things in life are simple! > > __________________________________________________ > > Kurt Horvath > 95 PT 42 > 10AC > |
10-15-2008, 04:04
Forget the Java! I can't get my better half to boil water. When I get
in the kitchen most folks just grab a drink and watch the show. She is an excelent Navigator, Got to look at the bright side. Sorry what did you say? Lost my hearing over 2500 decibels years ago from industrial noise exposure. I've had tech's say, hear that air leak? What air leak? The one next to your head Bubba. I'm sure that technology is on the horizon, Sound can tell the story if you know what your hearing, or if you can hear it to begin with. She's running great, purring like a Kitten, two days latter your putting a new cam and roller bearings in the S-60. I'm sure if you could hear it, the motor would sound different with only 5 cylinders banging away. Kurt Horvath 95 PT 42 10AC --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Kurt,facilitating passanger involvemt would require moving the > coffee maker to the dash. > > The one thing I miss with driving the bus is early warning engine > noise. I dont miss the noise but fear not hearing trouble. Some > time back there was a guy who posted looking for sound tracs of the > 8v92 and tranny sounds?????? kinda got me thinking of what the > benefits of sounds were. Wonder if you could math out a sound and > have the computer compare realtime sound to prove normal and > adnormal. this could help with the toad also. things like ;bad tire > tread and ;squeeling bearings, ;hissing hoses etc are unique and > adnormal. Sound is funny I can hear my cell phone and horns if I > wear headphones while on my loader otherwise all I hear is the > loader!!! Sound is an interesting early warning paramater. many > large gensets have a vibration cadence shutdown system, who whould > have considered that? > Greg94ptCa > > > > --- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath" > wrote: > > > > Silverleaf VMSpc Screen Cloning > > > > To maximize the usefulness of the VMSpc Silverleaf I have a 7" > inch > > touch screen monitor mounted on the top center of the dash the > laptop > > is in front of the passenger seat, It is almost perfect, A slight > > glance and I have more Inf. than I really need. Very COOL! When I > > first installed it. It mirrored the laptop, but after several days > > use it stopped doing this and went to expanded screen mode. > > > > I liked the fact that the laptop and the 7" were in sync. I ran > the > > VMSpc and Streets and Trips on one screen and have both programs > > running at the same time. It's set up as follows, click maximized > on > > either program for a full screen view or click minimize on either > > program and 1/3 of the scene on the left has all the vital engine > and > > speed gauges and the right 2/3 of the screen has the GPS and route > > tracking. It is set on rotate to coincided with the direction I'm > > driving, very easy to follow when your driving. Very good set up, > and > > in clone mode the CO-pilot & passengers have the same Inf. As the > > driver. One draw back is if your CO-pilot has a tendency to help > in > > anything other than directions it's hard to hide how fast your > going. > > > > As an expanded desktop it isn't good for the passengers to view or > > help navigate and it will not run Streets and trips independently > in > > the expanded screen mode, if I try to open it independently to > each > > screen it will not function. It won't find the com. port for the > GPS > > puck > > > > I have been using it this way for several months now. Today I > decided > > to fix this problem. > > > > Well after a search for a solution and finding a lot of B.S. > mostly > > gamer, graphic art, and presentation software and video card stuff > > that wasn't applicable to my problem or budget, I ran across a > three > > sentence explanation on how to do this. It's simple, and it works > > perfectly. > > > > Here is how to Clone or Mirror the two monitors. > > > > Fn + F8 (CRT/LCD) functions > > > > On the F8 key, you will notice a blue CRT/LCD marking. By holding > > down the blue Fn key at the bottom left of the keyboard and > pressing > > F8, you can change to which screen to send the output. Each time > you > > hold Fn and press F8, you cycle through the options in the Output > To > > list. > > > > The first cycle on my laptop remains as is. The second cycle moves > > the desktop to the second monitor and the first monitor goes > blank. > > The third cycling of the CRT/LCD key both monitors function in > clone > > mode the are the mirror image of each other and they are both > fully > > functional. The touch screen works by touching or using the touch > pad > > on the laptop or with a mouse. The laptop is also fully functional. > > > > Two other notes on the VMSpc: It would sometime freeze up when I > > would maximize the Streets and Trips screen then return to the > VMSpc > > program. I would have to restart the VMSpc program. The fix for > this > > is on the VMSpc toolbar. > > > > Click on ADVANCED when the window opens click on the box marked > > AutoRestart then click OK. The program will run flawlessly no > matter > > what you open on top of it. When you go back to it. It will be > > running. > > > > The second and I think very important is that the powers to be at > > Silverleaf have finally added the 470HP version of the Series 60 > > engine paramiters to the list of engine types. It will be > interesting > > to see the diffrence in data from the old recommended 500HP > setting. > > > > You can find the new programe here. > > > > http://www.silverleafelectronics.com/?q=node/270 > > > > The best things in life are simple! > > > > __________________________________________________ > > > > Kurt Horvath > > 95 PT 42 > > 10AC > > > |
