You look for problems, YOU WILL FIND THEM!!!!
10-17-2008, 06:13
My problem hasn't changed as far as the exhaust being all messed up.
Here is a photo of the exhaust now that I'm getting into it. I'm glad I
didn't burn up! And we thought the cracked pipe next to the turbo was
bad. The pipe is completely disconnected. You can't see any of these
problems from the rear or curbside.
By the way if this ball joint connector is supposed to let the pipe
flex so it doesn't crack next to the turbo why is there a clamp on the
mount that holds everything down tight????
Kurt Horvath
95 PT 42
10AC
10-17-2008, 09:31
Kurt
Mine was burnt out and I replaced that bell? with stainless flex.
Fred & Jeanne Hulse
Morristown Arizona
1997 Wanderlodge WLWB41
10-17-2008, 10:42
Same, here -- a previous owner installed stainless flex on mine too.
aeonix1@...
On the road at Edinburg, VA
On Oct 17, 2008, at 5:31 PM, Fred Hulse wrote:
> Kurt
> Fred & Jeanne Hulse
> Morristown Arizona
10-17-2008, 13:02
Kurt, the frame on my dump truck twist quite a bit as I drive off road. I converted the truck from a city tractor and within one month the exhaust had 3 cracks ( one at the manifold) I replaced the pipe and bends then used widebands to join the unions and not pipe in bell ends that the system had. on one problem area I used straps with springs for washers to keep agressive but nota fixedforce on the joint. The truck builders crossed the frame to hang the stack whick leaves alot of room for flex and give to help avoid a crack but the bus exhaust cantilevers close off the maniforl. I think the weight of the exhaust should be held ridgit at the top with a single point as a pivot. then hung stable from the sides????? one other point to check is the motor and transmission mounts. they too cause diferential movement that may result as a crack.
Greg94ptCa
> Kurt Horvath
> 95 PT 42
> 10AC
