water problem
05-29-2005, 06:24
water problem
I had the same thing happen. Thought it was the sporlan valve- ordered some
from Stephen Birtles-- prompt service- Ernie-83PT40 in Texas
05-29-2005, 08:03
water problem
Not sure about your rig setup for water but on mine I have to flip the
switch to allow water to flow into tank. When the tank is full I have to
flip the switch off or the water pumps will not pump water out of the tank.
Rob Robinson
1994 WLWB
Victoria, BC
-----Original Message-----
[mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of mortyheller
Sent: Sunday, May 29, 2005 4:53 PM
Subject: [WanderlodgeForum] water problem
i hooked up to city water and had the fill switch off and the water
ran into the tank. when i turn the pump on with the tank full the pump
works but i don't get any water. any idears what can be wrong??
morty heller 87 pt 40 jax. fl in ohio
Yahoo! Groups Links
a.. To visit your group on the web, go to:
No virus found in this outgoing message.
Checked by AVG Anti-Virus.
Version: 7.0.322 / Virus Database: 267.2.0 - Release Date: 5/27/2005
05-29-2005, 09:53
water problem
05-29-2005, 10:12
water problem
Sporlan valve stuck open. You can try turning the fill switch on with
water flowing from the hose, see if a piece of debris is holding the
valve open, usually need to replace the diaphragm (rebuild kit).
- Jeff Miller
http://www.wanderlodge.net
--- In WanderlodgeForum@yahoogroups.com, "mortyheller"
pump
05-30-2005, 00:05
water problem
Hi Morty,
Make sure that your air purge switch is off and that the hot water
tank fill/drain switch is in the proper position. If these two items
are OK, then it probably is one of the sporlan valves acting up.
Shane Fedeli
85PT40
Hershey, PA
pump
