6" SS EXHAUST STACK
10-30-2008, 09:56
6" SS EXHAUST STACK
Hi Ernie,
There was talk about it and I asked Jessie at Tech Services and he
thought there may be but several PT 42 guys said no. Well curiousity
got the best of me so I went lookin and without a lot of trouble
there isn't going to be a hatch. I need to get the radiator checked
out anyway so no big deal. I would like to come up with a swing
system so you can get into the side of the engine bay from the
roadside. Now there's a project!
Kurt Horvath
95 PT 42
10AC
--- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote:
> Kurt- is your engine access in your rear closet floor?
> Ernie Ekberg
> 83PT40
> Weatherford, Texas
> **************Plan your next getaway with AOL Travel. Check out
Today's Hot
> 5 Travel Deals!
> (http://pr.atwola.com/promoclk/100000075x...71803/aol?
redir=http://travel.aol.com/discount-travel?nc...av00000001)
10-30-2008, 10:38
6" SS EXHAUST STACK
Good grief! Do all people named Curt/Kurt have too much time on their
hands?! How do you find time to do that spectacular custom weapon
engraving? ;^)
1991 WB40 "Texas Minivan"
--- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath"
> Hi Ernie,
> Kurt Horvath
> 95 PT 42
> 10AC
> > Ernie Ekberg
> > 83PT40
> > Weatherford, Texas
> Today's Hot
> > 5 Travel Deals!
ncid=emlcntustrav00000001)
10-30-2008, 11:39
6" SS EXHAUST STACK
There isn't ehough time! LOL
Kurt Horvath
95 PT 42
10AC
--- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...>
their
> engraving? ;^)
> Mike Bulriss
> San Antonio, TX
> > Hi Ernie,
he
curiousity
checked
> > Kurt Horvath
> > 95 PT 42
> > 10AC
> > > Ernie Ekberg
> > > 83PT40
> > > Weatherford, Texas
out
> > Today's Hot
> > > 5 Travel Deals!
10-30-2008, 12:48
6" SS EXHAUST STACK
Kurt, try and figure why there were 4 bends. it may be that it was
engineered to alow for swing room between the 'hung exhaust' and
the 'torque reaction of the ruber mounted detroit'. look at the roll
of the torque and see that there is a place for the movement to twist
a union. I kinda think this movement was the problem with the
resulting crack. crack=result ;movement=cause ;facilitate movement
=repair. may be that BB enginered it correct but someone
overtightened a band to cure an exhaust leak??????? you also got to
keep the stack from cantilivering off of the maniford with your new
design. Scavenging is one variable in fuel efficiency. even straight
pipes some time will result in lower fuel economy because the intake
variable get screwd. backpressure is mathed into the computer.
10-30-2008, 14:02
6" SS EXHAUST STACK
Kurt,
I agree with Greg. I'm gonna keep mine stock. There's a bunch
of vibration and movement back there. I figure BB's been building
buses a whole lot longer than I have. Initially I'd scratch my
head when looking at the frame and support pieces, but when
you consider that something as big as a bus must twist and flex,
this flexibility needs to be designed in. Make one piece stronger
and you've created a stress raiser someplace else.
I have a friend who transplanted a honda v-tech motor into a
lotus elise. Everything worked but the alternator mount. The mount
insists on cracking. There can be some weird harmonics and
resonant frequencies going on that are difficult to grasp and
only trial and error and a 50 year track record of building buses
can solve (unless you can model it and run high powered
computer finite element analysis on it). He's still fighting that
mount...
Okay, I'm off my soap box.
David Brady
'02 LXi, NC
Internal Virus Database is out-of-date.
Checked by AVG. Version: 7.5.405 / Virus Database: 270.8.0/1715 - Release Date: 10/9/2008 12:00 AM
10-30-2008, 15:56
6" SS EXHAUST STACK
David, Would you like to take that brand new muffler off my hands???
According to DD straight pipe & ECU will not have any issues in the
95 vintage S 60.
OEM built that pipe for BB ACAP - As Cheep As Possible -
The original routing of the pipe leaves the turbo, source of the
first failure, cracked the 1st 90 degree turn a short straight run
2nd. 90 degree turn, then into a double ball connector that also
telescopes in and out. You can check out that piece of S---, sorry
engineering wonder here.
http://www.dynaflexproducts.com/download...g70-89.pdf
Page 76 Double Ball Joint with Slip Joint Feature Allowing Lateral
Movement length 16 to 18 inches mine measures 14 .55 inches at
present. This marvel allows for 10 degrees of angularity 360 degree
rotation 2" of offset 2" axial movement,. Hell the u joints can't
move around that much. Besides it was hard clamped to the mount from
the engine in front of this connection not to mention rusted to the
point that it took an pneumatic impact chisel to get it apart.. So
what's the point. You need flex in between the turbo and the first
mount.
The Flex Connector with liner I choose is here at
http://vibrantperformance.com/catalog/product_info.php?
cPath=1022_1035_1064_1114&products_id=1008&osCsid=999d7ef5fdd15864bae3
3db41abf5ef9
The 2 90 degree turns were fabricated in that manner because it's not
easy to bend large diameter pipe in a single 180 degree bend, thus
they weld 2 90's together, which is the industry standard for
manufacturing a 180 degree turn in large pipe exhausts. Well this
ain't the factory and we're not constrained by what is easy. I have
acquired a 14ga 180 degree U-Tube that has the same external
dimensions as the original pipe. I'm not an engineer but I reasonably
certain that with the remaining 90 degree bend and a 45 degree bend
there will be sufficient back pressure.
There will also be a flexible pipe hanger mount behind the Flex
connector mounted on the ceiling of the engine compartment that will
support the middle section of pipe and will allow for any movement
and or torque that may be transferred to the pipe by the motor. The
original clamps for the muffler have to go as they are 6" but the
rubber isolated mounting bars will remain and that's all that was
there to begin with. So where's the rub? Bub!
Not to take anything away from the engineers that designed the Bird,
But there are some glaring deficiencies. 7 way trailer plug, Air
Purge System, Watts valve, Accelerator and Brake peddles, Front Left
Shock Mount, Relay for Jake Brake, W/D Vent for Slendide 2000,
Installation of Refrigerator with inadequate convection, The seat
belts mounted to floor instead of the seat, That reminds me I still
have to fix that one. Nothing like hitting a road transition just to
have the air ride seat bounce and the seat belts automatically adjust
for the slack then the air ride seat rebounds and the belts try to
cut you in half at the waist. That's just the 95 PT 42. I'm not
bitchin! I'm fixin
Kurt Horvath
95 PT 42
10AC
--- In WanderlodgeForum@yahoogroups.com, David Brady
> Kurt,
> mount...
> David Brady
> '02 LXi, NC
roll
twist
to
new
straight
intake
> > Checked by AVG.
10/9/2008 12:00 AM
10-30-2008, 16:33
6" SS EXHAUST STACK
As one of our contributors, a retired heavy equip mech. recently
posted a reminder, sorry I don't recall his name at the moment. The V-
Band clamps are meant to hold pipes in place not cinch them down
tightly. My system has three V-Band clamps and Flange Assemblies that
are placed in a manner that will allow for multiple Axis movement.
Hangers are flexible and hard mounts have rubber isolators. This
equates to 7 attaching points all will flex or swivel. Well 8 if you
count the 5" X 10" SS Braided Flex Connector that will flex in any
direction.
Kurt Horvath
95 Pt 42
10AC
> 95 vintage S 60.
from
> mount.
> 3db41abf5ef9
not
reasonably
will
The
Bird,
Left
to
adjust
> bitchin! I'm fixin
> Kurt Horvath
> 95 PT 42
> 10AC
> > Kurt,
> > mount...
> > David Brady
> > '02 LXi, NC
was
> roll
> twist
movement
got
> to
> new
> straight
> intake
> > > Checked by AVG.
> 10/9/2008 12:00 AM
10-30-2008, 17:06
6" SS EXHAUST STACK
Yea I've heard that but the one with the liner has fixed the high
pressure leaks according to the Mfg. Let's hope. Prevost has from
what I recall pipes bent in one piece, they are held together with
those nifty band clamps that seat and conform to the pipe exterior,
If the V-Bands and Flanges don't work out I'll go to those pipe
clamps. The Flanges are also available with three different types of
gaskets, o-ring, flat, and, and, and I can't remember, oh yea the
type I bought, male-female flanges, perfect alignment, leak free,
again according to Vibrant Mfg. There is also a Stainless Steel
Muffler available that may work well on your coach, but it's inlet
outlet is 5" not the 6" like on your coach. well I assume yours is
6"??? Also it is 10" in diameter which would help with crowed exhaust
tunnel.
Kurt Horvath
95 Pt 42
10AC
> Hi Kurt,
> No thanks, I already have a stock muffler. Thanks for the links,
> there's some pretty nifty items there. Be careful with those fancy
> braided stainless steel pieces. They look sharp, but they've always
> leaked on my turbocharged subaru wrx. Kurt, you've been around
> a few over-the-road coaches, Prevost' and what not, what do they
> run on their exhaust systems; i.e., expansion pipes, flex pipe, etc.
> David Brady
> '02 LXi, NC
hands???
> > 95 vintage S 60.
> > http://www.dynaflexproducts.com/download...g_03_pg70-
89.pdf
> > <http://www.dynaflexproducts.com/download...g_03_pg70-
89.pdf>
degree
from
> > mount.
> > <http://vibrantperformance.com/catalog/product_info.php?>
> > 3db41abf5ef9
not
have
reasonably
bend
will
The
Bird,
Left
still
to
adjust
> > bitchin! I'm fixin
> > Kurt Horvath
> > 95 PT 42
> > 10AC
> > , David Brady
> > wrote:
> > > Kurt,
building
stronger
mount
buses
that
> > > mount...
> > > David Brady
> > > '02 LXi, NC
it was
> > roll
to
> > twist
movement
got
> > to
your
> > new
> > straight
> > intake
> > > > Checked by AVG.
Date:
> > 10/9/2008 12:00 AM
> > Checked by AVG.
10/9/2008 12:00 AM
10-30-2008, 17:31
6" SS EXHAUST STACK
Hi Kurt,
David Brady
'02 LXi, NC
hands???
95 vintage S 60.
http://www.dynaflexproducts.com/downloads/DP_Catalog_03_pg70-89.pdf
mount.
3db41abf5ef9
bitchin! I'm fixin
Kurt Horvath
95 PT 42
10AC
David Brady "dmb993@..."
> Kurt,
> mount...
> David Brady
> '02 LXi, NC
it was
roll
to
twist
movement
got
to
your
new
straight
intake
> > Checked by AVG.
Date:
10/9/2008 12:00 AM
10-31-2008, 08:39
6" SS EXHAUST STACK
The LXi, like your WB, uses a 6 inch muffler. Five inch will
certainly suck some ponies away.
David Brady
'02 LXi, NC
tunnel.
Kurt Horvath
95 Pt 42
10AC
> Hi Kurt,
etc.
> David Brady
> '02 LXi, NC
hands???
issues in
> > 95 vintage S 60.
straight run
also
sorry
89.pdf
> > <http://www.dynaflexproducts.com/downloads/DP_Catalog_03_pg70-
89.pdf>
Lateral
degree
can't
mount
from
to
apart.. So
first
> > mount.
> > 3db41abf5ef9
it's
not
thus
this
I
have
reasonably
degree
bend
Flex
that
will
movement
motor.
The
was
Bird,
Air
Front
Left
seat
still
just
to
automatically
adjust
try to
not
> > bitchin! I'm fixin
> > Kurt Horvath
> > 95 PT 42
> > 10AC
> > <"Wanderlodge"Forum%40yahoogroups.com>,
David Brady
> > wrote:
> > > Kurt,
bunch
building
scratch my
when
and flex,
stronger
into a
The
mount
grasp and
building
buses
fighting
that
> > > mount...
> > > David Brady
> > > '02 LXi, NC
be that
it was
exhaust'
look at
> > roll
movement
to
> > twist
problem with the
;facilitate
movement
someone
you also
got
> > to
maniford with
your
> > new
efficiency. even
> > straight
because the
> > intake
the computer.
> > > > Checked by AVG.
Release
Date:
> > 10/9/2008 12:00 AM
> > Checked by AVG.
Date:
10/9/2008 12:00 AM
