6" SS EXHAUST STACK
10-31-2008, 09:14
Post: #21
6" SS EXHAUST STACK
David,
I think your muffler is 6" inlet & out your pipes from the turbo to
the muffler are 5"
Kurt Horvath
95 PT 42
10AC
--- In WanderlodgeForum@yahoogroups.com, David Brady
> The LXi, like your WB, uses a 6 inch muffler. Five inch will
> certainly suck some ponies away.
> David Brady
> '02 LXi, NC
> Kurt Horvath wrote:
> > Yea I've heard that but the one with the liner has fixed the high
> > pressure leaks according to the Mfg. Let's hope. Prevost has from
> > what I recall pipes bent in one piece, they are held together with
> > those nifty band clamps that seat and conform to the pipe
exterior,
> > If the V-Bands and Flanges don't work out I'll go to those pipe
> > clamps. The Flanges are also available with three different types
of
> > gaskets, o-ring, flat, and, and, and I can't remember, oh yea the
> > type I bought, male-female flanges, perfect alignment, leak free,
> > again according to Vibrant Mfg. There is also a Stainless Steel
> > Muffler available that may work well on your coach, but it's inlet
> > outlet is 5" not the 6" like on your coach. well I assume yours is
> > 6"??? Also it is 10" in diameter which would help with crowed
exhaust
> > tunnel.
> > Kurt Horvath
> > 95 Pt 42
> > 10AC
> > , David Brady
> > wrote:
> > > Hi Kurt,
> > > No thanks, I already have a stock muffler. Thanks for the links,
> > > there's some pretty nifty items there. Be careful with those
fancy
> > > braided stainless steel pieces. They look sharp, but they've
always
> > > leaked on my turbocharged subaru wrx. Kurt, you've been around
> > > a few over-the-road coaches, Prevost' and what not, what do they
> > > run on their exhaust systems; i.e., expansion pipes, flex pipe,
etc.
> > > David Brady
> > > '02 LXi, NC
> > > Kurt Horvath wrote:
> > > > David, Would you like to take that brand new muffler off my
> > hands???
> > > > According to DD straight pipe & ECU will not have any issues
in
> > the
> > > > 95 vintage S 60.
> > > > OEM built that pipe for BB ACAP - As Cheep As Possible -
> > > > The original routing of the pipe leaves the turbo, source of
> > > > first failure, cracked the 1st 90 degree turn a short
straight run
> > > > 2nd. 90 degree turn, then into a double ball connector that
also
> > > > telescopes in and out. You can check out that piece of S---,
sorry
> > > > engineering wonder here.
> > > > http://www.dynaflexproducts.com/download...g_03_pg70-
> > <http://www.dynaflexproducts.com/download...g_03_pg70->
> > 89.pdf
> > 89.pdf>
> > > > Page 76 Double Ball Joint with Slip Joint Feature Allowing
Lateral
> > > > Movement length 16 to 18 inches mine measures 14 .55 inches at
> > > > present. This marvel allows for 10 degrees of angularity 360
> > degree
> > > > rotation 2" of offset 2" axial movement,. Hell the u joints
can't
> > > > move around that much. Besides it was hard clamped to the
mount
> > from
> > > > the engine in front of this connection not to mention rusted
to
> > the
> > > > point that it took an pneumatic impact chisel to get it
apart.. So
> > > > what's the point. You need flex in between the turbo and the
first
> > > > mount.
> > > > The Flex Connector with liner I choose is here at
> > > > http://vibrantperformance.com/catalog/product_info.php?
> > <http://vibrantperformance.com/catalog/product_info.php?>
> > <http://vibrantperformance.com/catalog/product_info.php?>>
cPath=1022_1035_1064_1114&products_id=1008&osCsid=999d7ef5fdd15864bae3
> > > > 3db41abf5ef9
> > > > The 2 90 degree turns were fabricated in that manner because
it's
> > not
> > > > easy to bend large diameter pipe in a single 180 degree bend,
thus
> > > > they weld 2 90's together, which is the industry standard for
> > > > manufacturing a 180 degree turn in large pipe exhausts. Well
this
> > > > ain't the factory and we're not constrained by what is easy. I
> > have
> > > > acquired a 14ga 180 degree U-Tube that has the same external
> > > > dimensions as the original pipe. I'm not an engineer but I
> > reasonably
> > > > certain that with the remaining 90 degree bend and a 45 degree
> > bend
> > > > there will be sufficient back pressure.
> > > > There will also be a flexible pipe hanger mount behind the
Flex
> > > > connector mounted on the ceiling of the engine compartment
that
> > will
> > > > support the middle section of pipe and will allow for any
movement
> > > > and or torque that may be transferred to the pipe by the
motor.
> > The
> > > > original clamps for the muffler have to go as they are 6" but
> > > > rubber isolated mounting bars will remain and that's all that
was
> > > > there to begin with. So where's the rub? Bub!
> > > > Not to take anything away from the engineers that designed the
> > Bird,
> > > > But there are some glaring deficiencies. 7 way trailer plug,
Air
> > > > Purge System, Watts valve, Accelerator and Brake peddles,
Front
> > Left
> > > > Shock Mount, Relay for Jake Brake, W/D Vent for Slendide 2000,
> > > > Installation of Refrigerator with inadequate convection, The
seat
> > > > belts mounted to floor instead of the seat, That reminds me I
> > still
> > > > have to fix that one. Nothing like hitting a road transition
just
> > to
> > > > have the air ride seat bounce and the seat belts automatically
> > adjust
> > > > for the slack then the air ride seat rebounds and the belts
try to
> > > > cut you in half at the waist. That's just the 95 PT 42. I'm
not
> > > > bitchin! I'm fixin
> > > > Kurt Horvath
> > > > 95 PT 42
> > > > 10AC
> > > > , David Brady
> > > > wrote:
> > > > > Kurt,
> > > > > I agree with Greg. I'm gonna keep mine stock. There's a
bunch
> > > > > of vibration and movement back there. I figure BB's been
> > building
> > > > > buses a whole lot longer than I have. Initially I'd scratch
my
> > > > > head when looking at the frame and support pieces, but when
> > > > > you consider that something as big as a bus must twist and
flex,
> > > > > this flexibility needs to be designed in. Make one piece
> > stronger
> > > > > and you've created a stress raiser someplace else.
> > > > > I have a friend who transplanted a honda v-tech motor into a
> > > > > lotus elise. Everything worked but the alternator mount. The
> > mount
> > > > > insists on cracking. There can be some weird harmonics and
> > > > > resonant frequencies going on that are difficult to grasp
> > > > > only trial and error and a 50 year track record of building
> > buses
> > > > > can solve (unless you can model it and run high powered
> > > > > computer finite element analysis on it). He's still fighting
> > that
> > > > > mount...
> > > > > Okay, I'm off my soap box.
> > > > > David Brady
> > > > > '02 LXi, NC
> > > > > Gregory OConnor wrote:
> > > > > > Kurt, try and figure why there were 4 bends. it may be
that
> > it was
> > > > > > engineered to alow for swing room between the 'hung
exhaust'
> > and
> > > > > > the 'torque reaction of the ruber mounted detroit'. look
at
> > the
> > > > roll
> > > > > > of the torque and see that there is a place for the
movement
> > to
> > > > twist
> > > > > > a union. I kinda think this movement was the problem with
> > > > > > resulting crack. crack=result ;movement=cause ;facilitate
> > movement
> > > > > > =repair. may be that BB enginered it correct but someone
> > > > > > overtightened a band to cure an exhaust leak??????? you
also
> > got
> > > > to
> > > > > > keep the stack from cantilivering off of the maniford with
> > your
> > > > new
> > > > > > design. Scavenging is one variable in fuel efficiency.
even
> > > > straight
> > > > > > pipes some time will result in lower fuel economy because
> > > > intake
> > > > > > variable get screwd. backpressure is mathed into the
computer.
> > > > > > Internal Virus Database is out-of-date.
> > > > > > Checked by AVG.
> > > > > > Version: 7.5.405 / Virus Database: 270.8.0/1715 - Release
> > Date:
> > > > 10/9/2008 12:00 AM
> > > > Checked by AVG.
Date:
> > 10/9/2008 12:00 AM
> > Checked by AVG.
> > Version: 7.5.405 / Virus Database: 270.8.0/1715 - Release Date:
10/9/2008 12:00 AM
10-31-2008, 12:42
Post: #22
6" SS EXHAUST STACK
I went to 5" muffler on my 8V92 last year. Have not noticed any
change in performance. My logic is the fact that 5" is the outlet
from the turbo. Besides that, 5" is the common exhaust on most of the
over the road rigs today. There are exceptions, but I don't see any
advantage to 6" with the turbo outlet restricted to 5"
> David Brady
> '02 LXi, NC
> > those nifty band clamps that seat and conform to the pipe exterior,
> > clamps. The Flanges are also available with three different types of
> > 6"??? Also it is 10" in diameter which would help with crowed exhaust
> > tunnel.
> > Kurt Horvath
> > 95 Pt 42
> > 10AC
> > , David Brady
> > wrote:
> > > Hi Kurt,
> > > there's some pretty nifty items there. Be careful with those fancy
> > > braided stainless steel pieces. They look sharp, but they've always
> > > run on their exhaust systems; i.e., expansion pipes, flex pipe, etc.
> > > David Brady
> > > '02 LXi, NC
> > hands???
> > > > According to DD straight pipe & ECU will not have any issues in
> > the
> > > > 95 vintage S 60.
> > > > The original routing of the pipe leaves the turbo, source of the
> > > > first failure, cracked the 1st 90 degree turn a short straight run
> > > > 2nd. 90 degree turn, then into a double ball connector that also
> > > > telescopes in and out. You can check out that piece of S---, sorry
> > 89.pdf
> > 89.pdf>
> > > > Page 76 Double Ball Joint with Slip Joint Feature Allowing Lateral
> > degree
> > > > rotation 2" of offset 2" axial movement,. Hell the u joints can't
> > > > move around that much. Besides it was hard clamped to the mount
> > from
> > > > the engine in front of this connection not to mention rusted to
> > the
> > > > point that it took an pneumatic impact chisel to get it apart.. So
> > > > what's the point. You need flex in between the turbo and the first
> > > > mount.
> > > > 3db41abf5ef9
> > > > The 2 90 degree turns were fabricated in that manner because it's
> > not
> > > > easy to bend large diameter pipe in a single 180 degree bend, thus
> > > > manufacturing a 180 degree turn in large pipe exhausts. Well this
> > have
> > reasonably
> > bend
> > > > There will also be a flexible pipe hanger mount behind the Flex
> > > > connector mounted on the ceiling of the engine compartment that
> > will
> > > > support the middle section of pipe and will allow for any movement
> > > > and or torque that may be transferred to the pipe by the motor.
> > The
> > > > original clamps for the muffler have to go as they are 6" but the
> > > > rubber isolated mounting bars will remain and that's all that was
> > Bird,
> > > > But there are some glaring deficiencies. 7 way trailer plug, Air
> > > > Purge System, Watts valve, Accelerator and Brake peddles, Front
> > Left
> > > > Installation of Refrigerator with inadequate convection, The seat
> > still
> > > > have to fix that one. Nothing like hitting a road transition just
> > to
> > adjust
> > > > for the slack then the air ride seat rebounds and the belts try to
> > > > cut you in half at the waist. That's just the 95 PT 42. I'm not
> > > > bitchin! I'm fixin
> > > > Kurt Horvath
> > > > 95 PT 42
> > > > 10AC
> > > > , David Brady
> > > > wrote:
> > > > > Kurt,
> > > > > I agree with Greg. I'm gonna keep mine stock. There's a bunch
> > building
> > > > > buses a whole lot longer than I have. Initially I'd scratch my
> > > > > you consider that something as big as a bus must twist and flex,
> > stronger
> > mount
> > > > > resonant frequencies going on that are difficult to grasp and
> > buses
> > that
> > > > > mount...
> > > > > David Brady
> > > > > '02 LXi, NC
> > > > > > Kurt, try and figure why there were 4 bends. it may be that
> > it was
> > > > > > engineered to alow for swing room between the 'hung exhaust'
> > and
> > > > > > the 'torque reaction of the ruber mounted detroit'. look at
> > the
> > > > roll
> > > > > > of the torque and see that there is a place for the movement
> > to
> > > > twist
> > > > > > a union. I kinda think this movement was the problem with the
> > movement
> > > > > > overtightened a band to cure an exhaust leak??????? you also
> > got
> > > > to
> > your
> > > > new
> > > > > > design. Scavenging is one variable in fuel efficiency. even
> > > > straight
> > > > > > pipes some time will result in lower fuel economy because the
> > > > intake
> > > > > > variable get screwd. backpressure is mathed into the computer.
> > > > > > Checked by AVG.
> > Date:
> > > > 10/9/2008 12:00 AM
> > > > Checked by AVG.
> > 10/9/2008 12:00 AM
> > Checked by AVG.
10/9/2008 12:00 AM
10-31-2008, 14:05
Post: #23
6" SS EXHAUST STACK
That's correct.
David Brady
'02 LXi, NC
Kurt Horvath wrote:
David,
the muffler are 5"
Kurt Horvath
95 PT 42
10AC
David Brady "dmb993@..."
> David Brady
> '02 LXi, NC
high
from
with
exterior,
pipe
types
of
free,
Steel
inlet
yours is
exhaust
> > tunnel.
> > Kurt Horvath
> > 95 Pt 42
> > 10AC
> > <"Wanderlodge"Forum%40yahoogroups.com>,
David Brady
> > wrote:
> > > Hi Kurt,
the links,
those
fancy
they've
always
around
do they
flex pipe,
etc.
> > > David Brady
> > > '02 LXi, NC
muffler off my
> > hands???
have any issues
in
> > the
> > > > 95 vintage S 60.
Possible -
source of
short
straight run
connector that
also
of S---,
sorry
> > > > http://www.dynaflexproducts.com/downloads/DP_Catalog_03_pg70-
> > <http://www.dynaflexproducts.com/downloads/DP_Catalog_03_pg70->
> > 89.pdf
> > 89.pdf>
Allowing
Lateral
.55 inches at
angularity 360
> > degree
u joints
can't
to the
mount
> > from
mention rusted
to
> > the
get it
apart.. So
turbo and the
first
> > > > mount.
> > > > 3db41abf5ef9
manner because
it's
> > not
degree bend,
thus
standard for
exhausts. Well
this
is easy. I
> > have
external
engineer but I
> > reasonably
a 45 degree
> > bend
behind the
Flex
compartment
that
> > will
for any
movement
by the
motor.
> > The
are 6" but
that's all that
was
designed the
> > Bird,
trailer plug,
Air
peddles,
Front
> > Left
Slendide 2000,
convection, The
seat
reminds me I
> > still
transition
just
> > to
automatically
> > adjust
the belts
try to
42. I'm
not
> > > > bitchin! I'm fixin
> > > > Kurt Horvath
> > > > 95 PT 42
> > > > 10AC
David Brady
> > > > wrote:
> > > > > Kurt,
There's a
bunch
BB's been
> > building
my
pieces, but when
must twist and
flex,
one piece
> > stronger
else.
v-tech motor into a
> > mount
harmonics and
difficult to grasp
record of building
> > buses
high powered
still fighting
> > that
> > > > > mount...
> > > > > David Brady
> > > > > '02 LXi, NC
bends. it may be
that
> > it was
the 'hung
exhaust'
> > and
detroit'. look
at
> > the
> > > > roll
place for the
movement
> > to
> > > > twist
the problem with
> > movement
correct but someone
leak??????? you
also
> > got
> > > > to
the maniford with
> > your
> > > > new
fuel efficiency.
even
> > > > straight
economy because
> > > > intake
mathed into the
computer.
> > > > > > Checked by AVG.
> > Date:
> > > > 10/9/2008 12:00 AM
> > > > Checked by AVG.
Release
Date:
> > 10/9/2008 12:00 AM
> > Checked by AVG.
Date:
10/9/2008 12:00 AM
Checked by AVG. Version: 7.5.405 / Virus Database: 270.8.0/1715 - Release Date: 10/9/2008 12:00 AM
10-31-2008, 14:30
Post: #24
6" SS EXHAUST STACK
In other words, it was slow with the 6" and its still slow with
the 5". It would be interesting if you could do a benchmark.
Climb a six percent grade before and after, or put it on a dyno.
I'll have to dig out my fluid flow equations to let you know what
the real restrictions are. Coming out of the turbo with a narrow
pipe should increase velocities due to the Bernoulli principle, but
shortly thereafter you really want to dump it to a wide low back-
pressure exhaust. Without benchmarks it's hard to tell what power
loss you've sustained.
David Brady
'02 LXi, NC
> David Brady
> '02 LXi, NC
high
from
with
exterior,
pipe
types of
free,
Steel
inlet
yours is
exhaust
> > tunnel.
> > Kurt Horvath
> > 95 Pt 42
> > 10AC
David Brady
> > wrote:
> > > Hi Kurt,
the links,
those fancy
they've always
around
do they
flex pipe, etc.
> > > David Brady
> > > '02 LXi, NC
muffler off my
> > hands???
have any issues in
> > the
> > > > 95 vintage S 60.
Possible -
source of the
short straight run
connector that also
of S---, sorry
> > 89.pdf
> > 89.pdf>
Allowing Lateral
.55 inches at
angularity 360
> > degree
u joints can't
to the mount
> > from
mention rusted to
> > the
get it apart.. So
turbo and the first
> > > > mount.
> > > > 3db41abf5ef9
manner because it's
> > not
degree bend, thus
standard for
exhausts. Well this
is easy. I
> > have
external
engineer but I
> > reasonably
a 45 degree
> > bend
behind the Flex
compartment that
> > will
for any movement
by the motor.
> > The
are 6" but the
that's all that was
designed the
> > Bird,
trailer plug, Air
peddles, Front
> > Left
Slendide 2000,
reminds me I
> > still
transition just
> > to
automatically
> > adjust
the belts try to
42. I'm not
> > > > bitchin! I'm fixin
> > > > Kurt Horvath
> > > > 95 PT 42
> > > > 10AC
David Brady
> > > > wrote:
> > > > > Kurt,
There's a bunch
BB's been
> > building
pieces, but when
one piece
> > stronger
else.
v-tech motor into a
> > mount
harmonics and
record of building
> > buses
high powered
still fighting
> > that
> > > > > mount...
> > > > > David Brady
> > > > > '02 LXi, NC
> > it was
the 'hung exhaust'
> > and
detroit'. look at
> > the
> > > > roll
> > to
> > > > twist
> > movement
correct but someone
> > got
> > > > to
the maniford with
> > your
> > > > new
> > > > straight
economy because the
> > > > intake
> > > > > > Checked by AVG.
> > Date:
> > > > 10/9/2008 12:00 AM
> > > > Checked by AVG.
Release Date:
> > 10/9/2008 12:00 AM
> > Checked by AVG.
Date:
10/9/2008 12:00 AM
10-31-2008, 17:24
Post: #25
6" SS EXHAUST STACK
David,
A few days ago you were all for a straight pipe.
Now we have delved into the effects and merits of the, "Bernoulli
effect" it presumes that the density of the flowing gas is constant,
which will not necessarily be true in this application.
If this were a consideration and a factor in design and function
wouldn't this be a standard application on all exhausts, considering
today's drive for better performance Vs energy expended Vs
particulate
matter expelled Vs whatever else the EPA thinks we should be
ejecting from our exhaust pipes?
One factor you may have not considered are the exhaust blankets I
mentioned. They will retain the heat within the pipes thus increasing
the velocity of the exhaust creating an accelerated flow of gasses
through the tubes.
If I may present another observation, 5" exhaust systems are the
standard on all production class 8 trucks.
Furthermore and for the heck of it I don't believe that the trucker
that has 8" stacks on his rig has considered the, "Bernoulli effect"
in his choice at the Chrome Shop. Although it mat have an effect on
performance further than just looking cool. They do look good, no
doubt.
For the last four weeks I have queried Detroit Diesel, Custom Exhaust
Fabricators, Several OEM Exhaust Mfg.'s, Marine Exhaust Engineers &
Fabricators, My BB Guru, and anyone else that would lend an ear, and
no one has expressed any apprehension or regard in the respect to a
5" exhaust system. In fact all parties expressed their surprise in
respect as to why the system would change size at the muffler.
Several owners have modified their systems to 5" from end to end, and
have seen no change in performance. Positive or negative, In general
it was just a matter of convenience in acquiring parts, I won't get
into that. That has recently been beaten to death at the expense of
all parties involved
If there is someone who would like to further this debate with
Imperical evidence of the merits of, or placing a venturi somewhere
in this exhaust system I have pasted a site below where you can
formulate your calculations. I would love to see some evidence of a
positive effect, in which case I would have no problem in adding a
venturi crimp in the exhaust system.
Bernoulli Calculation
http://hyperphysics.phy-astr.gsu.edu/Hba...r.html#beq
The calculation of the "real world" pressure in a constriction of a
tube is difficult to do because of viscous losses, turbulence, and
the assumptions which must be made about the velocity profile (which
affect the calculated kinetic energy). The model calculation here
assumes laminar flow (no turbulence), assumes that the distance from
the larger diameter to the smaller is short enough that viscous
losses can be neglected, and assumes that the velocity profile
follows that of theoretical laminar flow. Specifically, this involves
assuming that the effective flow velocity is one half of the maximum
velocity, and that the average kinetic energy density is given by one
third of the maximum kinetic energy density.
Now if you can swallow all those assumptions, you can model* the flow
in a tube where the volume flow rate is = cm3/s and the fluid density
is ñ = gm/cm3. For an inlet tube area A1= cm2 (radius r1 =cm), the
geometry of flow leads to an effective fluid velocity of v1 =cm/s.
Since the Bernoulli equation includes the fluid potential energy as
well, the height of the inlet tube is specified as h1 = cm. If the
area of the tube is constricted to A2=cm2 (radius r1 = cm), then
without any further assumptions the effective fluid velocity in the
constriction must be v2 = cm/s. The height of the constricted tube
is specified as h2 = cm.
The kinetic energy densities at the two locations in the tube can now
be calculated, and the Bernoulli equation applied to constrain the
process to conserve energy, thus giving a value for the pressure in
the constriction. First, specify a pressure in the inlet tube:
Inlet pressure = P1 = kPa = lb/in2 = mmHg = atmos.
The energy densities can now be calculated. The energy unit for the
CGS units used is the erg.
Inlet tube energy densities
Kinetic energy density = erg/cm3
Potential energy density = erg/cm3
Pressure energy density = erg/cm3
Constricted tube energy densities
The pressure energy density in the constricted tube can now be
finally converted into more conventional pressure units to see the
effect of the constricted flow on the fluid pressure:
Calculated pressure in constriction =
P2= kPa = lb/in2 = mmHg = atmos.
This calculation can give some perspective on the energy involved in
fluid flow, but it's accuracy is always suspect because of the
assumption of laminar flow. For typical inlet conditions, the energy
density associated with the pressure will be dominant on the input
side; after all, we live at the bottom of an atmospheric sea which
contributes a large amount of pressure energy. If a drastic enough
reduction in radius is used to yield a pressure in the constriction
which is less than atmospheric pressure, there is almost certainly
some turbulence involved in the flow into that constriction.
Nevertheless, the calculation can show why we can get a significant
amount of suction (pressure less than atmospheric) with
an "aspirator" on a high pressure faucet. These devices consist of a
metal tube of reducing radius with a side tube into the region of
constricted radius for suction.
*Note: Some default values will be entered for some of the values as
you start exploring the calculation. All of them can be changed as a
part of your calculation.
Kurt Horvath
95 PT 42
10AC
> > > > , David Brady
> > > > wrote:
> > > > > Hi Kurt,
links,
those fancy
they've always
around
they
pipe, etc.
> > > > > David Brady
> > > > > '02 LXi, NC
my
> > > > hands???
issues in
> > > > the
> > > > > > 95 vintage S 60.
of the
straight run
that also
-, sorry
> > <http://www.dynaflexproducts.com/download...g_03_pg70->>
> > > > 89.pdf
> > > > 89.pdf>
Allowing Lateral
inches at
360
> > > > degree
joints can't
mount
> > > > from
rusted to
> > > > the
apart.. So
the first
> > > > > > mount.
> > <http://vibrantperformance.com/catalog/product_info.php?>>>
> > > > > > 3db41abf5ef9
because it's
> > > > not
bend, thus
for
Well this
easy. I
> > > > have
external
> > > > reasonably
degree
> > > > bend
the Flex
compartment that
> > > > will
movement
motor.
> > > > The
but the
that was
designed the
> > > > Bird,
plug, Air
Front
> > > > Left
2000,
The seat
me I
> > > > still
transition just
> > > > to
automatically
> > > > adjust
belts try to
I'm not
> > > > > > bitchin! I'm fixin
> > > > > > Kurt Horvath
> > > > > > 95 PT 42
> > > > > > 10AC
> > > > > > , David Brady
> > > > > > wrote:
> > > > > > > Kurt,
bunch
> > > > building
scratch my
when
and flex,
> > > > stronger
into a
mount. The
> > > > mount
grasp and
building
> > > > buses
fighting
> > > > that
> > > > > > > mount...
> > > > > > > David Brady
> > > > > > > '02 LXi, NC
be that
> > > > it was
exhaust'
> > > > and
look at
> > > > the
> > > > > > roll
movement
> > > > to
> > > > > > twist
with the
> > > > > > > > resulting crack.
> > > > movement
someone
you also
> > > > got
> > > > > > to
with
> > > > your
> > > > > > new
efficiency. even
> > > > > > straight
because the
> > > > > > intake
computer.
> > > > > > > > Checked by AVG.
Release
> > > > Date:
> > > > > > 10/9/2008 12:00 AM
> > > > > > Checked by AVG.
Date:
> > > > 10/9/2008 12:00 AM
> > > > Checked by AVG.
Date:
> > 10/9/2008 12:00 AM
> > Checked by AVG.
10/9/2008 12:00 AM
11-01-2008, 04:18
Post: #26
6" SS EXHAUST STACK
Having recently replaced my muffler (at great expense) -- had I to do
it over again, I'd have switched over to a 5" system from turbo to
stack. As others have stated, it's 5" at the turbo outlet and the
standard in the heavy truck industry is 5".
The only performance difference I notice (between the old blown out
muffler and the new one) is that the exhaust-type Jake brake seems to
be slightly less effective.
aeonix1@...
On the road at Hohenwald, TN (Natchez Trace Parkway)
On Oct 31, 2008, at 11:24 PM, Kurt Horvath wrote:
> <snip>
11-01-2008, 05:33
Post: #27
6" SS EXHAUST STACK
Hi Kurt,
I am for hollow unbaffled straight pipes. The Bernoulli effect,
or "crimp" is built into the turbocharger. Take a look, every
one I've seen has the exhaust tapering to a smaller diameter
as it passes the turbine to increase velocities. I'm suggesting
that performance may be enhanced by providing a taper from
the outlet of the turbo exhaust thru the exhaust system. Our
taper is a 5" pipe at going into 6" pipe; that's a surface area of
19.6 sq inches expanding to 28.3 square inches. Basically a horn
hanging from the outlet of the exhaust turbo enhancing the flow
of gases from the turbo. I'm not surprised the vendors support your
desire for a 5" exhaust. The only way to really get at the bottom
of this is to try both and dyno both.
David Brady
'02 LXi, NC
Kurt Horvath wrote:
David,
particulate
through the tubes.
doubt.
http://hyperphysics.phy-astr.gsu.edu/Hbase/pber.html#beq
Kurt Horvath
95 PT 42
10AC
David Brady
> > > > wrote:
> > > > > Hi Kurt,
Thanks for the
links,
careful with
those fancy
sharp, but
they've always
you've been
around
not, what do
they
pipes, flex
pipe, etc.
> > > > > David Brady
> > > > > '02 LXi, NC
new muffler off
my
> > > > hands???
will not have any
issues in
> > > > the
> > > > > > 95 vintage S 60.
Cheep As Possible -
the turbo, source
of the
turn a short
straight run
ball connector
that also
that piece of S--
-, sorry
> > <http://www.dynaflexproducts.com/downloads/DP_Catalog_03_pg70->>
> > > > 89.pdf
> > > > 89.pdf>
Feature
Allowing Lateral
measures 14 .55
inches at
360
> > > > degree
Hell the u
joints can't
hard clamped to the
mount
> > > > from
not to mention
rusted to
> > > > the
chisel to get it
apart.. So
the first
> > > > > > mount.
here at
> > > > > > 3db41abf5ef9
that manner
because it's
> > > > not
single 180 degree
bend, thus
industry standard
for
pipe exhausts.
Well this
easy. I
> > > > have
has the same
external
an engineer but I
> > > > reasonably
bend and a 45
degree
> > > > bend
mount behind
the Flex
engine
compartment that
> > > > will
will allow for any
movement
the pipe by the
motor.
> > > > The
go as they are 6"
but the
and that's all
that was
Bub!
engineers that
designed the
> > > > Bird,
7 way trailer
plug, Air
and Brake peddles,
Front
> > > > Left
Vent for Slendide
2000,
The seat
seat, That reminds
me I
> > > > still
hitting a road
transition just
> > > > to
seat belts
automatically
> > > > adjust
rebounds and the
belts try to
the 95 PT 42.
I'm not
> > > > > > bitchin! I'm fixin
> > > > > > Kurt Horvath
> > > > > > 95 PT 42
> > > > > > 10AC
David Brady
> > > > > > wrote:
> > > > > > > Kurt,
bunch
> > > > building
have. Initially I'd
scratch my
support pieces, but
when
as a bus must twist
and flex,
> > > > stronger
someplace else.
honda v-tech motor
into a
the alternator
mount. The
> > > > mount
are difficult to
grasp and
track record of
building
> > > > buses
it). He's still
fighting
> > > > that
> > > > > > > mount...
> > > > > > > David Brady
> > > > > > > '02 LXi, NC
be that
> > > > it was
exhaust'
> > > > and
look at
> > > > the
> > > > > > roll
movement
> > > > to
> > > > > > twist
with the
> > > > > > > > resulting crack.
> > > > movement
someone
exhaust leak???????
you also
> > > > got
> > > > > > to
> > > > > > > > keep the stack from
with
> > > > your
> > > > > > new
variable in fuel
efficiency. even
> > > > > > straight
lower fuel economy
because the
> > > > > > intake
computer.
out-of-date.
> > > > > > > > Checked by AVG.
Release
> > > > Date:
> > > > > > 10/9/2008 12:00 AM
> > > > > > Checked by AVG.
Date:
> > > > 10/9/2008 12:00 AM
> > > > Checked by AVG.
Release
Date:
> > 10/9/2008 12:00 AM
> > Checked by AVG.
Date:
10/9/2008 12:00 AM
11-01-2008, 06:25
Post: #28
6" SS EXHAUST STACK
One pipe from the turbo then splits to two stacks.
Kurt Horvath
95 PT 42
10AC
> But doesn't the trucking industry run dual exhausts?
> David Brady
> '02 LXi, NC
to do
out
seems to
> > Pete Masterson
> > aeonix1@...
> > > <snip>
Exhaust
Engineers &
ear, and
to a
in
end, and
general
get
expense of
> > Checked by AVG.
10/9/2008 12:00 AM
11-01-2008, 06:47
Post: #29
6" SS EXHAUST STACK
I guess you could or go to a large 8" single , bit the chrome shops
sell them for outrageous prices---$692.00
http://www.iowa80.com/DirectionsWEB/webc...splay.php?
itemid=74151
Kurt Horvath
95 PT 42
10AC
> Now we're talking. Can you fit two stacks back there? I'm
> serious. This will be an improvement in performance. Two stacks
> will dramatically reduce backpressure, which will result in
> lower turbo pyrometer temps, and will allow more boost and
> more power. A single 5 inch, as compared to the stock 6"
> will do the reverse.
> David
> '02 LXi, NC
> > Kurt Horvath
> > 95 PT 42
> > 10AC
> > , David Brady
> > > David Brady
> > > '02 LXi, NC
I
> > to do
turbo to
blown
> > out
> > seems to
> > > > Pete Masterson
> > > > aeonix1@
> > > > > <snip>
Custom
> > Exhaust
> > Engineers &
> > ear, and
respect
> > to a
surprise
> > in
muffler.
> > end, and
> > general
won't
> > get
> > expense of
> > > > Checked by AVG.
Date:
> > 10/9/2008 12:00 AM
> > Checked by AVG.
10/9/2008 12:00 AM
11-01-2008, 06:50
Post: #30
6" SS EXHAUST STACK
David Brady
'02 LXi, NC
do
"aeonix1%40mac.com"
> <snip>
Exhaust
general
