87 FC RADIATOR
10-22-2008, 07:43
87 FC RADIATOR
Does anyonr know the best place to buy and ball park cost?
TKS Bob in KY
10-22-2008, 09:13
87 FC RADIATOR
I built a radiator tanks included(steel) 2 years ago it was about
1100.00 If you want I scare the current prices
Stephen 77FC35
dupreeproducts.com
> TKS Bob in KY
11-09-2008, 00:04
87 FC RADIATOR
Does anyone know on a 87 swing radiator the hose numbers ? On mine I
have to disconnect to swing oprn. This is not right is it?
Bob Malonry
87 FC 35 in KY
11-09-2008, 00:09
87 FC RADIATOR
Good morning Bob:
You should be able to swing the rad open with hoses connected. The numbers
should be on the build sheet in your blue box. The only thing that may need
disconnecting would be the alarm stat wire going to the sensor.
Safe travels,
84FC35 "Ruff Diamond"
Duncan, Oklahoma
Bob Malonry
87 FC 35 in KY
11-09-2008, 02:31
87 FC RADIATOR
Hi Bob,
Good to hear from you, I wrote up a procedure several years ago.
It is located in the files of one of the other forums.
http://f1.grp.yahoofs.com/v1/4OwWSaZxA88...PiETtcSIA-
SLzQkltJ_ulR9v545C0J86CIDzohIfix0Tps60Ikp-VdNiKo46T7EkSivV7G/Swing%
20Radiator%2087%2C%2088%2C%2089FC
You will need to cut and paste this link.
The 87,88,89 FC's has an air cooler and it is not as easy as the
older FC's to open and swing the radiator.
Bill 88 FC Michigan
> Good morning Bob:
numbers
may need
> Safe travels,
> Duncan, Oklahoma
I
> Bob Malonry
> 87 FC 35 in KY
