Losing coolant
10-23-2008, 03:26
Losing coolant
I've never had much coolant loss (except when dealing with replacing gate
valves), so I tend to check rather sporadically. A couple of days ago I checked
and it was not visible in the sight glass. Took roughly one gallon to bring it
back to the top of the glass.
This was approximately 480 miles since the last check (three separate runs with
several days between each).
I checked about 40 miles later (hot) and it was full. Checked it just now, cold,
and it was not visible. Took a bit over a quart to bring it to the top. This was
about 110 miles since the previous fill.
My oil usage appears about normal, 5 quarts on this trip over 4300 miles. I
would expect less if it was going into the oil (unless it boils off??)
I'm parked on clean concrete, and there are no signs of any fluids underneath
(It's been cool enough that the air conditioner has not been used, so not even
condensate).
Any thoughts on what to look at/for?
Don Bradner
90 PT40 "Blue Thunder"
Posting today by satellite from Hilton Head, South Carolina
10-23-2008, 05:02
Losing coolant
Since I got my radiator re-cored (I won't count the coolant loss
before the radiator was working properly), I've had long periods
where the coolant seems to be in the glass each time I check -- and I
check each time I'm getting ready to leave a location. Other times,
I've found the coolant level below the glass -- and I've needed to
put in a few ounces to as much as a half-gallon.
I can't explain why theses periods of "usage" occur when compared to
times when the coolant level is stable.
My only suggestions: make sure the cap is on correctly. I find that
my coolant cap is difficult to turn to "the last click" and I may
have left it slightly loose. Also be sure that the cap is holding the
(rather low) pressure. Over time, the spring-valve in the cap can
weaken. If I recall correctly the cap is 7 psi rated -- so check to
see that you have the correct cap.
Beyond that, if there are no symptoms of leakage or other ways that
coolant is being lost, it may just be one of those mysteries ...
aeonix1@...
On the road at Edinburg, VA
> replacing gate valves), so I tend to check rather sporadically. A
> couple of days ago I checked and it was not visible in the sight
> glass. Took roughly one gallon to bring it back to the top of the
> glass.
> separate runs with several days between each).
> just now, cold, and it was not visible. Took a bit over a quart to
> bring it to the top. This was about 110 miles since the previous fill.
> miles. I would expect less if it was going into the oil (unless it
> boils off??)
> underneath (It's been cool enough that the air conditioner has not
> been used, so not even condensate).
> Don Bradner
10-23-2008, 05:14
Losing coolant
Don, you mentioned you changed the gate valves, for the heater system I presume. It probably is an air pocket that got worked through if no evidence in the engine oil or ground.You might check the tranny since it's oil is water cooled. I say that because after I changed my main engine water pump I had to add fluid a couple of times. It finally stabilized and have not added fluid since.
Leroy Eckert
1990 WB-40 Smoke N Mirrors
Dahlonega, GA
--- On Thu, 10/23/08, Don Bradner wrote:
From: Don Bradner Subject: [WanderlodgeForum] Losing coolant
Date: Thursday, October 23, 2008, 11:26 AM
I've never had much coolant loss (except when dealing with replacing gate valves), so I tend to check rather sporadically. A couple of days ago I checked and it was not visible in the sight glass. Took roughly one gallon to bring it back to the top of the glass.
This was approximately 480 miles since the last check (three separate runs with several days between each).
I checked about 40 miles later (hot) and it was full. Checked it just now, cold, and it was not visible. Took a bit over a quart to bring it to the top. This was about 110 miles since the previous fill.
My oil usage appears about normal, 5 quarts on this trip over 4300 miles. I would expect less if it was going into the oil (unless it boils off??)
I'm parked on clean concrete, and there are no signs of any fluids underneath (It's been cool enough that the air conditioner has not been used, so not even condensate).
Don Bradner
My location: http://www.bbirdmaps. com/user2. cfm?user= 1
10-23-2008, 05:29
Losing coolant
Don,
Does your toad show any signs of splash? Go to Autozone and rent
a radiator pressurizer. Pump her up to the pressure designated on your
radiator cap, and check all the hoses/fittings for leaks. Probably just
a loose hose clamp
David Brady
'02 LXi, NC
boils off??)
Don Bradner
My location: www.bbirdmaps.com/user2.cfm?user=1
Internal Virus Database is out-of-date.
Checked by AVG. Version: 7.5.405 / Virus Database: 270.8.0/1715 - Release Date: 10/9/2008 12:00 AM
10-23-2008, 06:09
Losing coolant
Don, to get peace of minde it would help to do an oil anlalsis on
what is in the oil pan now. once again I am not for oil analysis and
what would you do if it showed glycol in the pan anyway? if you wash
the puke tank and wrap the rad cap with toil paper prior to a run,
you would get an idea if it is puking and then there is a pressure
issue???? I had a hose leak on a truck that would only piss when it
got to 175 dertrr and it would hit the exhaust so the only sign I
had was the sweet smell of glycol. check up around the starter for
signs of the compressor lines or such. I hope it is no issue and
only the $23,000 fear we all have.
Greg94ptCa
glass.
fill.
boils off??)
> Don Bradner
10-23-2008, 06:38
Losing coolant
I've had 2 instances where I've mysteriously lost a quart or so
of coolant, both times the loss was traced to a leaky hose via
a loose hose clamp. I tightened the clamp a bit (don't overtighten)
and the coolant level has been rock steady. If you find yourself
having to add coolant, then you have a leak. If you've done coolant
system work in the very recent past, then there could be a pocket
of air that's being worked out. I've just finished a 7000 mile trip
with zero coolant consumption. The 7 psi cap raises the boiling point
by 21 deg F (3 deg per 1 psi I believe). If you have a leak then the
system won't reach spec pressure and you'll boil at a correspondingly
lower temperature. As part of our yearly maintenance we should all
rent/buy a radiator pressure tester and do a leak down on the cooling
system. You may be surprised what you find.
David Brady
'02 LXi, NC
David Brady wrote:
Don,
a loose hose clamp
David Brady
'02 LXi, NC
boils off??)
Don Bradner
10-23-2008, 07:17
Losing coolant
David, I show no sign of splash, but the rate of leak is slow enough, and the
rear mudflap solid enough, that it doesn't rule out leak. At the stop where I
checked the level hot I also looked underneath for any sign of loss (engine was
running) and there was none. Even so, I think your idea of getting a pressurizer
for testing is the best plan moving forward.
My cap is a 13-lb cap, and is secure. I agree that last click is hard - takes
two hands for me.
It has been driven 6000 miles since the upper gate valves were replaced. There
was about 1 gallon replaced in the first hundred miles or so. Heater has been
used multiple times.
Transmission fluid level is normal/slightly low, and is clear. I would not
expect either if it had 5 quarts of coolant in it.
On 10/23/2008 at 12:29 PM David Brady wrote:
>Don,
>a loose hose clamp
>David Brady
>'02 LXi, NC
>> boils off??)
>> Don Bradner
>> Checked by AVG.
>10/9/2008 12:00 AM
10-23-2008, 07:26
Losing coolant
Don,
You could get a gallon container and some how wire it so that it would collect anything from the overflow tube to see if it coming from there
Jim Riordan
88 WBWL XXV
Stuart, Fl
Don Bradner wrote:
David, I show no sign of splash, but the rate of leak is slow enough, and the rear mudflap solid enough, that it doesn't rule out leak. At the stop where I checked the level hot I also looked underneath for any sign of
loss (engine was running) and there was none. Even so, I think your idea of getting a pressurizer for testing is the best plan moving forward.
My cap is a 13-lb cap, and is secure. I agree that last click is hard - takes two hands for me.
It has been driven 6000 miles since the upper gate valves were replaced. There was about 1 gallon replaced in the first hundred miles or so. Heater has been used multiple times.
Transmission fluid level is normal/slightly low, and is clear. I would not expect either if it had 5 quarts of coolant in it.
>Don,
>a loose hose clamp
>David Brady
>'02 LXi, NC
>Don Bradner
>> boils off??)
>> Don Bradner
>> Checked by AVG.
>10/9/2008 12:00 AM
10-23-2008, 09:00
Losing coolant
That first gallon of coolant was very likely air in the system being
cleared out. It's been a couple of years, but I recall needing to top
off my coolant a several of times during the first 500 miles of
travel after my radiator was rebuilt.
I suspect that smaller 'shortages' of coolant that I've experienced
from time to time (and seemingly randomly) were due to limited
'spitting' out the overflow for reasons that may never be known.
(Perhaps a few ounces spit out due to a warmer engine than usual --
but so little that it evaporated without clear evidence left behind?
I note that I get a similar occurrence with my auto from time to
time.) If I were experiencing shortages after every trip ... then I'd
tend to suspect a loose hose clamp or minor leak somewhere in the
system.
aeonix1@...
On the road at
> underneath for any sign of loss (engine was running) and there was
>> Don,
>> your
>> just
>> a loose hose clamp
>> David Brady
>> '02 LXi, NC
>>> days
>>> roughly
>>> separate
>>> just
>>> bring it
>>> boils off??)
>>> Don Bradner
10-23-2008, 12:32
Losing coolant
Don, I would wonder why someone has put a 13 # cap on your cooling system. The standard for these engines have been 7#. I haven't heard of very many with anything above that.
Dick Hayden - '87 PT 38 - Lake Stevens, WA - still in Medford, OR but on the road again tomorrow after the tranny is fixed.
Sent: Thursday, October 23, 2008 12:17 PM
Subject: Re: [WanderlodgeForum] Losing coolant
David, I show no sign of splash, but the rate of leak is slow enough, and the rear mudflap solid enough, that it doesn't rule out leak. At the stop where I checked the level hot I also looked underneath for any sign of loss (engine was running) and there was none. Even so, I think your idea of getting a pressurizer for testing is the best plan moving forward.
>Don,
>a loose hose clamp
>David Brady
>'02 LXi, NC
>> boils off??)
>> Don Bradner
>> Checked by AVG.
>10/9/2008 12:00 AM
