engine noise
10-23-2008, 05:59
engine noise
Here is an odd question for you FC owners. I have noticed (I think)
that the engine in my bus seems to be a little louder from time to time. I've tried to see if I could determine a particular time or situation which causes this and have not been able to do so. Obviously the harder you push the engine the more sound you get. I am talking about the sound just at idle. Perhaps this is all in my head but I was riding a friend around and he noticed at one point and commented that he thought the engine sounded louder. As stated can't localize to conditions.His comment prompted me to ask if other have experience this. John Heckman central Pa 1973 FC with 3208 NA Cat |
10-23-2008, 06:04
engine noise
When I had the FC and heard that noise the first time I was baffled. Very soon I realized that it was the radiator fan cycling, even at idle.
10-23-2008, 06:07
engine noise
John just a guess but would the increased sound coincide with the fan cycling on and off?
2008/10/23 bubblerboy64 <"jehdds@hotmail.com">
-- Rob, Sue & Merlin Robinson 94 WLWB |
10-23-2008, 06:30
engine noise
Well, I have never noticed the fan cycling on and off and to be
honest with you I didn't know that it did. Hummmm. Learning all the time. The engine just sounds louder at times. John Heckman central Pa 1973 FC with 3208 NA > > John just a guess but would the increased sound coincide with the fan > cycling on and off? > > 2008/10/23 bubblerboy64 > > > Here is an odd question for you FC owners. I have noticed (I think) > > that the engine in my bus seems to be a little louder from time to > > time. I've tried to see if I could determine a particular time or > > situation which causes this and have not been able to do so. Obviously > > the harder you push the engine the more sound you get. I am talking > > about the sound just at idle. Perhaps this is all in my head but I was > > riding a friend around and he noticed at one point and commented that > > he thought the engine sounded louder. As stated can't localize to > > conditions.His comment prompted me to ask if other have experience > > this. > > > > John Heckman > > central Pa > > 1973 FC with 3208 NA Cat > > > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > |
10-23-2008, 07:22
engine noise
John, turn on the fan override switch, see if tha is the sound. I am always happy when my engine makes a sound! so much better than it not making a sound! Jim Riordan 88 WBWL XXV Stuart, Fl bubblerboy64
10-23-2008, 08:02
engine noise
If there is a fan overide switch that would be news to me. Remember
this old girl was a gasser and converted to 3208 NA. Maybe it doesn't have a fan clutch? I'll have to check into this. The bus never seems to run hot and so I don't know if the fan has ever come on, or it may cycle and I don't hear it? Like I said,learning all the time. John Heckman central pa 1973 FC 3208 Cat > > John, > > turn on the fan override switch, see if tha is the sound. > > I am always happy when my engine makes a sound! so much better than it not making a sound! > > Jim Riordan > 88 WBWL XXV > Stuart, Fl > > bubblerboy64 > Here is an odd question for you FC owners. I have noticed (I think) > that the engine in my bus seems to be a little louder from time to > time. I've tried to see if I could determine a particular time or > situation which causes this and have not been able to do so. Obviously > the harder you push the engine the more sound you get. I am talking > about the sound just at idle. Perhaps this is all in my head but I was > riding a friend around and he noticed at one point and commented that > he thought the engine sounded louder. As stated can't localize to > conditions.His comment prompted me to ask if other have experience > this. > > John Heckman > central Pa > 1973 FC with 3208 NA Cat > |
10-23-2008, 09:04
engine noise
John,
Is it possible that your hearing when the compressor is actually pumping or not? Just a thought. Tom Sorrentino 1987 PT38 Bedford Hills, NY --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" wrote: > > Here is an odd question for you FC owners. I have noticed (I think) > that the engine in my bus seems to be a little louder from time to > time. I've tried to see if I could determine a particular time or > situation which causes this and have not been able to do so. Obviously > the harder you push the engine the more sound you get. I am talking > about the sound just at idle. Perhaps this is all in my head but I was > riding a friend around and he noticed at one point and commented that > he thought the engine sounded louder. As stated can't localize to > conditions.His comment prompted me to ask if other have experience > this. > > John Heckman > central Pa > 1973 FC with 3208 NA Cat > |
10-23-2008, 10:22
engine noise
It may have a viscous type fan no fan override no switch
it still cycles when the temp increases the fan engages or locks up stephen 77fc35 dupreeproducts.com --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" wrote: > > If there is a fan overide switch that would be news to me. Remember > this old girl was a gasser and converted to 3208 NA. Maybe it > doesn't have a fan clutch? I'll have to check into this. The bus > never seems to run hot and so I don't know if the fan has ever come > on, or it may cycle and I don't hear it? Like I said,learning all > the time. > John Heckman > central pa > 1973 FC 3208 Cat > > > > John, > > > > turn on the fan override switch, see if tha is the sound. > > > > I am always happy when my engine makes a sound! so much better > than it not making a sound! > > > > Jim Riordan > > 88 WBWL XXV > > Stuart, Fl > > > > bubblerboy64 > > Here is an odd question for you FC owners. I have noticed > (I think) > > that the engine in my bus seems to be a little louder from time to > > time. I've tried to see if I could determine a particular time or > > situation which causes this and have not been able to do so. > Obviously > > the harder you push the engine the more sound you get. I am talking > > about the sound just at idle. Perhaps this is all in my head but I > was > > riding a friend around and he noticed at one point and commented > that > > he thought the engine sounded louder. As stated can't localize to > > conditions.His comment prompted me to ask if other have experience > > this. > > > > John Heckman > > central Pa > > 1973 FC with 3208 NA Cat > > > |
