strange odor
10-23-2008, 07:12
strange odor
Folks,
After a long drive (500 miles) I detect an electrical odor from
the bedroom area of the bus. It smells like an overheated
transistor, but I can't identify it's origin. Everything seems to
be operating normally, no leaks, smoke, or overheating. The
inverters are at normal temp, the alternator is normal, nothing
is overly hot. Any ideas?
Thanks,
David Brady
'02 LXi, NC
10-23-2008, 08:52
strange odor
From time to time, I encounter that "electrical smell" in one part
or another of the coach. There are electrical distribution panels
(12vdc) above the windshield and in the rear closet (as well as below
the driver's window on newer coaches or across the front of the coach
on the wide body models).
Several times, when I smelled "the smell" I've searched and checked
high-and-low but have not found anything clearly identifiable as the
source. (Although I note that the last electrical smell was coming
from somewhere near the inverters and one of my two is apparently no
longer inverting -- I'll find out tomorrow when I disconnect and hit
the road.)
So, I don't really have any suggestions -- and it is likely not a
good thing going on -- but it may be weeks (months or years) before
something actually occurs. Indeed, it took two years from the time
that my Kool-o-matic started having some odd symptoms until it
actually failed (and I've now clearly determined that the K-o-m motor
is dead). There wasn't (much) smell to the fan going out, if only
that any smell it generated went out the vent when the fan was
running...
I've also determined that appearances can be very misleading. For
example, in the case of the Kool-o-matic, I'd have sworn (after
inspection) that the thermostat was defective (due to a considerable
build up of 'crud' on the back side of the lower 1/3 of the circuit
board) -- but after a very thorough troubleshooting session, I proved
to my satisfaction that the thermostat works just fine, despite the
appearance.
aeonix1@...
On the road at Edinburg, VA
On Oct 23, 2008, at 3:12 PM, David Brady wrote:
> Folks,
> Thanks,
> David Brady
> '02 LXi, NC
10-23-2008, 11:39
strange odor
David
Just be certain you don't have an exhaust leak at or near the bends and swivels of your coaches exhaust system..
I have been told by a couple others that the odor from the engine room insulation will emit that electrical burning smell.
Fred & Jeanne Hulse
Morristown Arizona
1997 Wanderlodge WLWB41
10-23-2008, 11:48
strange odor
Thanks Pete,
I neglected to mention that the smell is only apparent when underway
dissipates when the coach is parked (regardless of shore power or
generator
operation).
I also noticed that my right turn signal on the toad isn't functioning,
the brake
lights on the toad do work, which tells me that it's not the bulb.
Prevost Car
told me that the trailer light module that I use is prone to meltdown
and catch
fire, so I purchased a draw-tite module for replacement. I haven't
installed it
yet. This could be the cuplrit.
David Brady
'02 LXi, NC
part
the road.)
running...
appearance.
"aeonix1%40mac.com"
> Folks,
> Thanks,
> David Brady
> '02 LXi, NC
Internal Virus Database is out-of-date.
Checked by AVG. Version: 7.5.405 / Virus Database: 270.8.0/1715 - Release Date: 10/9/2008 12:00 AM
10-23-2008, 12:48
strange odor
Thanks Fred,
That's good information. I'll take a second look at the exhaust system
for leaks and at the insulation for signs of burning.
David Brady
'02 LXi, NC
Fred Hulse wrote:
David
system..
burning smell.
Fred & Jeanne Hulse
Morristown Arizona
10-24-2008, 06:51
strange odor
That's a real possibility. I've had the diode for the right turn
signal on my toad apparently 'die' and I need to get another one to
replace it. It seems that these components are made particularly
cheaply -- which means they don't work very well or for very long.
aeonix1@...
On the road at Max Meadows, VA
On Oct 23, 2008, at 7:48 PM, David Brady wrote:
> Thanks Pete,
> underway and
> generator
> operation).
> functioning, the brake
> Prevost Car
> meltdown and catch
> installed it
> David Brady
> '02 LXi, NC
>> the road.)
>> running...
>> appearance.
>> Pete Masterson
>> aeonix1@...
>> > Folks,
>> > Thanks,
>> > David Brady
>> > '02 LXi, NC
>> Internal Virus Database is out-of-date. Checked by AVG. Version:
>> 12:00 AM
