High beams on dim
11-10-2008, 12:13
High beams on dim
Hi group,
Has anybody had this problem? Turn on headlights and low beams come on ok, but high beams also come on very faintly. So far have had replaced dimmer switch, headlight switch, all 4 headlights but no go. If take the low beams out, the high beam goes off..plug in low beam and high comes back on. This holds true for both sides. Any thoughts? Bob Lawrence 84 PT 36 On the road fulltiming |
11-10-2008, 12:28
High beams on dim
Ground.
Regards, Bruce Morris in Raleigh, NC
Webmaster - Wanderlodge Owners Online Vietnam Vet 1966-67 Navy "Doc" 3rd MarDiv 1983 FC35RB FMCA #7142s
11-10-2008, 12:30
High beams on dim
--- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence"
Have your headlights been rewired thought a relay?If not it may be time to do so. Bob Loomas 1985 PT 36 > > Hi group, > Has anybody had this problem? > Turn on headlights and low beams come on ok, but high beams also come > on very faintly. > So far have had replaced dimmer switch, headlight switch, all 4 > headlights but no go. > If take the low beams out, the high beam goes off..plug in low beam and > high comes back on. This holds true for both sides. > Any thoughts? > > Bob Lawrence > 84 PT 36 > On the road fulltiming > |
11-10-2008, 12:48
High beams on dim
Bruce,
You are absolutely correct, this is a classic bad ground symptom. Gardner 83FC35 --- In WanderlodgeForum@yahoogroups.com, "Bruce Morris" <bamnc@...> wrote: > > Ground. > > Regards, Bruce Morris in Raleigh, NC > Webmaster - Wanderlodge Owners Online > Vietnam Vet 1966-67 Navy "Doc" 3rd MarDiv > 1983 FC35RB FMCA #7142s > > ----- Original Message ----- > From: Bob Lawrence > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, November 10, 2008 7:13 PM > Subject: [WanderlodgeForum] High beams on dim > > > Hi group, > Has anybody had this problem? > Turn on headlights and low beams come on ok, but high beams also come > on very faintly. > So far have had replaced dimmer switch, headlight switch, all 4 > headlights but no go. > If take the low beams out, the high beam goes off..plug in low beam and > high comes back on. This holds true for both sides. > Any thoughts? > > Bob Lawrence > 84 PT 36 > On the road fulltiming > |
11-11-2008, 14:36
High beams on dim
Well, got the high beam on dim problem fixed by Ralph here in Duncan,
Ok. Turns out a previous owner had made the headlight mod ok, but swapped wires (high to low) on one side and swapped them wrong on the other side. Also a ground wire wasn't that well grounded. This problem has been on the bird for about 9 years before it got fixed today. Kudos to Ralph for finding this problem. This guy can find ANY electric problem. Bob Lawrence 84 PT 36 Duncan, Ok > Bruce, > You are absolutely correct, this is a classic bad ground symptom. > Gardner > 83FC35 |
11-11-2008, 16:44
High beams on dim
Bob,
Thank you for the update. Glad it's fixed. On Tue, Nov 11, 2008 at 6:36 PM, Bob Lawrence <"bobandarlene@earthlink.net"> wrote:
