Bizarre - Masters degree credit available for alternator cha...
11-14-2008, 14:28
I doubt if there are many bird owners that don't believe theirs has
a "soul" but I find this really spooky.
THE VERY NEXT TIME I started "Gerald" after making the original post,
the alternator showed charge WITHOUT the throttle rev.
Two times now !!!
WHHHOOOOOOOOOWWWWW, and it isn't even Halloween,
GPSGary
11-14-2008, 14:40
Oh, on the contrary... Soul is what Wanderlodge ownership is
all about!
David Brady
'02 LXi, NC
has
Two times now !!!
GPSGary
Checked by AVG. Version: 7.5.549 / Virus Database: 270.9.3/1786 - Release Date: 11/13/2008 6:01 PM
11-14-2008, 15:17
David,
Since I don't have an advanced degree, can you answer a question for me?
What's the difference between the "engine pre-heat" switch over the driver's head and the lighted pre-heat switch in front of the sink? It's cold here in Texas tonight. I have Aqua-Hot on but I don't plan to run the Webasto.
Brad
Brad Barton 00LXiDFW bbartonwx@...
Date: Fri, 14 Nov 2008 21:40:48 -0500
Subject: Re: [WanderlodgeForum] Bizarre - Masters degree credit available for alternator cha...
all about!
David Brady
'02 LXi, NC
Two times now !!!
GPSGary
Stay up to date on your PC, the Web, and your mobile phone with Windows Live Click here
11-14-2008, 15:32
Hi Brad,
No advanced degree required. The switch above the pilot seat turns on
the engine Aqua-hot preheat pump (requires that the Aqua-hot be
running, electric or diesel), and the switch by the sink is for the
electric heat element screwed directly into the S-60 block, this heat
is only available with shore power. Stay warm down there; hey, what am
I talking about, we're currently in frigid North Carolina!
David Brady
'02 LXi, NC
--- In WanderlodgeForum@yahoogroups.com, brad barton <bbartonwx@...>
> David,
me?
to run the Webasto.
> BradBrad Barton 00LXiDFW bbartonwx@...
> To: WanderlodgeForum@...: dmb993@...: Fri, 14 Nov 2008 21:40:48
-0500Subject: Re: [WanderlodgeForum] Bizarre - Masters degree credit
> Oh, on the contrary... Soul is what Wanderlodge ownership isall
a "soul" but I find this really spooky.THE VERY NEXT TIME I started
"Gerald" after making the original post, the alternator showed charge
WITHOUT the throttle rev.Two times now !!!WHHHOOOOOOOOOWWWWW, and it
isn't even Halloween,GPSGary
> Checked by AVG.
11/13/2008 6:01 PM
> _________________________________________________________________
Windows Live
> http://clk.atdmt.com/MRT/go/119462413/direct/01/
11-14-2008, 15:39
I suppose I could run the Aqua-hot all night, but not the block heater.
Date: Sat, 15 Nov 2008 03:32:27 +0000
Subject: [WanderlodgeForum] Re: Bizarre - Masters degree credit available for alternator cha...
Hi Brad,
David Brady
'02 LXi, NC
--- In "WanderlodgeForum@yahoogroups.com", brad barton <bbartonwx@.<WBR>..>
> David,
me?
to run the Webasto.
> Checked by AVG.
11/13/2008 6:01 PM
Windows Live
Get 5 GB of storage with Windows Live Hotmail. Sign up today.
11-14-2008, 16:24
Many people who live in the north never winterize there coaches;
they simply run their A-H's continuously from December to April.
David Brady
heater.
Brad Barton 00LXiDFW bbartonwx@hotmail.com
Hi Brad,
David Brady
'02 LXi, NC
brad barton <bbartonwx@.<wbr>..>
> David,
for
me?
to run the Webasto.
> BradBrad Barton 00LXiDFWbbartonwx@...
> To: WanderlodgeForum@...: "dmb993@...:" Fri, 14 Nov 2008
21:40:48
it
> Checked by AVG.
11/13/2008 6:01 PM
Windows Live
11-15-2008, 02:29
Switch on the panel over the driver's side window: "Engine Preheat"
-- this activates the AquaHot engine coolant link to warm the
coolant. You must ALSO have the "hydronic heat" switch ON (located on
the main dashboard array, upper left quadrant on my coach). This
allows the AquaHot to fire up the diesel burner. If the hydronic heat
switch is off, the 2000 watt electrical element in the AquaHot may
provide a very modest bit of heating as might be needed in cool
rather than truly cold conditions. When the AquaHot burner is
operating, it is very effective and, depending on how cold it gets,
will warm the engine for startup in 30 minutes to 2 hours.
Switch in front of the sink (usually a red, lighted switch). This is
the engine block heater. It has a heating element installed on or in
the engine that directly heats the engine block (or possibly the oil
pan). [I haven't investigated exactly where it's located or the exact
type of installation on my 'Bird.] It's much slower than the "Engine
Preheat" -- usually it's advisable to turn it on at least 12 hours
before a planned startup. It may prove insufficient in really cold
weather (in my experience) but it's better than nothing. When I use
mine, I usually turn it on around dinner time the night before a
travel day.
Note that both engine heater systems MUST be turned off when the
engine is running, as either (or worse both together) can overwhelm
the cooling system causing overheating and possible engine damage if
they remain on.
Pete Masterson
aeonix1@...
On the road at Lockhart, Texas -- where it will be cold tonight, too...
On Nov 14, 2008, at 9:17 PM, brad barton wrote:
> David,
> for me?
> Brad
11-16-2008, 16:27
Thanks Pete and David.
I thought the block heater might scorch the oil if it was left on too long. I ran the pre-heat from Aqua-Hot just on AC. It got to 40last night just outside New Braunfels. I usually hit the Webasto before the morning showers to give the hot water a boost. BTW, the Walnut Canyon RV Park on 2763 is more for fifth wheels than 43' coaches. And the bathhouse was 'prison primitive' with the rope-activated spring-loaded non-adjustable temperature shower. And the well water smelled of sulphur. Nice folks but not the park for us.
Date: Sat, 15 Nov 2008 08:29:39 -0600
travel day.
they remain on.
Pete Masterson
"aeonix1@mac.com"
> David,
> for me?
> Brad
> Brad Barton 00LXiDFW "bbartonwx@hotmail.com"
11-17-2008, 07:38
Brad, I did not remember this park as being a part of the Texas State
Park System and a quick check confirms that it is not. There is a very recent "Campers Guide to Texas parks, lakes, and forest" by Mickey Little. The book is very complete and can be ordered from Amazon. I have been in four Texas State parks within the last month and my only problem is that you had to watch the overhead limbs. Also, cudos to Oklahoma state parks; the ones I have seen are exceellent.
Wallace Craig
95 WLWB 42
Azle, Texas
--- On Sun, 11/16/08, brad barton <bbartonwx@...> wrote:
Subject: RE: [WanderlodgeForum] Bizarre - Masters degree credit available for alternator cha...
To: wanderlodgeforum@yahoogroups.com
Date: Sunday, November 16, 2008, 10:27 PM
travel day.
they remain on.
Pete Masterson
"aeonix1@mac.com"
> David,
> Since I don't have
> for me?
> Brad
11-17-2008, 11:39
Thanks, Wallace.
We don't get out much but once we do, your idea sounds like the only way to go.
Date: Mon, 17 Nov 2008 11:38:41 -0800
Wallace Craig
95 WLWB 42
Azle, Texas
travel day.
they remain on.
Pete Masterson
"aeonix1@mac.com"
> David,
> for me?
> Brad
Windows Live Hotmail now works up to 70% faster. Sign up today.
