Low Beam Headlight Switch
11-15-2008, 12:42
When I turn my low beam headlights on sometimes they won't come on.
The high beams will work. I put a new switch in & thought that corrected the problem. The only thing that seems to work is to wiggle the cannon plug then it will work for a while & then it will not work & this is when he bus has not been moved. The plug is P20. I was wandering if any one has a drawing to tell what the # of that wire is from the low beam head light switch or how would be a good way to find the bad wire? Don Spithaler 89 SP 36' Butler, PA |
11-15-2008, 13:06
Don:
The low beams are a green wire marked 0 and the high beams are red wire marked 0. The head light switch supplies power to the dimmer switch and from the dimmer switch the high or low beams are selected, not the dash head light switch. If you have the head light mod then the dimmer switch selects the coil of the high or low beam turning them on or off and power to the head lights is straight from the battery through a 30 am cb. I would start at the dimmer switch. Safe travels, Ralph and Charolette Fullenwider 84FC35 "Ruff Diamond" Duncan, Oklahoma At 12:42 AM 11/16/2008 +0000, you wrote: >When I turn my low beam headlights on sometimes they won't come on. >The high beams will work. I put a new switch in & thought that >corrected the problem. The only thing that seems to work is to wiggle >the cannon plug then it will work for a while & then it will not work >& this is when he bus has not been moved. The plug is P20. I was >wandering if any one has a drawing to tell what the # of that wire is >from the low beam head light switch or how would be a good way to find >the bad wire? >Don Spithaler >89 SP 36' >Butler, PA > |
11-15-2008, 13:34
Ralph
I just thought about it & I said that wrong . It is the parking lights that is giving me the trouble. Not the low & high beams. Sorry about the confusion. Don Spithaler' 89 SP 36' Butler, PA On Sat, Nov 15, 2008 at 8:06 PM, Ralph L. Fullenwider <"rlf47@swbell.net"> wrote:
