Starter on 89WB
12-08-2008, 12:08
Starter on 89WB
Hi, all Richard here from Decatur Il. Was on a small trip after new
tire, new oil, things checked out underneath, got to Missouir an turned
coach off, wouldn't start again. The ignition switch would turn on
Acc. but as I turn it to the start, nothing. This happen to me before
an turning the key back an froth a few times an the ignition would
catch an start, not this time, haad to jump across the starter on the
engine, it started right up.Took the ignition out the keys works loose
in it, so thinking it this ignition switch, can't find one it is --
Pollak-31-158-100, can't tell you if its the original switch, I would
say no. Any ideas?
12-08-2008, 12:56
Starter on 89WB
Does it have a rear start station, My '85 does.
Art Weatherly
Riverside Ca
'85 PT36
-- In WanderlodgeForum@yahoogroups.com, "dctrcarter"
turned
loose
> say no. Any ideas?
12-08-2008, 13:47
Starter on 89WB
A good Napa will have a book where you can see pics of the ignition
saddle. I was 'unable' to match up one on my 94. I found an
international harverster unit that was close enough to keep as a
back up and just cleaned up the one I intended to replace. turned
out the ign swith was not the problem anyway. LeroyE posted that he
has issues such as you describe and must go to the rear ignition
location and switch the selector back and forth??
If the 89 is as the 94 circuits are, keep in mind The key cues a
relay which sends fused 12V to the big starter solenoid. If the
fused relay has a self resetting fuse (silver box) that could be the
intermiting prob. as some fuses are used for several functions. it
could also be a ground to that relay.
If you have an early Ddec computer you may want to be careful
jumping the starter. I burnt up a N14Cumins computer doing the same.
turns out to be common to blow them with bad starters, bad rebuild
starters, jumpstarting and solenoid starting.
GregoryO'Connor ofTim&Greg
94ptCa
. --- In WanderlodgeForum@yahoogroups.com, "dctrcarter"
new
turned
on
before
loose
would
> say no. Any ideas?
12-09-2008, 13:28
Starter on 89WB
he
same.
> 94ptCa
> new
> turned
> on
> before
would
> the
> loose
> would
> > say no. Any ideas?
>Thanks for the infor. looking for a scheme of the starter system,
I'm looking for the back relay, is it by the auto. grease box?, any
help wanted
12-09-2008, 13:31
Starter on 89WB
--- In WanderlodgeForum@yahoogroups.com, "amweath"
> Art Weatherly
> Riverside Ca
> '85 PT36
new
> turned
on
before
would
> loose
would
> > say no. Any ideas?
>I believe it has one , I'm looking for it
12-09-2008, 16:25
Starter on 89WB
> -I believe it has one , the drawing I have shows one, the problem
is I don't know what to look for, I know I have looked right at it, I
think it's the box in rear , has a like a four poisition switch on it
with a key hole?
> Art Weatherly
> Riverside Ca
> '85 PT36
new
> turned
on
before
would
> loose
would
> > say no. Any ideas?
12-10-2008, 12:28
Starter on 89WB
I
it
> with a key hole?
> > Art Weatherly
> > Riverside Ca
> > '85 PT36
> > Found it today started right up, I was looking at it all the time
Thanks for the reply
after
> new
an
> > turned
turn
> on
> before
> would
on
> the
works
> > loose
is -
> would
> > > say no. Any ideas?
