Camloc fasteners
12-18-2008, 06:14
Camloc fasteners
Greetings to all. I would like to replace the I’m hoping to stay away from aviation sources because they Thank you. Gus Rodriguez 89pt40 8v92 Pearland, Tx |
12-18-2008, 07:32
Camloc fasteners
Aircraft Spruce <http://www.aircraftspruce.com> sells Camloc fasteners like those used on the front panel. There's a number (you'll need a magnifying glass) on the head of the fastener that tells you the size -- but check against the measurements as the number is very hard to read (at least it was on my fasteners).
You need a special tool to install them -- but if you're clever and have 3 hands you can do it without the tool. (I was only replacing one that I had broken, so I didn't get the tool.) If you wish to replace more than one or two, the tool is well worth having. I don't recall the camlocs as being all that expensive. I bought 2 or 3 "just in case" because the shipping was more than the fastener. Not _all_ aircraft parts are expensive.
Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 (For Sale) El Sobrante CA "aeonix1@mac.com" On Dec 18, 2008, at 10:14 AM, Gus wrote:
12-18-2008, 16:59
Camloc fasteners
If I remember correctly /steve //birtles might be able to help you "cape0001@hotmail.com" jim riordan Gus
12-20-2008, 13:27
Camloc fasteners
--- In WanderlodgeForum@yahoogroups.com, jim riordan
wrote: > > If I remember correctly /steve //birtles might be able to help you cape0001@... > > jim riordan > > Gus > Greetings to all. I would like to replace the fasteners that hold the electrical panel outside the front of the bus. Does anyone have any sources for these. Also, If you have the size of the fastener it would be very helpful. > I'm hoping to stay away from aviation sources because they can get costly for "screws" > Thank you. > > Gus Rodriguez > 89pt40 8v92 > Pearland, Tx > Gus If you have an aircraft supply place in your area they can lead you to where you can buy camloc fasteners. Comlocs are used extensively in aircrafts. I am sorry I cannot get that info from where we are. I will have to Wait till Monday to get you a company name that can help you with size. I recommend using stainless steel that would eliminate the rust problems. Hisham and Sue Amaral 97 WLWB 43' Titusville FL. dukeflyer@... |
12-28-2008, 13:57
Camloc fasteners
Thanks to all for your input on the Camloc fasteners. I Gus Rodriguez 89pt40 8v92 Pearland, Texas From: --- In "WanderlodgeForum%40yahoogroups.com", jim riordan wrote: > > If I remember correctly /steve //birtles might be able to help you cape0001@... > > jim riordan > > Gus > Greetings to all. I would like to replace the fasteners that hold the electrical panel outside the front of the bus. Does anyone have any sources for these. Also, If you have the size of the fastener it would be very helpful. > I'm hoping to stay away from aviation sources because they can get costly for "screws" > Thank you. > > Gus Rodriguez > 89pt40 8v92 > Pearland, Tx > Gus If you have an aircraft supply place in your area they can lead you to where you can buy camloc fasteners. Comlocs are used extensively in aircrafts. I am sorry I cannot get that info from where we are. I will have to Wait till Monday to get you a company name that can help you with size. I recommend using stainless steel that would eliminate the rust problems. Hisham and Sue Amaral 97 WLWB 43' Titusville FL. "dukeflyer%40sbcglobal.net" |
