Just got my radiator back in
12-22-2008, 14:04
Hi group,
Just got done staying on a ranch in Mathis, Texas. I had an excellent
mechanic, Richard who pulled the radiator and replaced ALL the hoses in
the engine compartment. Had the radiator serviced while it was out also.
He has worked with hydralics and engines for 40 years and is excellent
at what he does. He isn't good with electrics tho.
His name is Richard Scott and his phone number is 361-290-5882.
Best part is his hourly rate is $35.00. Beat that!
Bob Lawrence
84 PT36
Mathis, Texas (Leaving for Rockport, Texas for Christmas)
12-22-2008, 15:46
That's great Bob. Glad you got the work done and at such a good rate.
--- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence"
> Hi group,
> Bob Lawrence
> 84 PT36
12-23-2008, 00:44
12-23-2008, 00:46
Bob, did you get your oil hoses replaced, also. Ernie 83PT40 in Texas
-----Original Message-----
Sent: Mon, 22 Dec 2008 8:04 pm
Subject: [WanderlodgeForum] Just got my radiator back in
Hi group,
Bob Lawrence
84 PT36
12-23-2008, 02:23
Hi Ernie,
He replaced ALL the hoses in the compartment. Total of 11 hoses. Have a
couple of pics with the radiator out. Seems one of them right behind
the rad is next to impossible to remove with out taking out the rad.
Bob Lawrence
84 PT36
Mathis, Tx (with engine running 10 degrees cooler)
12-23-2008, 04:10
Bob, did you need a new radiator or was it rodded. I notice a big diff of opinions between radiator shops on trashing a core over rodding one. Sounds like you found the guy for members to make the trip to perform this dirty dreaded maintenance task. I rod our trucks every several years.
I dropped our 94pt radiator and sent it for rodding.At 90% plugged, one shop said it was trash($3,800) and one other was able to clean it up($700). The 94pt has a three piece radiator; top tank , bottom tank and core. on many cars and light trucks the tanks are soldered on. Heavy trucks and bus apps the tanks are stainless steel bolted-on with cork gaskets.
Rodding is a process where a service shop takes one tank ($500) or tanks ($700) off and inserts flat strap rod pipe cleaners thru the several hundreds of journals running thru the center core.
You can see the foil fins that are solderd (attached?) to the outside of these journals. The exterior fins should be first inspected to see if they are screwed. often hidden deep in the exterior core ,you may find a spot or two of degraded foil finns. often the result of; some caustic cleaner, fluid or overpressurized cleaning or build up of road salt. the union of the foil finn and journal pipe is where leaks develop. if too much of the foil is off the journal pipe when fluid passes that pipe will stay hot as the foil heatsink is detached, heat will not disipate. This is not a prob on better built cores because the journals are of a thicker wall and the temps will not melt them.
There is a small hose that runs from radiator top to the expansion tank where we put rad fluid. I assumed it was a equalizerline between that FillTank/ExpansionTank pressure cap and the radiator when I assumed FillTank to be a PukeTank. it turns out that the line is prob a secondary air vent to the Expansion/Fill tank?????? in any event that thin line is full or like pressure and become a more vaunerable link than just a puke connection line. If you use a overbuilt rubber line for replacement it may be hard to clamp a perfect seal on the thin ID.
GregoryO'Connor of Tim&Greg 94ptca
12-31-2008, 09:26
Thanks for the reply, Tim.
I will pas this info on to Powell.
My rad was in good condition and just needing rodding and new
gaskets. Cost was $300.
Richard, who did the dirty deed of removing the rad and all the hoses
was great! Having worked with these engines and all hydraulics for 40
years, there isn't much he hasn't seen.
Bob Lawrence
84 PT36
Padre Island, Texas
diff
one.
perform
> years.
<http://autos.groups.yahoo.com/group/Wand...sage/36506>
94pt has
cars
apps
> Rodding <http://www.sancarlosradiator.com/images/rodout30.jpg> is
a
off
of
outside of
if
find
caustic
salt. the
too
disipate.
of a
between
assumed
that
line for
