Practical troubleshooting your RV, 101 #1
12-24-2008, 08:50
Hello everyone;
Electrical systems in any venue, to many, is confusing and it does not have
to be. With just a few simple rules, one can do a systems check no matter
if it is a 12vdc/24vdc or an 110vac system.
The words, what? where?, how? and why? come to mind as the very basic start
to finding a problem with systematic troubleshooting.
What? equates to, What is the real problem? (does not mean what the problem
appears to be.)
Where? equates to the physical location of items along a "path" in a given
system.
How? equates to how does it or is supposed to work?
Why? (remember when Dad used to say "there is no such word as why." The why
equates to why did it happen in the first place.
It is important to try to learn how a system is designed to work or the
right way to say this is "know the sequence of operation." If you know how
it is supposed to work then you are ready to start trying to; "recognize"
"localize" and "isolate" a problem.
Ok lets pick a simple system; 12vdc fan. Problem, fan does not run. Ok so
now we know it is a fan not coming on, so the problem is "recognized." So
what do we really know about "where it is." A switch on a dash, the fan is
located behind a panel near the co pilots feet, but is there more in that
system besides a switch and fan motor? Could there be a "relay" in line
between the switch and fan? Could there be a circuit breaker or fuse,
between the switch and fan motor? All are valid questions and can be
answered with a "sequence" of operation.
"Sequence" of operation for the system above; 1.it is a 12vdc system so
from the system circuit breaker, 12vdc is supplied to a switch and from the
switch to the coil of a 12vdc relay then 12vdc passes through the contacts
of the relay to the fan motor and the fan motor runs.
Now we know the "how" it works, we can start to "localize" the problem.
Starting at the circuit break we are going to check for 12vdc to be sure
the switch is in fact getting power. Yes voltage is present. Then go to the
switch and check for 12vdc, yes voltage is present on one side, then switch
the switch to the run position and check for voltage. It is found that
12vdc is present on the out put side of the switch. Next stop is the relay
coil, check for 12vdc at the coil of the relay, yes 12vdc is resent, then
check the out put side of the relay, no voltage found, hmmm, interesting,
now it is time to find out how the relay works, 12vdc goes to the coil of
the relay then passes through the coil to ground and the relay energizes
and the contacts are changed in state for open to closed, but the 12vdc
power source is from some where else going to the 12vdc fan motor and not
the switch on the dash. Now one must check the voltage patch the flow
through the relay to the 12vdc fan motor, and find the "why" it is not
present. So we have isolated the part of the 12vdc circuit that is not
working to turn on the fan with the switch. Checking the "source" circuit
breaker, it is found not to have 12vdc present. So the circuit breaker is
the bad part, it must be replaced. Now switch on the dash switch and the
fan motor runs. Great! you have fixed the problem, or have you? Did we look
into the "why" the circuit breaker went bad? This part of trouble shooting
is not always well defined and in fact may not be found. So that brings up
the question, what must happen to make a circuit breaker fail? Lose
connections are a cause. Bad ground is a cause, age of the part will
contribute to the cause of failure.
As you can see there can be several steps and items in a system even one as
simple as this one. Trouble shooting can be VERY time consuming, but it has
to be done to make a system work. Once you have been through a few
troubleshooting procedures like this, you learn some short cuts here and
there that helps to "cut" the time factor down a bit.
Also a thing to remember. Nothing is set in concrete when trying to find
out and repair what does not work. What I am trying to do here is show a
process that is practical, saves time and effort and cuts the cost of a repair.
Let's not throw money at something in hopes that is will make it run. You
can sure go through allot of money doing that and still not find the
problem let alone fix it. So with a few trouble shooting steps we have
spent $3.00 on a part to make the system run, instead of spending $225.00
in parts like new switch? new fan motor, new relay and so forth. Yes it has
cost the time to troubleshoot the system but is still cheaper on a repair
bill than throwing money at some thing.
Will stop here for this first post and wait a few days and answer any
questions anyone may have.
Ues I know it is a VERY simple system noted above, but there are a large
percentage of people that do not have any idea what or how. Please keep
that in mind when posting on this first post.
Safe travels,
84FC35 "Ruff Diamond"
Duncan, Oklahoma
12-24-2008, 08:54
Ralph, thank you for posting this information. Since this is your baby, I'll still want you to work on my stuff. Merry Christmas, Ernie and Brenda Ekberg 83PT40 in sunny Texas
derlodgeForum@yahoogroups.com
Sent: Wed, 24 Dec 2008 2:50 pm
Subject: [WanderlodgeForum] Practical troubleshooting your RV, 101 #1
Hello everyone;
appears to be.)
system.
Safe travels,
Duncan, Oklahoma
12-24-2008, 12:23
Thanks for the detail Ralph. While I understand this I will print this off and put it in my files as a memo for myself and for the next owner. Great stuff for BB folks. Merry Christmas.
Leroy Eckert
1990 WB-40 Smoke N Mirrors
Dahlonega, GA
Royale Conversion
Date: Wednesday, December 24, 2008, 3:50 PM
Hello everyone;
appears to be.)
system.
now we know it is a fan not coming on, so the problem is "recognized. " So
Safe travels,
Duncan, Oklahoma
12-24-2008, 18:06
Another useful tip.
I've got quite a lot of experience troubleshooting electronics but I
have to admit these BBs had me on the ropes. No diagrams, wrong
diagrams and previous owner mods were killers.
I just recently broke down and bought a "clamp" ammeter. Sears has a
nice VOM w/ clamp ammeter for around $70.
Good god ... how much this helps. Voltage can be present even with
bad contacts and in some cases will show up even if the circuit
you're tracing is open on one direction. (Coming from the back.) But
current is like water, it's either flowing or not and if its flowing
its got to be going somewhere.
The clamp requires some work sometimes because you can only "clamp"
one direction of the circuit so you have to separate wires sometimes
and the clamp is a little large maybe requiring "jumpers" but it sure
clears up mysteries like "flakey" relay coils fast.
Don't leave home without one,
GPSGary
12-28-2008, 02:20
Hello All,
Merry Christmas,
I have an 85 PT-40 and full schematics on the computer and am happy to help anyone troubleshoot with diagrams or techniques. I fix broadcast transmitters so I am familiar with many tricks
Gary
--- On Wed, 12/24/08, erniecarpet@... wrote:
Subject: Re: [WanderlodgeForum] Practical troubleshooting your RV, 101 #1
Date: Wednesday, December 24, 2008, 3:54 PM
derlodgeForum@ yahoogroups. com
Hello everyone;
appears to be.)
system.
Safe travels,
Duncan, Oklahoma
12-28-2008, 12:39
Hi Ralph,
On our trip here to South Padre Island, we stopped at a campground in
Rockport.
I was working outside with my Dremel plugged in and it bogged down. I
heard a pop and I lost all the grounds in the bus and blew 6 surge
protectors.
Where do I look?
Could the ground have melted off at the bus 50 amp inlet?
Bob Lawrence
84 PT36
South Padre Island, Texas
> Hello everyone;
not have
matter
basic start
problem
> appears to be.)
a given
> system.
The why
know how
to; "recognize"
Ok so
is "recognized." So
fan is
in that
line
fuse,
be
system so
from the
contacts
problem.
sure
go to the
then switch
that
the relay
resent, then
interesting,
coil of
energizes
12vdc
and not
flow
not
not
circuit
breaker is
and the
we look
shooting
brings up
will
even one as
but it has
here and
find
show a
of a repair.
run. You
have
$225.00
Yes it has
repair
any
large
keep
> Safe travels,
> Duncan, Oklahoma
12-28-2008, 12:53
Bob, check your plug at the bus end. Mine acted strange at the last rally. Ernie- 83PT40 in Weatherford, Tex
In a message dated 12/28/08 18:40:06 Central Standard Time, bobandarlene@... writes:
Hi Ralph,
Rockport.
protectors.
Where do I look?
Bob Lawrence
84 PT36
> Hello everyone;
not have
matter
basic start
problem
> appears to be.)
a given
> system.
The why
know how
to; "recognize"
Ok so
is "recognized." So
fan is
in that
line
fuse,
be
system so
from the
contacts
problem.
sure
go to the
then switch
that
the relay
resent, then
interesting,
coil of
energizes
12vdc
and not
flow
not
not
circuit
breaker is
he dash switch
and the
we look
shooting
brings up
will
even one as
but it has
here and
find
show a
of a repair.
run. You
have
$225.00
Yes it has
repair
any
large
se
keep
> Safe travels,
> Duncan, Oklahoma
12-28-2008, 13:00
Bob, please tell me the name of the campground. I am at Wal-mart in Victoria and plan on a stop in Corpus before going to SPI.
Wallace Craig
95 WLWB 42
Azle, Texas
--- On Sun, 12/28/08, Bob Lawrence wrote:
Subject: [WanderlodgeForum] Re: Practical troubleshooting your RV, 101 #1
Date: Sunday, December 28, 2008, 6:39 PM
Hi Ralph,
On our trip here to South Padre Island, we stopped at a campground in Rockport.
I was working outside with my Dremel plugged in and it bogged down. I heard a pop and I lost all the grounds in the bus and blew 6 surge protectors.
Where do I look?
Bob Lawrence
84 PT36
> Hello everyone;
> > Electrical systems in any venue, to many, is confusing and it does not have > to be. With just a few simple rules, one can do a systems check no matter > if it is a 12vdc/24vdc or an 110vac system.
> > The words, what? where?, how? and why? come to mind as the very basic start > to finding a problem with systematic troubleshooting.
> > What? equates to, What is the real problem? (does not mean what the problem > appears to be.)
in a given > system.
why." The why > equates to why did it happen in the first place.
> > It is important to try to learn how a system is designed to work or the > right way to say this is "know the sequence of operation." If
you know how > it is supposed to work then you are ready to start trying to; "recognize" > "localize" and "isolate" a problem.
> > Ok lets pick a simple system; 12vdc fan. Problem, fan does not run. Ok so > now we know it is a fan not coming on, so the problem is "recognized." So > what do we really know about "where it is." A switch on a dash,
the fan is > located behind a panel near the co pilots feet, but is there more in that > system besides a switch and fan motor? Could there be a "relay"
in line > between the switch and fan? Could there be a circuit breaker or fuse, > between the switch and fan motor? All are valid questions and can be > answered with a "sequence" of operation.
> > "Sequence" of operation for the system above; 1.it is a 12vdc system so > from the system circuit breaker, 12vdc is supplied to a switch and from the > switch to the coil of a 12vdc relay then 12vdc passes through the contacts > of the relay to the fan motor and the fan motor runs.
"localize" the problem. > Starting at the circuit break we are going to check for 12vdc to be sure > the switch is in fact getting power. Yes voltage is present. Then go to the > switch and check for 12vdc, yes voltage is present on one side, then switch > the switch to the run position and check for voltage. It is found that > 12vdc is present on the out put side of the switch. Next stop is the relay > coil, check for 12vdc at the coil of the relay, yes 12vdc is resent, then > check the out put side of the relay, no voltage found, hmmm, interesting, > now it is time to find out how the relay works, 12vdc goes to the coil of > the relay then passes through the coil to ground and the relay energizes > and the contacts are changed in state for open to closed, but the 12vdc > power source is from some where else going to the 12vdc fan motor and not > the switch on the dash. Now one must check the voltage patch the flow > through the relay to the 12vdc fan motor, and find the "why" it
is not > present. So we have isolated the part of the 12vdc circuit that is not > working to turn on the fan with the switch. Checking the
"source" circuit > breaker, it is found not to have 12vdc present. So the circuit breaker is > the bad part, it must be replaced. Now switch on the dash switch and the > fan motor runs. Great! you have fixed the problem, or have you? Did we look > into the "why" the circuit breaker went bad? This part of
trouble shooting > is not always well defined and in fact may not be found. So that brings up > the question, what must happen to make a circuit breaker fail? Lose > connections are a cause. Bad ground is a cause, age of the part will > contribute to the cause of failure.
> > As you can see there can be several steps and items in a system even one as > simple as this one. Trouble shooting can be VERY time consuming, but it has > to be done to make a system work. Once you have been through a few > troubleshooting procedures like this, you learn some short cuts here and > there that helps to "cut" the time factor down a bit.
> > Also a thing to remember. Nothing is set in concrete when trying to find > out and repair what does not work. What I am trying to do here is show a > process that is practical, saves time and effort and cuts the cost of a repair.
> > Let's not throw money at something in hopes that is will make it run. You > can sure go through allot of money doing that and still not find the > problem let alone fix it. So with a few trouble shooting steps we have > spent $3.00 on a part to make the system run, instead of spending $225.00 > in parts like new switch? new fan motor, new relay and so forth. Yes it has > cost the time to troubleshoot the system but is still cheaper on a repair > bill than throwing money at some thing.
> > Will stop here for this first post and wait a few days and answer any > questions anyone may have.
> > Ues I know it is a VERY simple system noted above, but there are a large > percentage of people that do not have any idea what or how. Please keep > that in mind when posting on this first post.
> > Safe travels,
> Duncan, Oklahoma
Yahoo! Groups Links
<*> Your email settings:
(Yahoo! ID required)
mailto:WanderlodgeForum-digest@yahoogroups.com mailto:WanderlodgeForum-fullfeatured@yahoogroups.com
12-28-2008, 13:31
Hi Wallace,
Stayed at Drifters Resort in Rockport.
Took hwy 188 to business 35. Left on business 35 (not hwy 35). Left
about 1/4 mile on left. 5 year old park. Stayed in space 81. Best as
at the end and no one on one side. Phone 361-727-9105.
See you here at Padre.
Bob
84 PT36
Padre Island, Texas
> Wallace Craig
> 95 WLWB 42
> Azle, Texas
> From: Bob Lawrence
101 #1
> Hi Ralph,
in
> Rockport.
I
> protectors.
> Where do I look?
> Bob Lawrence
> 84 PT36
> > Hello everyone;
does
> not have
no
> matter
> basic start
> problem
> > appears to be.)
> in
> a given
> > system.
> why."
> The why
or
> the
> you
> know how
> to; "recognize"
run.
> Ok so
> is "recognized." So
> the
> fan is
> in that
> in
> line
> fuse,
> be
> system so
> from the
> contacts
> "localize" the
> problem.
be
> sure
> go to the
> then switch
> that
> the relay
> resent, then
> interesting,
> coil of
> energizes
> 12vdc
> and not
> flow
> is
> not
is
> not
> "source"
> circuit
> breaker is
> and the
Did
> we look
> trouble
> shooting
> brings up
Lose
> will
> even one as
> but it has
few
> here and
to
> find
> show a
cost
> of a repair.
> run. You
> the
> have
> $225.00
> Yes it has
a
> repair
> any
a
> large
Please
> keep
> > Safe travels,
> > Duncan, Oklahoma
> Yahoo! Groups Links
12-28-2008, 13:33
Thanks, Ernie,
Was thinking about it a little while ago.
Will check ii in the am.
Bob
> Hi Ralph,
in
> Rockport.
I
> protectors.
> Where do I look?
> Bob Lawrence
> 84 PT36
> > Hello everyone;
does
> not have
no
> matter
> basic start
> problem
> > appears to be.)
in
> a given
> > system.
why."
> The why
or
> the
> know how
> to; "recognize"
run.
> Ok so
> is "recognized." So
> fan is
> in that
in
> line
> fuse,
> be
> system so
> from the
> contacts
> problem.
be
> sure
> go to the
> then switch
> that
> the relay
> resent, then
> interesting,
> coil of
> energizes
> 12vdc
> and not
> flow
is
> not
is
> not
> circuit
> breaker is
> and the
Did
> we look
> shooting
> brings up
Lose
> will
> even one as
> but it has
few
> here and
to
> find
> show a
cost
> of a repair.
> run. You
> the
> have
> $225.00
> Yes it has
a
> repair
> any
a
> large
Please
> keep
> > Safe travels,
> > Duncan, Oklahoma
