Getting Hard Water Scale in Plumbing, What To Do?
12-30-2008, 08:39
Howdy.
I just took apart the solenoid for our coach's Microphor 12 V Commode to see why it wouldn't shut off the water. Water was running into the commode's bowl constantly. The Microphor tech said,"Look for sand in the valve part of the solenoid." I did that and did NOT find any SAND but pieces of scale instead. I am too old and lazy to keep tearing that solenoid apart every two weeks. There must be an answer to solve this hard water scale problem. Ideas, suggestions would be appreciated. A source of C4 as a permanent solution? TIA, Jack Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 D'Hanis, TX in the Winter Buena Vista, CO in the Summer |
12-30-2008, 10:26
Hi Jack,
We fulltime also and use a water softner by Flow Pure. When we first got it 3 years ago, after using it for about 2 weeks, I noticed that when I flushed, white chunks started coming out of the toilet head. Turns out to be hard water chunks. Problem solved for us. When we first check in somewhere, I test the water with test strips and if hard enough, I put on the water softner. Cost was $290, but recharging it with cheap salt (33 cents) every 800 gallons or so (depending on how hard the water is), is a cheap solution. Bob Lawrence 84 PT36 South Padre Island, Tx (where we are using the softner) > Howdy. > > I just took apart the solenoid for our coach's Microphor 12 V Commode to > see why it wouldn't shut off the water. Water was running into the > commode's bowl constantly. The Microphor tech said,"Look for sand in the > valve part of the solenoid." I did that and did NOT find any SAND but > pieces of scale instead. I am too old and lazy to keep tearing that > solenoid apart every two weeks. There must be an answer to solve this > hard water scale problem. Ideas, suggestions would be appreciated. > A source of C4 as a permanent solution? > > TIA, > Jack > Regards, > Jack and Liz Pearce > Fulltiming in a 1993 Wanderlodge WB40 > D'Hanis, TX in the Winter > Buena Vista, CO in the Summer > |
12-30-2008, 11:00
Where did you get the water softener?
Bill Jowers
83PT36
12-30-2008, 14:17
Jack: You might try a water softener. Talk to Chet Parks about that.
He is an expert and also makes softeners. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Jack and Liz Pearce" > > Howdy. > > I just took apart the solenoid for our coach's Microphor 12 V Commode to > see why it wouldn't shut off the water. Water was running into the > commode's bowl constantly. The Microphor tech said,"Look for sand in the > valve part of the solenoid." I did that and did NOT find any SAND but > pieces of scale instead. I am too old and lazy to keep tearing that > solenoid apart every two weeks. There must be an answer to solve this > hard water scale problem. Ideas, suggestions would be appreciated. > A source of C4 as a permanent solution? > > TIA, > Jack > Regards, > Jack and Liz Pearce > Fulltiming in a 1993 Wanderlodge WB40 > D'Hanis, TX in the Winter > Buena Vista, CO in the Summer > |
12-31-2008, 10:03
Hey Bill,
Try Flowpur.com. That should do it. Flowpur has more gold in it that the Camping World model. Bob Lawrence 84 PT36 Padre Island, Tx > Where did you get the water softener? > Bill Jowers > 83PT36 > ----- Original Message ----- > From: Bob Lawrence > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, December 30, 2008 4:26 PM > Subject: [WanderlodgeForum] Re: Getting Hard Water Scale in Plumbing, What To Do? > > > Hi Jack, > We fulltime also and use a water softner by Flow Pure. When we first > got it 3 years ago, after using it for about 2 weeks, I noticed that > when I flushed, white chunks started coming out of the toilet head. > Turns out to be hard water chunks. Problem solved for us. > When we first check in somewhere, I test the water with test strips > and if hard enough, I put on the water softner. > Cost was $290, but recharging it with cheap salt (33 cents) every 800 > gallons or so (depending on how hard the water is), is a cheap > solution. > Bob Lawrence > 84 PT36 > South Padre Island, Tx (where we are using the softner) > > > Howdy. > > > > I just took apart the solenoid for our coach's Microphor 12 V > Commode to > > see why it wouldn't shut off the water. Water was running into the > > commode's bowl constantly. The Microphor tech said,"Look for sand > in the > > valve part of the solenoid." I did that and did NOT find any SAND > but > > pieces of scale instead. I am too old and lazy to keep tearing that > > solenoid apart every two weeks. There must be an answer to solve > this > > hard water scale problem. Ideas, suggestions would be appreciated. > > A source of C4 as a permanent solution? > > > > TIA, > > Jack > > Regards, > > Jack and Liz Pearce > > Fulltiming in a 1993 Wanderlodge WB40 > > D'Hanis, TX in the Winter > > Buena Vista, CO in the Summer > > > |
