Holding tanks frozen. Now what?
01-11-2009, 12:44
I live in it part of the time. If you're familiar with the term "man
cave", it's easy to understand. Smile
-Ryan
'86 PT-40 8V92
On 1/4/09, Leroy Eckert wrote:
> Ryan, are you living in the coach this winter? Or is it parked in the yard?
> My coach has tank heaters which I never turn on because I have had a bad
experience
> with heat strips. It gets very cold here in the mountains so I simply empty
the tanks
> during the winter. I still get quiet time in the coach while parked in the
driveway.
> Leroy Eckert
> 1990 WB-40 Smoke N Mirrors
> Dahlonega, GA
> Royale Conversion
01-11-2009, 13:01
Hey Ryan,
I live in my PT40 part of each week too when I'm in Billings. Coldest
temps so far (Dec) this winter was 34 below. I have an air hook up to
clear my water system in about 2 minutes. I use my on board water tank
for water source & unhook the hose after each fill. Rock salt in
the holding tanks too. Last year, I pulled all of the copper pipe
& old heat tapes out & replaced with PEX. So far, no freeze
ups this winter. I have one of the constant hot water circulating
pumps that I may add to the water system if I get tired of draining the
water system each week.
It does work thanks to the PEX & the fact that I do drain the
system at about -15 or colder.
Terry Neal
82PT40 6V92TA
73FC31 6V53T
Bozeman, Montana
"man
-Ryan
'86 PT-40 8V92
On 1/4/09, Leroy Eckert <"jwasnewski%40yahoo.com">
the yard?
a bad experience
simply empty the tanks
parked in the driveway.
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
Checked by AVG - http://www.avg.com Version: 8.0.176 / Virus Database: 270.10.5/1886 - Release Date: 1/10/2009 6:01 PM
