1984 Elect System
01-19-2009, 06:23
1984 Elect System
Gary:
I have to agree, the system we have on our coaches is overkill. I only use the 50 amp powercord, and have two plugs that I can use, one down to 30 amps and one all the way down to 15 amps.
It is all about power management, the manual way.
I have plans to remove all of my 30 amp cabling system as it is not necessary.
I believe that John Finn changedhis system over where he uses the rotary transfer switch even for his inverter system. I willbe doing my system in April hopefully,so I will be interested in how you are doing yours. Tom Warner also did his, and he added another breaker box for the inverter loads.
Chuck -what size of generator did you get, I am thinking of getting a 2000 watt Honda or2400 Yamaha. Bill 84 FC 35 SB "$quanderlodge"Terrace, B.C. Canada
01-19-2009, 09:54
1984 Elect System
Bill,
I have the Honda 2000 which I always carry. You may want to check size. The Yamaha may work better. The Honda is a little too tall for the storage compartments on our bb. I made a carrier that holds it at a slight angle to meet the clearance without dumping oil or fuel. I wasn't aware of the Yamaha when I got the Honda.
- Chuck Wheeler-
1982 FC 31SB Fort Worth TX
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Wilhelmus Schreurs Sent: Monday, January 19, 2009 12:24 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] 1984 Elect System Gary:
01-20-2009, 04:54
1984 Elect System
Hey Guys,
I guess I was fortunate enough not to have all that extra wiring in my 78. I only have a 50 amp socket that both my 30 amp & 50 amp plugs use. I do have a 50-30 amp adapter too. I also created a 30 amp extention cord that I use (when needed) on my 50 amp cable. That way I can extend the 30 amp reach with a safe size wire. I'm also added a ProSine 2000 watt charger/inverter and will be putting in a seperate breaker box OR modifying the existing one, I have tore into that yet. As far as generators go, I too purchased a smaller one for boony docking to charge up the batteries. I purchased a cheap China 1000 watt generator for about $100 and run one of my old 40 amp chargers on it. It's not really regulated but these old chargers have transformers on the front end so it is ok. It'll run between 1-1/2 - 2 hours on a gallon of fuel and seems suffiecent and quiet in topping off my 4 deep cycle batteries. FYI, Michael 78FC35 Mesa, Az --- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > Bill, > I have the Honda 2000 which I always carry. You may want to check size. > The Yamaha may work better. The Honda is a little too tall for the storage > compartments on our bb. I made a carrier that holds it at a slight angle to > meet the clearance without dumping oil or fuel. I wasn't aware of the > Yamaha when I got the Honda. > > - Chuck Wheeler- > 1982 FC 31SB Fort Worth TX > > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Wilhelmus Schreurs > Sent: Monday, January 19, 2009 12:24 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] 1984 Elect System > > > > > Gary: > I have to agree, the system we have on our coaches is overkill. I only use > the 50 amp powercord, and have two plugs that I can use, one down to 30 amps > and one all the way down to 15 amps. > It is all about power management, the manual way. > I have plans to remove all of my 30 amp cabling system as it is not > necessary. > I believe that John Finn changed his system over where he uses the rotary > transfer switch even for his inverter system. I will be doing my system in > April hopefully, so I will be interested in how you are doing yours. Tom > Warner also did his, and he added another breaker box for the inverter > loads. > > Chuck - what size of generator did you get, I am thinking of getting a 2000 > watt Honda or 2400 Yamaha. > > Bill 84 FC 35 SB "$quanderlodge" > Terrace, B.C. Canada > > > > > _____ > > <http://us.i1.yimg.com/us.yimg.com/i/ca/iotg_search.jpg> > <http://ca.toolbar.yahoo.com/> Yahoo! Canada Toolbar : Search from anywhere > on the web and bookmark your favourite sites. Download it now! > |
