Speakers half work.
01-28-2009, 13:35
Speakers half work.
Only two of my cabin speakers work when listing to XM radio that is fed
thru the TV via sat system. All the speakers work when listening to the radio or cd player. Anybody know where the cable from the tv goes and where it is located. I know I have to push the accessory switch on the dash to route the XM to the speakers. Could this be where the other end of the cable is located. This is on a 98 LXI. Thanks for any help. Johnny M Slone Pikeville, Ky 98 LXI 41' Pressently in 80 degree Tampa Florida. |
01-28-2009, 14:12
Speakers half work.
Does your TV play through the same two speakers only or can you route it through the others?
Just wondering if it's more of a design limitation rather than something wrong. Brad Barton 00LXiDFW bbartonwx@... To: WanderlodgeForum@yahoogroups.com From: johnnymslone@... Date: Thu, 29 Jan 2009 01:35:29 +0000 Subject: [WanderlodgeForum] Speakers half work.
Only two of my cabin speakers work when listing to XM radio that is fed thru the TV via sat system. All the speakers work when listening to the radio or cd player. Anybody know where the cable from the tv goes and where it is located. I know I have to push the accessory switch on the dash to route the XM to the speakers. Could this be where the other end of the cable is located. This is on a 98 LXI. Thanks for any help. Johnny M Slone Pikeville, Ky 98 LXI 41' Pressently in 80 degree Tampa Florida. Windows Live⢠Hotmail®â¦more than just e-mail. See how it works. |
01-28-2009, 15:09
Speakers half work.
Thanks Brad for the reply. To my surprise I turned the system to a
TV channel and all 4 speakers worked. Turned the channel to XM and still all 4 speakers still have sound. Leave it on Willies place for a few minutes and now only 2 speakers work. I must have maybe an amp or something getting hot and then stops working. Going to let it rest a while and try again. May have been doing this all along and I just didn't notice. The system sounds good with 2 speakers but sounds great with all 4 working. Wonder if anyone has a drawing on this circuit. Johnny M Slone Pikeville, Ky 98 LXI |
