Lil' Stanker
02-01-2009, 11:23
Lil' Stanker
I just can't seem to rid myself of the occasional holding tank odor,
so I'm thinking sticking a pair of these on the roof: http://www.lslproducts.com/MK-IVPage.html The concept is sound (use a small fan to create a slight negative pressure inside the tank, thus ensuring all odors go out the roof vents). I'm curious if anyone has installed these on a Bird, and if so, how well they worked for you? My only real concern is the existing vents on my coach (picture at http://www.ryanwright.com/tmp/vent.jpg), which appear to take incoming air while moving and use that to create the negative pressure. While I don't foresee any problems swapping the Lil' Stankers for these, I did want to ask here just to be sure I wasn't missing something. Thank you, -Ryan '86 PT-40 8V92 |
02-01-2009, 13:51
Lil' Stanker
02-01-2009, 15:38
Lil' Stanker
Ryan & Leroy,
I installed two lil-stankers on the coach back in September. They work as advertised. Good service, burnt up a switch they repaced it no charge and it was my installation that caused the switch to burn, the hot wire got grounded under the rim of the lil-stanker, my bad.I used the external unit, easier for me to install, I could only access one up pie on the inside of the coach, so I decided to do both pipes the same. The internal units are more powerful but I'm happy with what I have. The last 1500 mile trip I had only one smelly incident , just after dumping. I could not determine the source but it hasn't reoccurred. I'm going to try Leroy's solution and make sure the shower and other drain traps are full and I will use a flat, soft, cover over the shower drain. If that does not work then the only source left for me to fix is the one Rob R. pointed out. The air vent in the toilet. Not sure what to do about that. Maybe Rob will chime in here. If you have a washer/dryer you may want to check out the check valve on the air purge system to winterize the water system, they are not air tight, and as it turns out it was my #1 source of bad smells. Kurt Horvath 95 PT 42 10AC --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert > > From all reports I have seen those fans work fine. I think LilStanker has a model that installs in the vent line so you don't have to mess with the vent venturi. I think on one of these forums someone just installed them. That vent for all intent and purposes operates in a semi vacuum at best. It still would not hurt to seek out the source of the issue. > I have never had the problem except when driving with a window open. I cured that by closing the drains while in motion. > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > Royale Conversion > > --- On Sun, 2/1/09, Ryan Wright > From: Ryan Wright > Subject: [WanderlodgeForum] Lil' Stanker > To: "wanderlodgeforum" > Date: Sunday, February 1, 2009, 6:23 PM > > > > > > > > > > > > I just can't seem to rid myself of the occasional holding tank odor, > > so I'm thinking sticking a pair of these on the roof: > > http://www.lslprodu cts.com/MK- IVPage.html > > > > The concept is sound (use a small fan to create a slight negative > > pressure inside the tank, thus ensuring all odors go out the roof > > vents). I'm curious if anyone has installed these on a Bird, and if > > so, how well they worked for you? > > > > My only real concern is the existing vents on my coach (picture at > > http://www.ryanwrig ht.com/tmp/ vent.jpg), which appear to take incoming > > air while moving and use that to create the negative pressure. While I > > don't foresee any problems swapping the Lil' Stankers for these, I did > > want to ask here just to be sure I wasn't missing something. > > > > Thank you, > > > > -Ryan > > '86 PT-40 8V92 > |
02-02-2009, 03:06
Lil' Stanker
DID YOU CHECK YOUR EXISTING VENT FOR A BLOCKAGE FIRST. SCOOTER 2000XL, MI
02-02-2009, 05:31
Lil' Stanker
Thank you for the responses. Some questions:
1. How do I check the vent for a blockage? 2. What else could I do to find the source(s) of the smells? I don't have a washer/dryer and I keep my p-traps full of water by regularly using the sinks & shower. My toilet, however, does not hold water for long - if I fill the bowl, it will be empty after a few hours. Should I replace it? (Is this difficult? It's a straight-drop, not an air toilet) If so, any recommendations on what type of toilet to buy? 3. If anyone has installed the in-line Lil' Stankers, I'd like to hear more on where you put them / how you accessed the vent lines. I'd prefer the in-lines over the roof mounts, but it looks like it would be very difficult to install and service the in-lines. Thank you! -Ryan '86 PT-40 8V92 On Mon, Feb 2, 2009 at 7:06 AM, Al Scudder > DID YOU CHECK YOUR EXISTING VENT FOR A BLOCKAGE FIRST. > > SCOOTER 2000XL, MI > > > ----- Original Message ----- > From: Ryan Wright > Sent: Sunday, February 01, 2009 6:23 PM > To: wanderlodgeforum > Subject: [WanderlodgeForum] Lil' Stanker > > > I just can't seem to rid myself of the occasional holding tank odor, > so I'm thinking sticking a pair of these on the roof: > http://www.lslproducts.com/MK-IVPage.html > > The concept is sound (use a small fan to create a slight negative > pressure inside the tank, thus ensuring all odors go out the roof > vents). I'm curious if anyone has installed these on a Bird, and if > so, how well they worked for you? > > My only real concern is the existing vents on my coach (picture at > http://www.ryanwright.com/tmp/vent.jpg), which appear to take incoming > air while moving and use that to create the negative pressure. While I > don't foresee any problems swapping the Lil' Stankers for these, I did > want to ask here just to be sure I wasn't missing something. > > Thank you, > > -Ryan > '86 PT-40 8V92 > > |
02-02-2009, 05:54
Lil' Stanker
--- In WanderlodgeForum@yahoogroups.com, Ryan Wright
> > 2. What else could I do to find the source(s) of the smells? I don't > have a washer/dryer and I keep my p-traps full of water by regularly > using the sinks & shower. My toilet, however, does not hold water for > long - if I fill the bowl, it will be empty after a few hours. > > -Ryan > '86 PT-40 8V92 > Ryan, I would think that if the water can seep into the tank, then the oders can "seep" out. This could possibly be the source of the oders you keep smelling. Either try to replace the seal or the toilet. I have not been following very closely. I don't know if a few hours for the water to leak out would equate to the potential oders you are encountering. Regards, Glenn |
02-02-2009, 06:05
Lil' Stanker
R,
What type of toilet is in your coach? Kurt Horvath 95 PT42 10AC --- In WanderlodgeForum@yahoogroups.com, Ryan Wright > > Thank you for the responses. Some questions: > > 1. How do I check the vent for a blockage? > > 2. What else could I do to find the source(s) of the smells? I don't > have a washer/dryer and I keep my p-traps full of water by regularly > using the sinks & shower. My toilet, however, does not hold water for > long - if I fill the bowl, it will be empty after a few hours. Should > I replace it? (Is this difficult? It's a straight-drop, not an air > toilet) If so, any recommendations on what type of toilet to buy? > > 3. If anyone has installed the in-line Lil' Stankers, I'd like to hear > more on where you put them / how you accessed the vent lines. I'd > prefer the in-lines over the roof mounts, but it looks like it would > be very difficult to install and service the in-lines. > > Thank you! > > -Ryan > '86 PT-40 8V92 > > On Mon, Feb 2, 2009 at 7:06 AM, Al Scudder > > DID YOU CHECK YOUR EXISTING VENT FOR A BLOCKAGE FIRST. > > > > SCOOTER 2000XL, MI > > > > > > ----- Original Message ----- > > From: Ryan Wright > > Sent: Sunday, February 01, 2009 6:23 PM > > To: wanderlodgeforum > > Subject: [WanderlodgeForum] Lil' Stanker > > > > > > I just can't seem to rid myself of the occasional holding tank odor, > > so I'm thinking sticking a pair of these on the roof: > > http://www.lslproducts.com/MK-IVPage.html > > > > The concept is sound (use a small fan to create a slight negative > > pressure inside the tank, thus ensuring all odors go out the roof > > vents). I'm curious if anyone has installed these on a Bird, and if > > so, how well they worked for you? > > > > My only real concern is the existing vents on my coach (picture at > > http://www.ryanwright.com/tmp/vent.jpg), which appear to take incoming > > air while moving and use that to create the negative pressure. While I > > don't foresee any problems swapping the Lil' Stankers for these, I did > > want to ask here just to be sure I wasn't missing something. > > > > Thank you, > > > > -Ryan > > '86 PT-40 8V92 > > > > > |
02-02-2009, 06:17
Lil' Stanker
Ryan,
This post presumes you have the original Thetford Galaxie toilet that were installed into many Bird. Try to open the toilet flapper and clean the seal with a toothbrush and lube with silicone grease or plumbers grease. The seal is probably leaking which leads to oders entering the Bird' the toilet seal should hold water indefinitely. If the seal needs replaced there are are few options. A complete set of seals are available about 6 seals, remove the toilet and replace. this is a tinkerers nightmare,at about $50. and it may not fix the problem, the kit does not replace the main valve and water shut-off. The entire bottom of the toilet can be replaced , this is a good option if the lid and bowl are in good condition about $150.00, . Thetford has a universal replacement toilet Bravura. http://www.tweetys.com/bravura-rv-toilet...saver.aspx IF the toilet is replaced there may be a lot more work with replacing the tile on the floor and the surround trimming in the rear of the toilet. The Thetford 800 # is very helpful Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, Ryan Wright > > Thank you for the responses. Some questions: > > 1. How do I check the vent for a blockage? > > 2. What else could I do to find the source(s) of the smells? I don't > have a washer/dryer and I keep my p-traps full of water by regularly > using the sinks & shower. My toilet, however, does not hold water for > long - if I fill the bowl, it will be empty after a few hours. Should > I replace it? (Is this difficult? It's a straight-drop, not an air > toilet) If so, any recommendations on what type of toilet to buy? > > 3. If anyone has installed the in-line Lil' Stankers, I'd like to hear > more on where you put them / how you accessed the vent lines. I'd > prefer the in-lines over the roof mounts, but it looks like it would > be very difficult to install and service the in-lines. > > Thank you! > > -Ryan > '86 PT-40 8V92 > > On Mon, Feb 2, 2009 at 7:06 AM, Al Scudder > > DID YOU CHECK YOUR EXISTING VENT FOR A BLOCKAGE FIRST. > > > > SCOOTER 2000XL, MI > > > > > > ----- Original Message ----- > > From: Ryan Wright > > Sent: Sunday, February 01, 2009 6:23 PM > > To: wanderlodgeforum > > Subject: [WanderlodgeForum] Lil' Stanker > > > > > > I just can't seem to rid myself of the occasional holding tank odor, > > so I'm thinking sticking a pair of these on the roof: > > http://www.lslproducts.com/MK-IVPage.html > > > > The concept is sound (use a small fan to create a slight negative > > pressure inside the tank, thus ensuring all odors go out the roof > > vents). I'm curious if anyone has installed these on a Bird, and if > > so, how well they worked for you? > > > > My only real concern is the existing vents on my coach (picture at > > http://www.ryanwright.com/tmp/vent.jpg), which appear to take incoming > > air while moving and use that to create the negative pressure. While I > > don't foresee any problems swapping the Lil' Stankers for these, I did > > want to ask here just to be sure I wasn't missing something. > > > > Thank you, > > > > -Ryan > > '86 PT-40 8V92 > > > > > |
02-02-2009, 06:26
Lil' Stanker
02-02-2009, 06:30
Lil' Stanker
