12.5 Kohler Gen set Instruments
02-03-2009, 15:15
I have the 12.5 Perkins/Kohler Gen set. The only "engine" instrument
that works is the Volt meter. Can anyone help with the location of the sending units on the engine for Water temp and oil pressure. I have checked the gnd at the instrument panel and got no results, this could still be the problem. I see several sending units on the engine but am unsure which ones are tied into the auto shut down and which go to the instruments. Also if anyone can help with a procedure for testing either the instruments or the sending units. Any help is greatly appreciated. THANKS Wendel 82 FCSB 35 "Change of Venue" |
02-03-2009, 16:45
The Oil pressure sending unit is on the right side of the engine low down about 2/3 back from the front. The temperature sending unit is on the top front near the upper radiator hose. I have the resistance of the units at home but we are on the road right now. I would expect a wiring problem since they both are not working. It is easy to pull the leads off them when work is being performed on the genset.
- Chuck Wheeler-
1982 FC 31SB Fort Worth TX
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of akav8r Sent: Tuesday, February 03, 2009 9:16 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] 12.5 Kohler Gen set Instruments I have the 12.5 Perkins/Kohler Gen set. The only "engine" instrument that works is the Volt meter. Can anyone help with the location of the sending units on the engine for Water temp and oil pressure. I have checked the gnd at the instrument panel and got no results, this could still be the problem. I see several sending units on the engine but am unsure which ones are tied into the auto shut down and which go to the instruments. Also if anyone can help with a procedure for testing either the instruments or the sending units. Any help is greatly appreciated. THANKS Wendel 82 FCSB 35 "Change of Venue" |
02-04-2009, 01:48
Try these Teleflex sites.
http://www.teleflexmarine.com/ http://www.downloadingfiles.co.uk/telefl...A%20Basic% 20Gauge%20Test.pdf http://www.downloadingfiles.co.uk/telefl...ructionman uals/67369.pdf http://www.teleflexmarine.com/cgi-bin/library.cgi? site=home&type=us&library=1019 You may need to cut and past these long address. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "akav8r" > > I have the 12.5 Perkins/Kohler Gen set. The only "engine" instrument > that works is the Volt meter. Can anyone help with the location of the > sending units on the engine for Water temp and oil pressure. I have > checked the gnd at the instrument panel and got no results, this could > still be the problem. I see several sending units on the engine but am > unsure which ones are tied into the auto shut down and which go to the > instruments. Also if anyone can help with a procedure for testing > either the instruments or the sending units. Any help is greatly > appreciated. > > THANKS > Wendel > 82 FCSB 35 > "Change of Venue" > |
02-07-2009, 03:32
