Mysteries of "The Bird"
02-04-2009, 11:35
Here are a couple of mysteries that to many may be simple but to me
they are a mystery.
1. I have a single switch, like used for lighting circuits, located
on the bottom of the overhead storage on the very rear of the coach
(in the bed room). I have twin beds and this switch is located
nearly center of the coach from side to side, putting it over the
center night stand. I can find nothing that it controls.
2. I have a 110v type plug in the rear fridge access compartment.
It is connected to 12/3 romex type wire that goes up, too where is
the question. It appears that at some time it has been plugged into
the same outlet as the fridge. It was not plugged in when I got the
coach and I have not left it plugged in. I have not been able to
find anything inop when unplugged or operative when plugged in.
3. I have an 110 outlet in the half closet beside the fridge that is
inop, a 110v outlet in the bath that is inop, and the 110v outlet in
the propane tank compartment is inop. I have checked the circuit
breakers and all appear to be on and working.
I have not chased any of these "mysteries" very much as they have
just not made it to the top of the to-do list. Some like the outlets
I would really like to make operative others are more of a curosity.
THANKS in advance and THANKS to the whole group for helping me with
several issues in my first 18 months of ownership not all of it has
been fun but I would not want any other coach.
Wendel, GA
82 fc35sb
"Change of Venue"
02-04-2009, 12:38
Wendell,
3. There is a breaker in your main box that is a GFI and that needs to have the little red button pushed. That should get juice to those outlets.
2. Not sure but me thinks this is where the heat tapes that are on your pipes where once connected.
1. Another guess here. It might be your electric door lock.
Chet Geist
1981 FC33, Austin, Texas
-----Original Message-----
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of akav8r
Sent: Wednesday, February 04, 2009 5:36 PM
Subject: [WanderlodgeForum] Mysteries of "The Bird"
they are a mystery.
Wendel, GA
82 fc35sb
"Change of Venue"
02-04-2009, 13:05
Hi,
There is a breaker in the main box that controls the bathroom outlet
and also controls the propane outlet.
I doubt that you have a GFI in your rig. Mine didn't come with it.
Does your single switch light up? If it does, it is probably the
engine oil heater.
Bob Lawrence
84 PT 36
Laguna Atascosa NWR
Los Fresnos, Texas.
> they are a mystery.
located
into
is
in
outlets
> Wendel, GA
> 82 fc35sb
> "Change of Venue"
02-04-2009, 14:52
Bob,
My 81 FC does have a GFI that controls those outlets. It has popped a number of times when driving in a hard rain. Probably shorts the outlet by the propane tank.
Chet Geist
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Bob Lawrence
Sent: Wednesday, February 04, 2009 7:05 PM
Subject: [WanderlodgeForum] Re: Mysteries of "The Bird"
Hi,
engine oil heater.
Bob Lawrence
84 PT 36
Laguna Atascosa NWR
Los Fresnos, Texas.
> they are a mystery.
located
into
is
in
outlets
> Wendel, GA
> 82 fc35sb
> "Change of Venue"
02-06-2009, 07:19
if this hasn't been answered yet, the switch on the bottom of that
rear compartment most likely controls the 110v outlet for your
television. In my '83 the outlet is on the passenger side up in front
of the bedroom window.
Not sure what the 110v romex if for at the back of the fridge, unless
someone had hook up a 110v fan at one time ??
Dan Schrader
Buckeye Bird
> they are a mystery.
located
into
is
in
outlets
> Wendel, GA
> 82 fc35sb
> "Change of Venue"
