Lighting problem
02-05-2009, 13:01
Lighting problem
I registered on this forum a few weeks back after we sold our Beaver
and bought this 85 PT40. I religously read the emails twice daily and it appears there is a wealth of knowledge here. I think I need some help now myself. I've fixed two plumbing problems and assorted other things and still have a few to go. Here's my main problem today: - Our 85 PT40 has the light switches above the front door to turn on the light over the door and turn on the lights by the front curtains on both sides. The other night the lights all went out and I haven't been able to get them to turn on. - The little individual lights work as do the rest of them throughout the coach. - I did take off all the switch plate covers and checked for loose wires, all to no avail. - The lights did work sporadically, but I haven't been able to get them to turn on in 2 days. Any ideas and help would be greatly appreciated. Thanks again. Jerry and Jayne Full timing in our 85 PT40 |
02-05-2009, 14:42
Lighting problem
Somewhere there are breakers for those lights (12v breakers). On mine, they are
on the passenger side overhead mid-coach, just forward of the refrigerator. Since that is only one of 5 separate 12V distribution areas on this coach I am not about to assume that's where yours are, but you need to find the appropriate panel. Don Bradner 90 PT40 "Blue Thunder" Posting today by aircard from the Flying J in Lodi, California My location: http://www.bbirdmaps.com/user2.cfm?user=1 On 2/6/2009 at 1:01 AM jburgessx2 wrote: >I registered on this forum a few weeks back after we sold our Beaver >and bought this 85 PT40. I religously read the emails twice daily >and it appears there is a wealth of knowledge here. I think I need >some help now myself. I've fixed two plumbing problems and assorted >other things and still have a few to go. Here's my main problem >today: > > - Our 85 PT40 has the light switches above the front door to turn on >the light over the door and turn on the lights by the front curtains >on both sides. The other night the lights all went out and I haven't >been able to get them to turn on. > > - The little individual lights work as do the rest of them >throughout the coach. > > - I did take off all the switch plate covers and checked for loose >wires, all to no avail. > > - The lights did work sporadically, but I haven't been able to get >them to turn on in 2 days. > >Any ideas and help would be greatly appreciated. > >Thanks again. > >Jerry and Jayne >Full timing in our 85 PT40 > > > >------------------------------------ > >Yahoo! Groups Links > > > |
02-05-2009, 16:09
Lighting problem
Don,
I've found a few busses and load centers but I have yet to see a circuit breaker for the 12 volt system. I've checked the books that came with the coach and it doesn't tell me where the circuit breakers are. I haven't yet checked behind the left headlight panel but will tomorrow. Jerry 85 PT40 --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > Somewhere there are breakers for those lights (12v breakers). On mine, they are on the passenger side overhead mid-coach, just forward of the refrigerator. Since that is only one of 5 separate 12V distribution areas on this coach I am not about to assume that's where yours are, but you need to find the appropriate panel. > > Don Bradner > 90 PT40 "Blue Thunder" > Posting today by aircard from the Flying J in Lodi, California > My location: http://www.bbirdmaps.com/user2.cfm?user=1 > > On 2/6/2009 at 1:01 AM jburgessx2 wrote: > > >I registered on this forum a few weeks back after we sold our Beaver > >and bought this 85 PT40. I religously read the emails twice daily > >and it appears there is a wealth of knowledge here. I think I need > >some help now myself. I've fixed two plumbing problems and assorted > >other things and still have a few to go. Here's my main problem > >today: > > > > - Our 85 PT40 has the light switches above the front door to turn on > >the light over the door and turn on the lights by the front curtains > >on both sides. The other night the lights all went out and I haven't > >been able to get them to turn on. > > > > - The little individual lights work as do the rest of them > >throughout the coach. > > > > - I did take off all the switch plate covers and checked for loose > >wires, all to no avail. > > > > - The lights did work sporadically, but I haven't been able to get > >them to turn on in 2 days. > > > >Any ideas and help would be greatly appreciated. > > > >Thanks again. > > > >Jerry and Jayne > >Full timing in our 85 PT40 > > > > > > > >------------------------------------ > > > >Yahoo! Groups Links > > > > > > > |
02-05-2009, 17:10
Lighting problem
Jerry,
Seems strange that all would stop working at one time. Follow the other responses first. Assuming the '85 PT40 is the same as an '87 PT38... Is there 12V at the switch(s)? If there is 12V...remove one of the florescent fixture frame/box. There should be an inverter attached to the fixture box...the lights work on AC and have an inverter to run each light. Test for 12V feeding the inverter. If there is 12V...and assuming the bulbs are good...replace the inverter as it's no longer working. Stephen Birtles sells the inverters. You will need one for each florescent fixture. I changed several in our coach. Good luck. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA On Thu, Feb 5, 2009 at 8:09 PM, jburgessx2 <"jburgessx2@yahoo.com"> wrote:
02-06-2009, 00:42
Lighting problem
02-06-2009, 06:31
Lighting problem
12V circuit breakers are fuse-like thingies with a little push switch on them. They otherwise look like the regular 2-prong automotive-type fuses. Half or more of the fuses on my coach are the circuit breaker type. Most of the rest are silver-canisters (that look a lot like the circuit breaker type) and a few are typical colored plastic fuses.
Unless someone has added ad hoc fuses, the fuses and circuit breakers should be in one of the several power centers in your coach. My coach is quite a lot newer, so the locations are likely different. I note, however, that a "hidden" power center was behind the above-dash cabinets that I only found when I was trying to fix a bad wire on my TV antenna. I was then able to resolve a dead power feed to the passenger power seat control which had eluded me for months.... So the hint is to check cabinets for removable panels at the rear that might conceal a power center. A circuit tracer tool _might_ be helpful -- but sometimes it's impossible to fully trace the circuit. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 (For Sale) El Sobrante CA "aeonix1@mac.com" On Feb 5, 2009, at 8:09 PM, jburgessx2 wrote:
02-06-2009, 09:33
Lighting problem
On 2/6/2009 at 10:31 AM Pete Masterson wrote:
>Half or more of the fuses on my coach are the circuit breaker >type. Most of the rest are silver-canisters (that look a lot like the >circuit breaker type) Pete, those are self-resetting circuit breakers. |
02-06-2009, 11:29
Lighting problem
Try Ernie's solution first.
I have been behind those swithes a lot adding wires and butt connectors are all over the place back there. Bob Lawrence 84 PT36 Workcamping at Laguna Atascosa NWR Texas > I registered on this forum a few weeks back after we sold our Beaver > and bought this 85 PT40. I religously read the emails twice daily > and it appears there is a wealth of knowledge here. I think I need > some help now myself. I've fixed two plumbing problems and assorted > other things and still have a few to go. Here's my main problem > today: > > - Our 85 PT40 has the light switches above the front door to turn on > the light over the door and turn on the lights by the front curtains > on both sides. The other night the lights all went out and I haven't > been able to get them to turn on. > > - The little individual lights work as do the rest of them > throughout the coach. > > - I did take off all the switch plate covers and checked for loose > wires, all to no avail. > > - The lights did work sporadically, but I haven't been able to get > them to turn on in 2 days. > > Any ideas and help would be greatly appreciated. > > Thanks again. > > Jerry and Jayne > Full timing in our 85 PT40 > |
02-07-2009, 03:19
Lighting problem
02-07-2009, 03:23
Lighting problem
