Rebuilding 6V92
02-14-2009, 12:14
Rebuilding 6V92
Anyone with 6V92 engine or Detroit parts for rebuild please contact me.
Thanks Bill Garlen 84PT40 Jesup, Ga |
02-14-2009, 23:24
Rebuilding 6V92
Bill. Did you blow an engine too.
Paul Downey
Versailles Ky
83PT 35
In a message dated 2/14/2009 4:14:57 P.M. Pacific Standard Time, bill@... writes:
A Good Credit Score is 700 or Above. See yours in just 2 easy steps! |
02-16-2009, 01:47
Rebuilding 6V92
Paul,
Yes, I did. The engine was running fine and starting on first turn over but all of a sudden began poring water from the tubes. Bill Garlen Jesup, Ga 84PT40 --- In WanderlodgeForum@yahoogroups.com, antique405@... wrote: > > Bill. Did you blow an engine too. > > Paul Downey > Versailles Ky > 83PT 35 > > > In a message dated 2/14/2009 4:14:57 P.M. Pacific Standard Time, > bill@... writes: > > > > > Anyone with 6V92 engine or Detroit parts for rebuild please contact me. > > Thanks > Bill Garlen > 84PT40 > Jesup, Ga > > > > > > **************A Good Credit Score is 700 or Above. See yours in just 2 easy > steps! > (http://pr.atwola.com/promoclk/100126575x...67884/aol? redir=http://www.freecreditreport.com/pm/defau...sc=668072% 26hmpgID=62%26bcd=fe > bemailfooterNO62) > |
02-16-2009, 03:16
Rebuilding 6V92
Paul,
Did Ron Roberts from Brandon Florida ever contact you back about the two 6V92's that he had? Bill Garlen Jesup, Ga 84PT40 --- In WanderlodgeForum@yahoogroups.com, antique405@... wrote: > > Bill. Did you blow an engine too. > > Paul Downey > Versailles Ky > 83PT 35 > > > In a message dated 2/14/2009 4:14:57 P.M. Pacific Standard Time, > bill@... writes: > > > > > Anyone with 6V92 engine or Detroit parts for rebuild please contact me. > > Thanks > Bill Garlen > 84PT40 > Jesup, Ga > > > > > > **************A Good Credit Score is 700 or Above. See yours in just 2 easy > steps! > (http://pr.atwola.com/promoclk/100126575x...67884/aol? redir=http://www.freecreditreport.com/pm/defau...sc=668072% 26hmpgID=62%26bcd=fe > bemailfooterNO62) > |
02-16-2009, 03:17
Rebuilding 6V92
I bet selling the bus with the blown engine and using that15 to $18K
with the 15K it cost to do a rebuild would prove the same as picking up a gem at 30 grand. Greg of Tim&Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, "jesupbill" > > Paul, > Yes, I did. The engine was running fine and starting on first turn > over but all of a sudden began poring water from the tubes. > > Bill Garlen > Jesup, Ga > 84PT40 > > --- In WanderlodgeForum@yahoogroups.com, antique405@ wrote: > > > > Bill. Did you blow an engine too. > > > > Paul Downey > > Versailles Ky > > 83PT 35 > > > > > > In a message dated 2/14/2009 4:14:57 P.M. Pacific Standard Time, > > bill@ writes: > > > > > > > > > > Anyone with 6V92 engine or Detroit parts for rebuild please > contact me. > > > > Thanks > > Bill Garlen > > 84PT40 > > Jesup, Ga > > > > > > > > > > > > **************A Good Credit Score is 700 or Above. See yours in > just 2 easy > > steps! > > (http://pr.atwola.com/promoclk/100126575x...67884/aol? > redir=http://www.freecreditreport.com/pm/defau...sc=668072% > 26hmpgID=62%26bcd=fe > > bemailfooterNO62) > > > |
02-16-2009, 04:33
Rebuilding 6V92
Sounds like mine when I was on the road in Alberta. Engine running
perfect, then water dump. Have you discovered where the seals failed? R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "jesupbill" > > Paul, > Yes, I did. The engine was running fine and starting on first turn > over but all of a sudden began poring water from the tubes. > > Bill Garlen > Jesup, Ga > 84PT40 > > --- In WanderlodgeForum@yahoogroups.com, antique405@ wrote: > > > > Bill. Did you blow an engine too. > > > > Paul Downey > > Versailles Ky > > 83PT 35 > > > > > > In a message dated 2/14/2009 4:14:57 P.M. Pacific Standard Time, > > bill@ writes: > > > > > > > > > > Anyone with 6V92 engine or Detroit parts for rebuild please > contact me. > > > > Thanks > > Bill Garlen > > 84PT40 > > Jesup, Ga > > > > > > > > > > > > **************A Good Credit Score is 700 or Above. See yours in > just 2 easy > > steps! > > (http://pr.atwola.com/promoclk/100126575x...67884/aol? > redir=http://www.freecreditreport.com/pm/defau...sc=668072% > 26hmpgID=62%26bcd=fe > > bemailfooterNO62) > > > |
02-16-2009, 04:38
Rebuilding 6V92
When this happens, how rebuildable is the engine? Is it better to
buy a rebuilt or new engine? It seems a new engine runs about $15k and I'm not sure if that's the installed price. Did the engine have a lot of miles? Had it been overhauled before? Just curious since I'm unfamiliar with the Detroits and this is the first one I've owned (I'm used to the Cats). Jerry 85 PT40 Port Hueneme, CA --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > Sounds like mine when I was on the road in Alberta. Engine running > perfect, then water dump. Have you discovered where the seals failed? > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > --- In WanderlodgeForum@yahoogroups.com, "jesupbill" > > > > Paul, > > Yes, I did. The engine was running fine and starting on first turn > > over but all of a sudden began poring water from the tubes. > > > > Bill Garlen > > Jesup, Ga > > 84PT40 > > > > --- In WanderlodgeForum@yahoogroups.com, antique405@ wrote: > > > > > > Bill. Did you blow an engine too. > > > > > > Paul Downey > > > Versailles Ky > > > 83PT 35 > > > > > > > > > In a message dated 2/14/2009 4:14:57 P.M. Pacific Standard Time, > > > bill@ writes: > > > > > > > > > > > > > > > Anyone with 6V92 engine or Detroit parts for rebuild please > > contact me. > > > > > > Thanks > > > Bill Garlen > > > 84PT40 > > > Jesup, Ga > > > > > > > > > > > > > > > > > > **************A Good Credit Score is 700 or Above. See yours in > > just 2 easy > > > steps! > > > (http://pr.atwola.com/promoclk/100126575x...67884/aol? > > redir=http://www.freecreditreport.com/pm/defau...sc=668072% > > 26hmpgID=62%26bcd=fe > > > bemailfooterNO62) > > > > > > |
02-16-2009, 06:33
Rebuilding 6V92
Bill. He did contact me but his engines are left hand engines. Paul
In a message dated 2/16/2009 7:16:44 A.M. Pacific Standard Time, bill@... writes:
02-16-2009, 06:37
Rebuilding 6V92
Bill. Do you know what damage you did to the engine. They pulled the pan on mine and found the number one main had spun. You may do an in frame if the crank is not bad. Paul
In a message dated 2/16/2009 5:47:25 A.M. Pacific Standard Time, bill@... writes:
02-16-2009, 07:56
Rebuilding 6V92
That 15K does not include removal and reinstall. I chose to do an
in-frame overhaul. Total cost at 23K, but it was done in Canada. Might have been a little cheaper here, but I doubt it very much. Mine was complete with new heads, new blower, cylinder kits, etc. They kept the block and crank. I had 190,000 miles on it. Since mine was an 8V92 yours might be a little less. If yours was shut-down just after starting, I doubt that yours was damaged like mine. Mine was up at full temperature and seized up because of no way to dissipate the heat in the engine. There did not appear to be any cost saving by purchasing a re-built and it would have taken 6 weeks to get one. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "jburgessx2" wrote: > > When this happens, how rebuildable is the engine? Is it better to > buy a rebuilt or new engine? It seems a new engine runs about $15k > and I'm not sure if that's the installed price. > > Did the engine have a lot of miles? Had it been overhauled before? > Just curious since I'm unfamiliar with the Detroits and this is the > first one I've owned (I'm used to the Cats). > > Jerry > 85 PT40 > Port Hueneme, CA > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > > > > Sounds like mine when I was on the road in Alberta. Engine running > > perfect, then water dump. Have you discovered where the seals > failed? > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > --- In WanderlodgeForum@yahoogroups.com, "jesupbill" > > > > > > Paul, > > > Yes, I did. The engine was running fine and starting on first > turn > > > over but all of a sudden began poring water from the tubes. > > > > > > Bill Garlen > > > Jesup, Ga > > > 84PT40 > > > > > > --- In WanderlodgeForum@yahoogroups.com, antique405@ wrote: > > > > > > > > Bill. Did you blow an engine too. > > > > > > > > Paul Downey > > > > Versailles Ky > > > > 83PT 35 > > > > > > > > > > > > In a message dated 2/14/2009 4:14:57 P.M. Pacific Standard > Time, > > > > bill@ writes: > > > > > > > > > > > > > > > > > > > > Anyone with 6V92 engine or Detroit parts for rebuild please > > > contact me. > > > > > > > > Thanks > > > > Bill Garlen > > > > 84PT40 > > > > Jesup, Ga > > > > > > > > > > > > > > > > > > > > > > > > **************A Good Credit Score is 700 or Above. See yours in > > > just 2 easy > > > > steps! > > > > > (http://pr.atwola.com/promoclk/100126575x...67884/aol? > > > redir=http://www.freecreditreport.com/pm/defau...sc=668072% > > > 26hmpgID=62%26bcd=fe > > > > bemailfooterNO62) > > > > > > > > > > |
