Tire Shopping
06-04-2005, 15:06
Post: #31
Tire Shopping
The differences between the XZ2 and the XZE are that the XZE is a long-
haul all-position tire, the XZ2 is also, but considered their premium steer tire. The XZ2 has a de-coupling groove to prevent uneven wear at the edge of the tire (significant on the steer axle), and a pretty much straight groove tread with sipes for traction, very quiet. The XZE has a more conventional zig-zag tread which potentially could sing more. Last and most significant is the XZE tread is deeper, which could potentially cause more tread squirm while driving and reduce response/control somewhat. In discussing these differences with an Engineer at Michelin, it was agreed that although the XZ2 is clearly the best choice for the steer axle, the XZE would serve as well on the drive and tag axles. For a coach, the quietest and best-response tires all-around are probably the best choice however, which favors the XZ2. - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, "pattypape" wrote: > > Thanks again, > > In further reviewing tire mfg. web sites, Jeff makes a good point > about the different spec. for the same sizes and load ranges for the > different mfg. > Michelin has a XZ2 and a XZE model, > Does anyone know the difference?? > The spec.s seem to be about the same. > > Bill 88 FC I like the tire debate, still deciding to decide, > can't find FarmKing in Michigan |
06-04-2005, 23:18
Post: #32
Tire Shopping
Jeff, Will you be in Frankenmuth??
Thanks for the explaination.Will decide and order late summer/fall. Will replace the steer tires first, depending on this outcome, the rears get replaced, next year. ( Long term tire planning) Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > The differences between the XZ2 and the XZE are that the XZE is a long- > haul all-position tire, the XZ2 is also, but considered their premium > steer tire. The XZ2 has a de-coupling groove to prevent uneven wear at > the edge of the tire (significant on the steer axle), and a pretty much > straight groove tread with sipes for traction, very quiet. The XZE has > a more conventional zig-zag tread which potentially could sing more. > Last and most significant is the XZE tread is deeper, which could > potentially cause more tread squirm while driving and reduce > response/control somewhat. > > In discussing these differences with an Engineer at Michelin, it was > agreed that although the XZ2 is clearly the best choice for the steer > axle, the XZE would serve as well on the drive and tag axles. For a > coach, the quietest and best-response tires all-around are probably the > best choice however, which favors the XZ2. > > - Jeff Miller > > > --- In WanderlodgeForum@yahoogroups.com, "pattypape" > wrote: > > > > Thanks again, > > > > In further reviewing tire mfg. web sites, Jeff makes a good point > > about the different spec. for the same sizes and load ranges for the > > different mfg. > > Michelin has a XZ2 and a XZE model, > > Does anyone know the difference?? > > The spec.s seem to be about the same. > > > > Bill 88 FC I like the tire debate, still deciding to decide, > > can't find FarmKing in Michigan |
06-06-2005, 16:45
Post: #33
Tire Shopping
Just wondering what people are getting for the old tires?
Troy, 83 FC33 --- In WanderlodgeForum@yahoogroups.com, randydupree > i just bought 12-22.5 toyos today for $400 each..randydupree93wb > ----- Original Message ----- > From: pattypape > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, June 03, 2005 8:03 PM > Subject: [WanderlodgeForum] Tire Shopping > > > Well, I am still investigating possible tire replacement brands. I > read many of the previous archive postings on the ongoing tire > debate. Many have a strong opinion about there favorite tire > manufacturer, especially the loyal Michelin followers. There were > also other brands mentioned such as: Kelly, Goodyear, BF Goodrich, > Toyo, a Les Schwab tire called Double Coin, Bridgestone etc. > > The 12R 22.5 load range H Michelin tires are about $500.00 each, > installed and out the door. > They carry a seven year / 700,000 mile manufacturer defect warranty. > > We presently are quite happy with our Firestone T575 tire. This tire > is obsolete and no longer manufactured, the replacement Firestone is > FS560 or Bridgestone R250 > > Our questions are: > Does anyone have experience with the Firestone FS560?? ( In the 12R > 22.5 LRH size) > Why should an RV owner help subsidize a seven year / 700,000 > warranty?? > Which brand are you happy with ?? > > Maybe this should be a poll? > > Any inputs are appreciated, > > Bill 88 fc > > > > > > > ------------------------------------------------------------------------------ > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] |
06-06-2005, 22:28
Post: #34
Tire Shopping
Tires over 5 years old are planters. They can't be re-capped.
My Michelins had great tread and I paid 4 bucks apiece for proper disposal. George Witt 81 FC 35 Lincoln, Nebraska --- In WanderlodgeForum@yahoogroups.com, "ttikalsky" wrote: > Just wondering what people are getting for the old tires? > > Troy, 83 FC33 > > --- In WanderlodgeForum@yahoogroups.com, randydupree > > i just bought 12-22.5 toyos today for $400 each..randydupree93wb > > ----- Original Message ----- > > From: pattypape > > To: WanderlodgeForum@yahoogroups.com > > Sent: Friday, June 03, 2005 8:03 PM > > Subject: [WanderlodgeForum] Tire Shopping > > > > > > Well, I am still investigating possible tire replacement brands. I > > read many of the previous archive postings on the ongoing tire > > debate. Many have a strong opinion about there favorite tire > > manufacturer, especially the loyal Michelin followers. There were > > also other brands mentioned such as: Kelly, Goodyear, BF Goodrich, > > Toyo, a Les Schwab tire called Double Coin, Bridgestone etc. > > > > The 12R 22.5 load range H Michelin tires are about $500.00 each, > > installed and out the door. > > They carry a seven year / 700,000 mile manufacturer defect warranty. > > > > We presently are quite happy with our Firestone T575 tire. This tire > > is obsolete and no longer manufactured, the replacement Firestone is > > FS560 or Bridgestone R250 > > > > Our questions are: > > Does anyone have experience with the Firestone FS560?? ( In the 12R > > 22.5 LRH size) > > Why should an RV owner help subsidize a seven year / 700,000 > > warranty?? > > Which brand are you happy with ?? > > > > Maybe this should be a poll? > > > > Any inputs are appreciated, > > > > Bill 88 fc > > > > > > > > > > > > > > > ------------------------------------------------------------------------------ > > Yahoo! Groups Links > > > > a.. To visit your group on the web, go to: > > http://groups.yahoo.com/group/WanderlodgeForum/ > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service. > > > > > > > > [Non-text portions of this message have been removed] |
06-06-2005, 23:07
Post: #35
Tire Shopping
george,in fl. they don't take tires that are over 3 years old.not even the
recappers.if you get lucky you can find a log truck that will buy them..randydupree93wb ----- Original Message ----- From: mrdonut12 To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, June 07, 2005 6:28 AM Subject: [WanderlodgeForum] Re: Tire Shopping Tires over 5 years old are planters. They can't be re-capped. My Michelins had great tread and I paid 4 bucks apiece for proper disposal. George Witt 81 FC 35 Lincoln, Nebraska --- In WanderlodgeForum@yahoogroups.com, "ttikalsky" wrote: > Just wondering what people are getting for the old tires? > > Troy, 83 FC33 > > --- In WanderlodgeForum@yahoogroups.com, randydupree > > i just bought 12-22.5 toyos today for $400 each..randydupree93wb > > ----- Original Message ----- > > From: pattypape > > To: WanderlodgeForum@yahoogroups.com > > Sent: Friday, June 03, 2005 8:03 PM > > Subject: [WanderlodgeForum] Tire Shopping > > > > > > Well, I am still investigating possible tire replacement brands. I > > read many of the previous archive postings on the ongoing tire > > debate. Many have a strong opinion about there favorite tire > > manufacturer, especially the loyal Michelin followers. There were > > also other brands mentioned such as: Kelly, Goodyear, BF Goodrich, > > Toyo, a Les Schwab tire called Double Coin, Bridgestone etc. > > > > The 12R 22.5 load range H Michelin tires are about $500.00 each, > > installed and out the door. > > They carry a seven year / 700,000 mile manufacturer defect warranty. > > > > We presently are quite happy with our Firestone T575 tire. This tire > > is obsolete and no longer manufactured, the replacement Firestone is > > FS560 or Bridgestone R250 > > > > Our questions are: > > Does anyone have experience with the Firestone FS560?? ( In the 12R > > 22.5 LRH size) > > Why should an RV owner help subsidize a seven year / 700,000 > > warranty?? > > Which brand are you happy with ?? > > > > Maybe this should be a poll? > > > > Any inputs are appreciated, > > > > Bill 88 fc > > > > > > > > > > > > > > > ------------------------------------------------------------------------------ > > Yahoo! Groups Links > > > > a.. To visit your group on the web, go to: > > http://groups.yahoo.com/group/WanderlodgeForum/ > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service. > > > > > > > > [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-09-2005, 12:57
Post: #36
Tire Shopping
Is there a market for old tires?Jon
Jon Lechich 1978 Wanderlodge Bremerton Washington ttikalsky Just wondering what people are getting for the old tires? Troy, 83 FC33 --- In WanderlodgeForum@yahoogroups.com, randydupree wrote: > i just bought 12-22.5 toyos today for $400 each..randydupree93wb > ----- Original Message ----- > From: pattypape > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, June 03, 2005 8:03 PM > Subject: [WanderlodgeForum] Tire Shopping > > > Well, I am still investigating possible tire replacement brands. I > read many of the previous archive postings on the ongoing tire > debate. Many have a strong opinion about there favorite tire > manufacturer, especially the loyal Michelin followers. There were > also other brands mentioned such as: Kelly, Goodyear, BF Goodrich, > Toyo, a Les Schwab tire called Double Coin, Bridgestone etc. > > The 12R 22.5 load range H Michelin tires are about $500.00 each, > installed and out the door. > They carry a seven year / 700,000 mile manufacturer defect warranty. > > We presently are quite happy with our Firestone T575 tire. This tire > is obsolete and no longer manufactured, the replacement Firestone is > FS560 or Bridgestone R250 > > Our questions are: > Does anyone have experience with the Firestone FS560?? ( In the 12R > 22.5 LRH size) > Why should an RV owner help subsidize a seven year / 700,000 > warranty?? > Which brand are you happy with ?? > > Maybe this should be a poll? > > Any inputs are appreciated, > > Bill 88 fc > > > > > > > ------------------------------------------------------------------------------ > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] Yahoo! Groups Links One of my favorite sayings goes! "You never own anything, everything owns you!" __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
06-09-2005, 12:58
Post: #37
Tire Shopping
Sure, in Mexico for sandles........Blair
At 05:57 PM 6/9/2005, you wrote: >Is there a market for old tires?Jon >Jon Lechich >1978 Wanderlodge >Bremerton Washington > >ttikalsky >Just wondering what people are getting for the old tires? > >Troy, 83 FC33 > >--- In WanderlodgeForum@yahoogroups.com, randydupree wrote: > > i just bought 12-22.5 toyos today for $400 each..randydupree93wb > > ----- Original Message ----- > > From: pattypape > > To: WanderlodgeForum@yahoogroups.com > > Sent: Friday, June 03, 2005 8:03 PM > > Subject: [WanderlodgeForum] Tire Shopping > > > > > > Well, I am still investigating possible tire replacement brands. I > > read many of the previous archive postings on the ongoing tire > > debate. Many have a strong opinion about there favorite tire > > manufacturer, especially the loyal Michelin followers. There were > > also other brands mentioned such as: Kelly, Goodyear, BF Goodrich, > > Toyo, a Les Schwab tire called Double Coin, Bridgestone etc. > > > > The 12R 22.5 load range H Michelin tires are about $500.00 each, > > installed and out the door. > > They carry a seven year / 700,000 mile manufacturer defect warranty. > > > > We presently are quite happy with our Firestone T575 tire. This tire > > is obsolete and no longer manufactured, the replacement Firestone is > > FS560 or Bridgestone R250 > > > > Our questions are: > > Does anyone have experience with the Firestone FS560?? ( In the 12R > > 22.5 LRH size) > > Why should an RV owner help subsidize a seven year / 700,000 > > warranty?? > > Which brand are you happy with ?? > > > > Maybe this should be a poll? > > > > Any inputs are appreciated, > > > > Bill 88 fc > > > > > > > > > > > > > > >------------------------------------------------------------------------------ > > Yahoo! Groups Links > > > > a.. To visit your group on the web, go to: > > > <http://groups.yahoo.com/group/WanderlodgeForum/>http://groups.yahoo.com/group/W\ anderlodgeForum/ > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of >Service. > > > > > > > > [Non-text portions of this message have been removed] > > > > > > >Yahoo! Groups Links > > > > > > > > > >One of my favorite sayings goes! "You never own anything, everything owns >you!" > > > > >__________________________________________________ >Do You Yahoo!? >Tired of spam? Yahoo! Mail has the best spam protection around ><http://mail.yahoo.com>http://mail.yahoo.com > >[Non-text portions of this message have been removed] > > > >---------- >Yahoo! Groups Links > * To visit your group on the web, go to: > * > <http://groups.yahoo.com/group/WanderlodgeForum/>http://groups.yahoo.com/group/W\ anderlodgeForum/ > > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-09-2005, 13:06
Post: #38
Tire Shopping
How about using to start fires under old tree stumps! Do you think the EPA would
mind? Jon Blair At 05:57 PM 6/9/2005, you wrote: >Is there a market for old tires?Jon >Jon Lechich >1978 Wanderlodge >Bremerton Washington > >ttikalsky wrote: >Just wondering what people are getting for the old tires? > >Troy, 83 FC33 > >--- In WanderlodgeForum@yahoogroups.com, randydupree wrote: > > i just bought 12-22.5 toyos today for $400 each..randydupree93wb > > ----- Original Message ----- > > From: pattypape > > To: WanderlodgeForum@yahoogroups.com > > Sent: Friday, June 03, 2005 8:03 PM > > Subject: [WanderlodgeForum] Tire Shopping > > > > > > Well, I am still investigating possible tire replacement brands. I > > read many of the previous archive postings on the ongoing tire > > debate. Many have a strong opinion about there favorite tire > > manufacturer, especially the loyal Michelin followers. There were > > also other brands mentioned such as: Kelly, Goodyear, BF Goodrich, > > Toyo, a Les Schwab tire called Double Coin, Bridgestone etc. > > > > The 12R 22.5 load range H Michelin tires are about $500.00 each, > > installed and out the door. > > They carry a seven year / 700,000 mile manufacturer defect warranty. > > > > We presently are quite happy with our Firestone T575 tire. This tire > > is obsolete and no longer manufactured, the replacement Firestone is > > FS560 or Bridgestone R250 > > > > Our questions are: > > Does anyone have experience with the Firestone FS560?? ( In the 12R > > 22.5 LRH size) > > Why should an RV owner help subsidize a seven year / 700,000 > > warranty?? > > Which brand are you happy with ?? > > > > Maybe this should be a poll? > > > > Any inputs are appreciated, > > > > Bill 88 fc > > > > > > > > > > > > > > >------------------------------------------------------------------------------ > > Yahoo! Groups Links > > > > a.. To visit your group on the web, go to: > > > http://groups.yahoo.com/group/WanderlodgeForum/ > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of >Service. > > > > > > > > [Non-text portions of this message have been removed] > > > > > > >Yahoo! Groups Links > > > > > > > > > >One of my favorite sayings goes! "You never own anything, everything owns >you!" > > > > >__________________________________________________ >Do You Yahoo!? >Tired of spam? Yahoo! Mail has the best spam protection around >http://mail.yahoo.com > >[Non-text portions of this message have been removed] > > > >---------- >Yahoo! Groups Links > * To visit your group on the web, go to: > * > http://groups.yahoo.com/group/WanderlodgeForum/ > > * > * To unsubscribe from this group, send an email to: > * > WanderlodgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > Yahoo! Terms of Service. [Non-text portions of this message have been removed] Yahoo! Groups Links One of my favorite sayings goes! "You never own anything, everything owns you!" __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
06-09-2005, 13:07
Post: #39
Tire Shopping
not much down here in the hot,sunny south..nobody buys them if they are over 3
years old. randydupree93wb ----- Original Message ----- From: jon lechich To: WanderlodgeForum@yahoogroups.com Sent: Thursday, June 09, 2005 8:57 PM Subject: Re: [WanderlodgeForum] Re: Tire Shopping Is there a market for old tires?Jon Jon Lechich 1978 Wanderlodge Bremerton Washington ttikalsky Just wondering what people are getting for the old tires? Troy, 83 FC33 --- In WanderlodgeForum@yahoogroups.com, randydupree wrote: > i just bought 12-22.5 toyos today for $400 each..randydupree93wb > ----- Original Message ----- > From: pattypape > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, June 03, 2005 8:03 PM > Subject: [WanderlodgeForum] Tire Shopping > > > Well, I am still investigating possible tire replacement brands. I > read many of the previous archive postings on the ongoing tire > debate. Many have a strong opinion about there favorite tire > manufacturer, especially the loyal Michelin followers. There were > also other brands mentioned such as: Kelly, Goodyear, BF Goodrich, > Toyo, a Les Schwab tire called Double Coin, Bridgestone etc. > > The 12R 22.5 load range H Michelin tires are about $500.00 each, > installed and out the door. > They carry a seven year / 700,000 mile manufacturer defect warranty. > > We presently are quite happy with our Firestone T575 tire. This tire > is obsolete and no longer manufactured, the replacement Firestone is > FS560 or Bridgestone R250 > > Our questions are: > Does anyone have experience with the Firestone FS560?? ( In the 12R > 22.5 LRH size) > Why should an RV owner help subsidize a seven year / 700,000 > warranty?? > Which brand are you happy with ?? > > Maybe this should be a poll? > > Any inputs are appreciated, > > Bill 88 fc > > > > > > > ------------------------------------------------------------------------------ > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] Yahoo! Groups Links One of my favorite sayings goes! "You never own anything, everything owns you!" __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-09-2005, 13:11
Post: #40
Tire Shopping
I'd have to answer you from jail.......that's a real no - no around here,
not to say it isn't done....I just saturate the whole area with a couple hundred gallons of diesel fuel and lite it off.......'course the neighboring trees get pretty scorched.... blair We did light up a stack of stumps a couple of years ago. Probably no less than 15 mansanita stumps full of dirt and junk and piled well of 12 feet high.....took a day to get it going and it burned for three weeks.... At 06:06 PM 6/9/2005, you wrote: >How about using to start fires under old tree stumps! Do you think the EPA >would mind? Jon > >Blair > > > >At 05:57 PM 6/9/2005, you wrote: > >Is there a market for old tires?Jon > >Jon Lechich > >1978 Wanderlodge > >Bremerton Washington > > > >ttikalsky wrote: > >Just wondering what people are getting for the old tires? > > > >Troy, 83 FC33 > > > >--- In WanderlodgeForum@yahoogroups.com, randydupree wrote: > > > i just bought 12-22.5 toyos today for $400 each..randydupree93wb > > > ----- Original Message ----- > > > From: pattypape > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Friday, June 03, 2005 8:03 PM > > > Subject: [WanderlodgeForum] Tire Shopping > > > > > > > > > Well, I am still investigating possible tire replacement brands. I > > > read many of the previous archive postings on the ongoing tire > > > debate. Many have a strong opinion about there favorite tire > > > manufacturer, especially the loyal Michelin followers. There were > > > also other brands mentioned such as: Kelly, Goodyear, BF Goodrich, > > > Toyo, a Les Schwab tire called Double Coin, Bridgestone etc. > > > > > > The 12R 22.5 load range H Michelin tires are about $500.00 each, > > > installed and out the door. > > > They carry a seven year / 700,000 mile manufacturer defect warranty. > > > > > > We presently are quite happy with our Firestone T575 tire. This tire > > > is obsolete and no longer manufactured, the replacement Firestone is > > > FS560 or Bridgestone R250 > > > > > > Our questions are: > > > Does anyone have experience with the Firestone FS560?? ( In the 12R > > > 22.5 LRH size) > > > Why should an RV owner help subsidize a seven year / 700,000 > > > warranty?? > > > Which brand are you happy with ?? > > > > > > Maybe this should be a poll? > > > > > > Any inputs are appreciated, > > > > > > Bill 88 fc > > > > > > > > > > > > > > > > > > > > > > >------------------------------------------------------------------------- > ----- > > > Yahoo! Groups Links > > > > > > a.. To visit your group on the web, go to: > > > > > > <http://groups.yahoo.com/group/WanderlodgeForum/>http://groups.yahoo.com/group/W\ anderlodgeForum/ > > > > > > b.. To unsubscribe from this group, send an email to: > > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of > >Service. > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > >One of my favorite sayings goes! "You never own anything, everything owns > >you!" > > > > > > > > > >__________________________________________________ > >Do You Yahoo!? > >Tired of spam? Yahoo! Mail has the best spam protection around > ><http://mail.yahoo.com>http://mail.yahoo.com > > > >[Non-text portions of this message have been removed] > > > > > > > >---------- > >Yahoo! Groups Links > > * To visit your group on the web, go to: > > * > > > <http://groups.yahoo.com/group/WanderlodgeForum/>http://groups.yahoo.com/group/W\ anderlodgeForum/ > > > > > * > > * To unsubscribe from this group, send an email to: > > * > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > * > > * Your use of Yahoo! Groups is subject to the > > Yahoo! Terms of Service. > > >[Non-text portions of this message have been removed] > > > > > >Yahoo! Groups Links > > > > > > > > > >One of my favorite sayings goes! "You never own anything, everything owns >you!" > > > > >__________________________________________________ >Do You Yahoo!? >Tired of spam? Yahoo! Mail has the best spam protection around ><http://mail.yahoo.com>http://mail.yahoo.com > >[Non-text portions of this message have been removed] > > > >---------- >Yahoo! Groups Links > * To visit your group on the web, go to: > * > <http://groups.yahoo.com/group/WanderlodgeForum/>http://groups.yahoo.com/group/W\ anderlodgeForum/ > > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
