Sound- absorption or reflection
02-21-2009, 04:16
if you look at the newer generators the sound deadening box has
baffled vents and is sealed as well as sound deadening
materials,thermostatically controlled fans and a smaller new motor
with indirect indirect injection. With all these it makes for a
quieter generator
Stephen 77fc35
--- In WanderlodgeForum@yahoogroups.com, Ernie Ekberg
> Jim, while the some of the noise was deflected down, 30 more db was
reflected to the front of the radiator. Bob's coach has the front
fan/radiator.
> Ernie Ekberg
> 83PT40
> Wanderlodge
> Weatherford, Tx
> --- On Fri, 2/20/09, jim riordan wrote:
> From: jim riordan
> Subject: Re: [WanderlodgeForum] Sound- absorption or reflection
> Date: Friday, February 20, 2009, 10:01 PM
> I would assume that the sound deading material used in these
generator compartments actually reflect the nooise down. so the noie
is forced under the coaches. Many boats and I belive that some new
coaches now have a box lined with sound deading which the generator is
placed.
> just a thought
> jim riordan
> 88 wbwl xxv
> stuart fl
> --- On Fri, 2/20/09, Ernest Ekberg wrote:
> From: Ernest Ekberg
> Subject: [WanderlodgeForum] Sound- absorption or reflection
> To: WanderlodgeForum@ yahoogroups. com
> Date: Friday, February 20, 2009, 7:43 PM
> After installing many generator compartments with the new insulation, I
> was wondering if there is a manufacturer that offers both.
> I insulated Bob Lawrences' generator compartment last December. He
> measured the db levels before and after and found that while the heat
> was reflected from the interior of the coach, the sound was also
> deflected to the outside. thus his db levels INCREASED to over 90.
> I know my with my coach, that I have been asked to park way downwind as
> my generator is really loud. Maybe its the dogs I carry with me???
> But, if there is a product that will absorb that sound while reflecting
> the heat, let's talk about it.
> Ernie-83PT40 in Texas, buying earplugs by the case~
02-21-2009, 04:38
Ernie
Any insulation that's smooth is going to reflect the sound. In order
to absorb the sound you need a material with a 3 dimensional contour,
like an egg carton. You need the sort of material used in an anechoic
chamber.
http://en.wikipedia.org/wiki/Anechoic_chamber
The basic idea is that the cones cause reflections that destructively
interfere with the incoming sound waves; i.e., the reflections cancel
out the noise. The dimension of the cone is on the order of the
wavelength of the noise that you're trying to cancel.
The LXi uses a material very similar to what's shown in the above
wikipedia page. People walk by the outside of the genny and don't
even notice that it's on.
David Brady
'02 LXi, NC
-----Original Message-----
Sent: Feb 21, 2009 11:16 AM
Subject: [WanderlodgeForum] Re: Sound- absorption or reflection
quieter generator
Stephen 77fc35
--- In "WanderlodgeForum%40yahoogroups.com", Ernie Ekberg .>
fan/radiator.
> Ernie Ekberg
> 83PT40
> Wanderlodge
> Weatherford, Tx
> http://autos.groups.yahoo.com/group/erniesremodelingandrepair
> From: jim riordan
placed.
> just a thought
> jim riordan
> 88 wbwl xxv
> stuart fl
> From: Ernest Ekberg
02-21-2009, 04:48
I havw ONAN RS12000(12K)unit outside my bedroom window (10 Ft) and can not hear it when it is running. Insulation is a 1" thick sponge with reflecting face sheet that is lined inside of the box that the generator
sits in. Works well cant tell you how many times I have awaken in the morning to find that the power was off for 6 hours or so
Scooter 2000LX Ocqueoc, MI
Date: Fri, 20 Feb 2009 20:01:40 -0800
I would assume that the sound deading material used in these generator compartments actually reflect the nooise down. so the noie is forced under the coaches. Many boats and I belive that some new coaches now have a box lined with sound deading which the generator is placed.
just a thought
jim riordan
88 wbwl xxv
stuart fl
02-21-2009, 06:30
Ernie - Thomasnet lists several acoustical foam suppliers near you
(Dallas, Garland, Desoto). You might try them. Here's the list:
http://tiny.cc/Ae7Up
Bob McLaughlin
Wannabe
> I wonder how an individual would purchase this?
> Ernie Ekberg
> 83PT40
> Wanderlodge
> Weatherford, Tx
02-21-2009, 06:35
Last year I insulated the doghouse of our 1983FC doghouse with 2" 2#/ft. sq.
fiberglass
and lead material that I purchased from Soundown. I followed the instructions
provided
by their rep Gary Kissal and am very happy with the results.
I have been speaking with Gary on how best to quiet down the 12.5 Yanmar/Kohler
he suggested several things:
To quiet outside noise, create a baffle between the fan and the exhaust louvers.
To quiet inside:
1. Apply mechanical fasteners to all surfaces to be covered
2. Apply adhesive damping material against the metal inside the generator
compartment.
"Soundown Vibration Damping Sheets and Tiles are a high performance, easily
applied,
extensional vibration dampers for reducing structural reverberant "ringing" and
structureborne noise. This material is effective on a wide range of substrates,
especially
fiberglass, aluminum, and steel. Soundown Damping Sheets are available in 1/16",
1/8",
1/4" at 54" width, and in 1'x 1' tiles in 3/8" and 1/2". We also stock a
complete line of
interlayer damping materials for many applications."
3. Apply 2" 2# ft./sq. composite insulation onto the damping material using both
mechanical fasteners and adhesive.
"Soundown's Mass Loaded Vinyl Barrier (Tuff Mass®) is available in 1/2, 1,
1-1/2, and 2
lb/ft2 densities. It is a rugged all-purpose sheet barrier with a wide range of
uses. Our
Mass Loaded Vinyl is supplied in a standard 54" and 48" width and variable roll
lengths
from 10' to 250' depending upon material configuration. Soundown Acoustic Lead
Barrier
is available in weights of 1 and 2 lb. This traditional incombustible barrier
material is
supplied in a standard 48" width, and rolls of 12', 24', or longer as required."
I have no material interest in the company other than being a very satisfied
customer.
Their exclusive function is to quiet things down and they have been doing it for
a very
long time with very expensive marine craft, and high end structures.
Here is a link to their web site. http://www.soundown.com/AI.htm#
Garry Kissal's e-,mail is gkissal@...
In lieu of the baffle which I think will be too much work, I plan to install a
quiet plastic
DC fan to the radiator (like in a car) and an aqua-stat that will keep the big
AC fan off
until higher temps are reached. I suspect this will help a lot and much of the
time we
run our genset at way less than half load.
Another factor is the use of a ProSine 2K inverter that also helps to minimize
gen run
time.
NH Bill 1983 FC "Casa Billisa"
> quieter generator
> Stephen 77fc35
> fan/radiator.
> > Ernie Ekberg
> > 83PT40
> > Wanderlodge
> > Weatherford, Tx
> > From: jim riordan
> placed.
> > just a thought
> > jim riordan
> > 88 wbwl xxv
> > stuart fl
> > From: Ernest Ekberg
02-21-2009, 06:46
Thanks, Bill, very good information. The worst part of the generators that some of us have is that the fan is belt driven off the engine.
83PT40
Wanderlodge
Date: Saturday, February 21, 2009, 12:35 PM
Last year I insulated the doghouse of our 1983FC doghouse with 2" 2#/ft. sq. fiberglass
and lead material that I purchased from Soundown. I followed the instructions provided
I have been speaking with Gary on how best to quiet down the 12.5 Yanmar/Kohler and
To quiet inside:
2. Apply adhesive damping material against the metal inside the generator compartment.
"Soundown Vibration Damping Sheets and Tiles are a high performance, easily applied,
structureborne noise. This material is effective on a wide range of substrates, especially
Damping Sheets are available in 1/16", 1/8",
1/4" at 54" width, and in 1'x 1' tiles in 3/8" and 1/2". We also stock a complete line of
interlayer damping materials for many applications. "
3. Apply 2" 2# ft./sq. composite insulation onto the damping material using both mechanical fasteners and adhesive.
"Soundown's Mass Loaded Vinyl Barrier (Tuff Mass®) is available in 1/2, 1, 1-1/2, and 2
lb/ft2 densities. It is a rugged all-purpose sheet barrier with a wide range of uses. Our
Mass Loaded Vinyl is supplied in a standard 54" and 48" width and variable roll lengths
from 10' to 250' depending upon material configuration. Soundown Acoustic Lead Barrier
is available in weights of 1 and 2 lb. This traditional incombustible barrier material is
I have no material interest in the company other than being a very satisfied customer.
Their exclusive function is to quiet things down and they have been doing it for a very
Here is a link to their web site. http://www.soundown .com/AI.htm#
Garry Kissal's e-,mail is "gkissal%40soundown.com"
In lieu of the baffle which I think will be too much work, I plan to install a quiet plastic
DC fan to the radiator (like in a car) and an aqua-stat that will keep the big AC fan off
until higher temps are reached. I suspect this will help a lot and much of the time we
Another factor is the use of a ProSine 2K inverter that also helps to minimize gen run
time.
> materials,thermosta tically controlled fans and a smaller new motor
> quieter generator
> Stephen 77fc35
> fan/radiator.
> > Ernie
Ekberg
> > 83PT40
> > Wanderlodge
> > Weatherford, Tx
> > http://autos. groups.yahoo. com/group/ erniesremodeling andrepair
> > From: jim riordan
the noie
> placed.
> > just a thought
> > jim riordan
> > 88 wbwl xxv
> > stuart fl
> > From: Ernest Ekberg
02-21-2009, 08:33
I tried a little different approach to the fan noise on our FC. I scouted the local salvage yards and found a fan and viscous clutch that would fit the electric fan motor. It reduced the fan noise greatly and I still have some air flow through the genset area to keep the heat down. I have only heard it fully engage a couple of times while we were at a rest area on interstate 8 and it was 109 degrees outside.
- Chuck Wheeler-
1982 FC 31SB Fort Worth TX
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Ernie Ekberg
Sent: Saturday, February 21, 2009 12:46 PM
Subject: Re: [WanderlodgeForum] Re: Sound- absorption or reflection
83PT40
Wanderlodge
To quiet inside:
fiberglass, aluminum, and steel. Soundown Damping Sheets are available in 1/16", 1/8",
"Soundown's Mass Loaded Vinyl Barrier (Tuff Mass®Wink is available in 1/2, 1, 1-1/2, and 2
time.
> quieter generator
> Stephen 77fc35
> fan/radiator.
> > Ernie Ekberg
> > 83PT40
> > Wanderlodge
> > Weatherford, Tx
> > From: jim riordan
> placed.
> > just a thought
> > jim riordan
> > 88 wbwl xxv
> > stuart fl
> > From: Ernest Ekberg
02-21-2009, 16:38
Not too far fetched. My cummins engine computer is cooled with
diesel fuel. I am just curious where you were transfering heat to
with your 'insulation heat dissipation remanufacture redesign'
heat is transfered and lost to other objects. for one thing to lose
heat somthing else must take it. its a calorie calc. when you
insulate to keep heat from the interior of the bus where does that
heat now go?
some times when an interior gets hot and calls for modification it
is an overlooked sign that the heat producer has other issues causing
excessive heat. KurtH can atest. in a genset the genhead may be
cooking or engine exhaust is screwed up.
Greg ofTim&Greg
94ptca
> why thank you for the mindless dribble another useless comment
> Stephen 77fc35
> --- In WanderlodgeForum@yahoogroups.com, "timvasqz" wrote:
> > To disipate heat, is to transfer it. Steve maybe you can disapate
it
> > thru a dupree valve back to the tank? Call it Hot$$$$ ?
> > I understand that the vault gets up to +250 degrees(USA). I
guess
> > that is a factor for Ernie to consider once he removed the
disipation
> > path of the vault heat to the bus interior. where does that
heat
> > now go.
> > Insulation keeps environments from disapating heat. heat is
removed
> > so the method to remove the heat in the compartment would now be
> > radiator system and the diesel engine is the heat sink, but the
> > diesel engine caused most of the heat. If the origional design
was
> > not intended to do that it would have to be beefed up
> > If you insulate the exhaust the otherwise exposed metal does not
> > radiate heat in the compartment. heat goes out the stack with the
> > exhast air. But is the stack able to take all the extra heat.
> > If someone complains to me about the noise my genset is making I
> > say "What? can't hear you, my genset is too loud".
> > GregofTim&Greg
> > 94ptCa
> > wrote:
> > > We will look into re manufacturing or redesigning a similar
product
> > > that will work as sound absorption as well as heat dissipation
> > > It will take some time to get a satisfactory product.
> > > Stephen 77fc35
> > > --- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg"
> > insulation, I
December.
> > He
> > heat
also
over
> > 90.
> > downwind as
me???
> > reflecting
02-21-2009, 20:06
I would say that careful inspections are the order of the day to keep
your coach in top form and you safe.
I'm not up to snuff on this post but in my case the new exhaust,
exhaust blankets on the new Stainless pipes (18ga.) and a soon to be
installed thermal and acoustic insulation in the engine compartment
she'll be cool, quite and efficient The blankets and the SS pipes are
rated at over 2000 degrees continuous duty. So the hottest parts are
insulated and the hottest gasses are directed out and away from the
motor. I did install 2 - 1650 cfm electric fans in the engine
compartment, to take care of any other residual heating problems.
I don't see how insulating any Bird compartment would be detrimental.
I can't imagine any engineer using the coach in any calculation as a
heat sink, to dissipate any heat from the engine or generator
Isn't that what radiators and exhausts are for.?
I'll redo the insulation in the genny compartment when I do the main
engine area.
Look at any Prevost conversion the generators are mostly in enclosed
compartments, Birds , at least the PT series are completely open
underneath. I would not worry about maximum insulation in the genny
box. When driving you get air flow, when parked the blower is sucking
air in from some where, some is air is flowing through the genny
box , along with the manifold, exhaust and valve cover blankets it's
already retaining/containing a lot of heat internally that can only
be removed through the exhaust and radiator. If after insulating you
see higher temps. Install a lower temp. thermostat.
After my near miss at burning up my coach I'd like to ask the forum a
question.
Has anybody ever checked the condition of the Generator exhaust stack
that goes up through the body? And how would we go about checking it?
It has the potential to be a serious issue should it be leaking
exhaust fumes into the coach.
In my coach the Genny Stack is located next to the Fridge. How well
insulated is it? Maybe that's why my Fridge works great when parked
but doesn't when I'm driving. I almost always run the generator when
driving, and yes it's running while parked if not at a place it can
be plugged in to. So is it part of my Fridge cooling problem? Maybe,
any thoughts?
Kurt Horvath
95 PT 42
10AC
lose
> heat now go?
causing
> Greg ofTim&Greg
> 94ptca
> > Stephen 77fc35
disapate
> it
> guess
> disipation
> heat
> > > now go.
> removed
be
> the
> was
not
I
> > > GregofTim&Greg
> > > 94ptCa
> product
dissipation
> > > > Stephen 77fc35
> > > insulation, I
> December.
> > > He
while
> the
> > > heat
> also
> over
> > > 90.
> > > downwind as
with
> me???
while
> > > reflecting
02-22-2009, 02:37
David, I would also assume that if the new insulation is too thick and takes up too much room, that it would restrict air flow?
83PT40
Wanderlodge
Date: Sunday, February 22, 2009, 8:39 AM
I pulled this out of the Powertech manual: (for what it's worth),
"Each engine is equipped with a high water temperature shutdown
switch, which will automatically shut down the set if the operating
temperature climbs too high. To prevent the generator set from
shutting down make sure the compartment openings are large enough
to allow adequate circulation of cooling air. The minimum free air
opening in the compartment door is 400 sq. in. or 2580 sq. cm.
Remember that louvers, screens and protective grills will restrict airflow.
A relatively open mesh screen will restrict airflow as much as 45%.
The intake opening must be increased to compensate for
such restrictions. "
David
'02 LXi, NC
for.?
engine area.
already retaining/containin g a lot of heat internally that can only
question.
checking it?
any thoughts?
Kurt Horvath
95 PT 42
10AC
> heat is
lose
> heat now go?
causing
> Greg ofTim&Greg
> 94ptca
> > Stephen 77fc35
disapate
> it
> > > I understand that the vault gets up to +250 degrees(USA) . I
> guess
> disipation
> heat
> > > now go.
> removed
be
> the
heat sink, but
> was
not
I
> > > GregofTim&Greg
> > > 94ptCa
> product
dissipation
> > > > Stephen 77fc35
> > > > --- In "WanderlodgeForum%40yahoogroups.com", "Ernest Ekberg"
> > > insulation, I
> December.
> > > He
while
> the
> > > heat
> also
> over
> > > 90.
> > > downwind as
with
> me???
while
> > > reflecting
Checked by AVG. Version: 7.5.552 / Virus Database: 270.11.2/1965 - Release Date: 2/21/2009 3:36 PM
