Refurbishing the Interior on Old Bird
02-21-2009, 16:36
It seems the former owner of our 1973 Bird papered the wall area behind
the dinette, and the wall next to the sink. We have the paper off, but
there is some type of thin white paint on the wall. What can we use to
remove this that will not affect the "Natural Wood" factory finish?
Paint Thinner, Alchol, Acatone, or Laquer thinner come too mind...
What to use that will not dissolve the factory finish??
Sanding will work, but it is very slow, and there is the danger that it
will gouge the finish.
Has anyone covered these areas with anything that looks good, and if
so, what?
Jack Smith
1973FC31
SoCal
02-21-2009, 16:50
may be it is wallpaper adhesive and commercial wall paper remover may
work???? when I paint or paper over a stain or gloss, some times it
is necessary to use a good sealer/primer or roll on a thin mix of
elmers glue. it could be that they primed it??????
Greg of Tim&Greg
94ptCa
--- In WanderlodgeForum@yahoogroups.com, "Jack & Donna Smith"
behind
but
use to
finish?
that it
if
> so, what?
> Jack Smith
> 1973FC31
> SoCal
02-21-2009, 17:52
may
> Greg of Tim&Greg
> 94ptCa
> behind
off,
> but
> use to
> finish?
> that it
> if
> > so, what?
> > Jack Smith
> > 1973FC31
> > SoCal
Dick do you have a spot where you could test a product to see if
would help remove that white paint? A friend of mine used some
ovencleaner but sparingly and with lots of fresh air in the general
area. Like I said you could just test an area that would not show
and this might be the trick. Be sure to wear gloves and have a fan
on. Jon
02-21-2009, 17:54
--- In WanderlodgeForum@yahoogroups.com, "Jon" wrote:
> may
it
of
> > Greg of Tim&Greg
> > 94ptCa
area
> > behind
> off,
> > but
we
> > use to
> > finish?
mind...
> > that it
> > if
> > > so, what?
> > > Jack Smith
> > > 1973FC31
> > > SoCal
if
> on. Jon
Oh yes maybe a set of clear plastic safety gogles? \\
Jon
Rebel Bird
02-21-2009, 18:09
remover
> > may
times
> it
> of
> > > Greg of Tim&Greg
> > > 94ptCa
> area
> > > behind
paper
> > off,
> > > but
> we
> > > use to
> > > finish?
> mind...
danger
> > > that it
> and
> > > if
> > > > so, what?
> > > > Jack Smith
> > > > 1973FC31
> > > > SoCal
> if
general
show
fan
> > on. Jon
> Jon
> Rebel Bird
I just goggled "Removal of glue from wall papered walls?
Here is the answer:http://www.google.com/search?
source=ig&hl=en&rlz=&q=What+can+I+use+to+remove+wall+paper+glue%
3F&btnG=Google+Search&aq=f
02-22-2009, 01:29
Jack, I suspect that the PO used Kilz to neutralize the surface. You might try a paint remover in a small area first. In one of our rentals we had hardwood floors under the carpet. The previous remodeler decided to not cover those floors when painting. I bouight a gallon of stripper and applied it like the directions. But I did not let it set too long. As soon as the paint was starting to bubble, I scraped it off. Tedious, for sure.
83PT40
Wanderlodge
--- On Sat, 2/21/09, Jack & Donna Smith wrote:
Subject: [WanderlodgeForum] Refurbishing the Interior on Old Bird
Date: Saturday, February 21, 2009, 10:36 PM
so, what?
Jack Smith
1973FC31
SoCal
02-23-2009, 08:47
Jack, MaybeGoo Gonewill work. I use the spray bottle to remove the sticky glue left after I remove a label from a plastic/glass bottle that I want to store something else in. I think the thick gel works better, but you get more coverage from the spray gel, as it is thinner. Good Luck, George Burke 1977 FC31 Charlotte
83PT40
Wanderlodge
so, what?
Jack Smith
1973FC31
SoCal
