hydraulic fan oil and filter
02-27-2009, 15:03
Rolling Stock is $49.95 these days. Have never used it, but like Ron I know the
author. Full-time RVer among other things.
Don Bradner
90 PT40 "Blue Thunder"
On 2/28/2009 at 2:35 AM ronmarabito2002 wrote:
>Dan: Have you had the coach out on the road recently. If oil is
>brown on the bottom, then it sounds like it has been setting still and
>some solids have settled. Please do inform me of the analysis.
>I use a software to keep all my records. It is called Rolling Stock.
> It was designed by a friend of mine and several fleets use it. Not
>sure what it cost right now. I was a Beta Tester on it several years
>back. If you are interested in it, I'll send you a URL to look at it.
> It has a Reminders page to let you know when the next services are due.
>R.E. (Ron) Marabito, Dallas, TX 92WB40
02-28-2009, 05:29
Here is an old post from a while back.
I just got 9 of these filters. I intend to purge my system twice, so
I needed 9 of them
http://www.adiesel.com/store/PT8487.html
This site has them for less than $13 bucks a pc., The best price I
found. They were over $40 bucks locally.
The 95 coaches do use different oils according to engine type.
The 8V92 uses an inline fitter in addition to the 3 reservoir filters
Parker Canister filter-(about 18" long in line street side), (
according to BB somewhere between the radiator and the tag axle).
Part #'s
Parker 925835
Donaldson P170073
BB 2122026
Reservoir filters All models, ( 8V92 & Series 60), use the same
reservoir filters.
The reservoir takes 3 filters.
Part #'s
Wix 57317
Nelson 83284D
Donaldson P550698
BB 2137065
The 8V92 uses 10W30, synthetic oils are ok to use.
The Series 60 uses HD32. Synthetics are OK to use. BB cross
referenced the recommended Dino. oil with CASTROL VS977 Synthetic. I
can't find it online. Waiting for return call from tech service.
After lots of surfing today I have found out that HD32 is a Texaco
product, Rando HD 32. As of July 2008 Chevron has the Texaco label
and will continue to mfg. The Rando line of fluids.
I also learned that any oil that is equivalent to ISO 32 should work
in the system. Some of these oils have a , AW or O&R rating. Anti -
Wear and Oxidation and Rust. Some have a combination of prefixes.
There are also biodegradable oils for Forestry and Marine
applications. I would recommend staying away from these because they
generally have a shorter service life. It your call. I will most
likely stay with the Rando HD 32 or it's synthetic version
I know all oils are not created equal. The mineral based oils run
anywhere from $30 to $60 for 5 gallons and the synthetics are $120
and up, some way up. The blends fall in the middle.
The capacity is 16 Quarts for the series 60 and 18 quarts for the
8V92, Jessie recommended buying 5 Gallons just to make sure you have
enough to refill the system.
In my opinion I would think capacity would be determined by how well
you can drain the system of old fluid. So I don't think these numbers
are written in stone in this senario.
To drain the system BB has a vacuum system that evacuates the
reservoir. They do not recommend disconnecting any of the hydraulic
lines in fear of creating a leak or breaking any connections,
especially the elbow under the reservoir tank, I can understand that,
the line and elbow are quite a bit heavier construction than the
tank, and BB has encountered breakage at that particular point
according to tech services.
Double oil and filter change
This technique involves an initial oil drain and filter change, The
system is then filled to the minimum level required and the fluid
circulated until operating temperature is reached and the fluid has
been turned over at least five times. The oil is drained and the
filters changed a second time. An appropriate oil analysis test
should be performed to determine the success of the flush. To
maximize the effectiveness of this technique, the system should be
drained as thoroughly as possible and the reservoir mechanically
cleaned.
Kurt Horvath
95 PT-42 WLWB S-60
10AC---
In WanderlodgeForum@yahoogroups.com, "Don Bradner"
Ron I know the author. Full-time RVer among other things.
> Don Bradner
Stock.
years
it.
are due.
02-28-2009, 10:10
can you purg it without filter elements? I would just ;drain the
reservoir and ;refill then ;run the pump by screwdriver on the
starter motor and blow the return line into a bucket. if I was
concerned about foam when switching brands.
two closed system purges would get you down to only 75% new if that
replaced each time (reservoir capacity) was 50% of total capacity. 3
purges get you close to 87% new. 4purg close to 94%.I bet my
screwdriver purge method takes it down to 95%new with less than 1
gallon loss problem would be that the steering fan motor must
function other wise you have to drain the lines. I bet the charge
pump on the motor would burn up in less than five minutes if it was
starved.
Greg ofTim&Greg
--- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath"
so
> I needed 9 of them
filters
> Part #'s
> Parker 925835
> Donaldson P170073
> BB 2122026
> reservoir filters.
> Part #'s
> Wix 57317
> Nelson 83284D
> Donaldson P550698
> BB 2137065
I
work
they
have
well
numbers
that,
> cleaned.
> Kurt Horvath
> 95 PT-42 WLWB S-60
> 10AC---
> > Don Bradner
still
> and
> Stock.
Not
> years
at
> it.
> are due.
03-04-2009, 15:34
Here are the hydraulic test results. What
do you think?
Dan Williams, 88WB38, Jackson, MS
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of ronmarabito2002
Sent: Friday, February 27, 2009
8:35 PM
Subject: [WanderlodgeForum] Re:
If oil is
TX
92WB40
"Dan Williams"
> Ron, I drew a sample from the canister and sent it in for testing. The
> fluid may have been clear on top but the fluid I drew from the
bottom of the
> canister was brown. You know, it would be nice if someone with some
fleet
> management software could enter all our coaches in a data base and help
> manage the maintenance and record keeping for us. I should have the lab
> results back by mid week and can give you the results if you are
interested.
MS
> _____
> From: "WanderlodgeForum%40yahoogroups.com"
> [mailto:"WanderlodgeForum%40yahoogroups.com"]
> Sent: Friday, February 27, 2009 4:47 PM
> Subject: [WanderlodgeForum] Re: hydraulic fan oil and filter
> Haven't had time to check the manual. It probably says the same as
> yours, but several other scheduled items really don't need that much
> attention either.
TX
92WB40
> --- In WanderlodgeForum@ Forum%40yahoogroups.com>
> yahoogroups.com, "Dan Williams"
> > Yes, mine is so clear that I wonder if it is 10w-30 motor oil. But
> still my
> > owners manual says in one place to change it every six months and in
> another
> > place to change it every oil change, which would be twelve months.
Does
> > your manual also mention changing it?
> > Dan Williams
> > 88WB38
> > Jackson, MS
> > _____
> > From: WanderlodgeForum@ Forum%40yahoogroups.com>
> yahoogroups.com
> > [mailto:WanderlodgeForum@ Forum%40yahoogroups.com>
> > Sent: Thursday, February 26, 2009 9:46 PM
> > To: WanderlodgeForum@ Forum%40yahoogroups.com>
> yahoogroups.com
> > Dan: I have run my oil in the power steering for more than 6 years
> > without a problem. Oil still looks clear and clean.
TX
92WB40
> > wrote:
> > > You are right, it runs the power steering and fan using 10w - 30
> > motor oil.
> > > 20 quarts. I wonder if there is a way to extend the change
> > interval. The
> > > instructions say to run the engine at 2100 rpm and if the red
light
> > on the
> > > rear switch panel comes on then change the oil and filter. I
don't
> > know how
> > > one man can run the engine at 2100 rpm and check the light on
the rear
> > > switch panel at the same time. Seems like the light should be on
> > the dash
> > > somewhere.
> > > _____
> > yahoogroups.com
> > yahoogroups.com] On Behalf Of timvasqz
> > > Sent: Wednesday, February 25, 2009 9:36 PM
> > yahoogroups.com
> > > I think that is overkill. I bet caution is because the tank
reservoir
> > > is where the expansion takes place and the cold oil airspace
leaves
> > > room for condensation. when you mix water with the hydrolic oil
> you get
> > > a foam. the foam air can pack airpressure in the lines and screw
with
> > > the pump and rams. (the steering gets spongy) the fan pump and
oil
> also
> > > runs the steering on the pt's.--- In
> > > yahoogroups.com, "maureyroad"
> > > > Why should the hydraulic fan oil be changed every six
months as
> > > > directed by the owner's manual? Thanks
> > > > Dan Williams
> > > > 88WB38
> > > > Jackson,
MS
03-04-2009, 15:39
I
tried to attach the exact numbers as a file but it didn’t work so here is
the narrative: COPPER AND LEAD APPEAR HIGH! ELEVATED COPPER MAY BE SOURCED TO
BUSHINGS, THRUST WASHERS, COPPER OXIDES, NON-MECHANICAL ORIGIN. ELEVATED LEAD
LEVELS ARE NOT
COMMONLY
ASSOCIATED WITH CRITICAL WEAR OF MOST HYDRAULIC COMPONENTS. LEAD COULD BE
SOURCED TO ORIGINAL/SUPPLEMENTAL ADDITIVES. VISCOSITY (V100 READING)
INDICATES
THIS IS 20 WEIGHT OR EQUIVALENT OIL. OTHER ANALYSIS READINGS APPEAR TO BE ACCEPTABLE. MORE SAMPLE
HISTORY NEEDED TO ESTABLISH A WEAR TREND.
8:35 PM
If oil is
TX
92WB40
"Dan Williams"
bottom of the
fleet
interested.
MS
> _____
> attention either.
TX
92WB40
> still my
> another
Does
> > Dan Williams
> > 88WB38
> > Jackson, MS
> > _____
> yahoogroups.com
> yahoogroups.com
TX
92WB40
> > motor oil.
> > interval. The
light
> > on the
don't
> > know how
the rear
> > the dash
> > > somewhere.
> > > _____
> > yahoogroups.com
> > yahoogroups.com
reservoir
leaves
> you get
with
oil
> also
months as
> > > > Dan Williams
> > > > 88WB38
> > > > Jackson,
MS
03-04-2009, 15:48
Dan: Attachments will not open on the forum. Please send the lab report to me
via email.
--- In WanderlodgeForum@yahoogroups.com, "Dan Williams" wrote:
> Here are the hydraulic test results. What do you think?
> _____
> Sent: Friday, February 27, 2009 8:35 PM
> bottom of the
> fleet
> interested.
> > _____
> yahoogroups.com
> yahoogroups.com
> > attention either.
> > still my
> > another
> Does
> > > Dan Williams
> > > 88WB38
> > > Jackson, MS
> > > _____
> > yahoogroups.com
> > yahoogroups.com
> > > motor oil.
> > > interval. The
> > > > instructions say to run the engine at 2100 rpm and if the red light
> > > on the
> > > > rear switch panel comes on then change the oil and filter. I don't
> > > know how
> the rear
> > > the dash
> > > > somewhere.
> > > > _____
> > > yahoogroups.com
> > > yahoogroups.com
> reservoir
> > > > is where the expansion takes place and the cold oil airspace leaves
> > you get
> with
> > > > the pump and rams. (the steering gets spongy) the fan pump and oil
> > also
> > > > WanderlodgeForum@
> > > > yahoogroups.com, "maureyroad" wrote:
> > > > > Why should the hydraulic fan oil be changed every six months as
> > > > > Dan Williams
> > > > > 88WB38
> > > > > Jackson, MS
03-04-2009, 19:41
Dan,
"INDICATES THIS IS 20 WEIGHT OR EQUIVALENT OIL. OTHER ANALYSIS READINGS APPEAR
TO BE ACCEPTABLE.",
You should check on that 20 weight, that does not sound correct. I think 10w/30
is what your coach should have in the hydraulic system.
Kurt Horvath
95 PT 42
10AC
> I tried to attach the exact numbers as a file but it didn't work so here is
> TO BUSHINGS, THRUST WASHERS, COPPER OXIDES, NON-MECHANICAL ORIGIN. ELEVATED
> LEAD LEVELS ARE NOT
> COMMONLY ASSOCIATED WITH CRITICAL WEAR OF MOST HYDRAULIC COMPONENTS. LEAD
> COULD BE SOURCED TO ORIGINAL/SUPPLEMENTAL ADDITIVES. VISCOSITY (V100
> READING)
> APPEAR TO BE ACCEPTABLE. MORE SAMPLE HISTORY NEEDED TO ESTABLISH A WEAR
> TREND.
> _____
> bottom of the
> fleet
> interested.
> > _____
> yahoogroups.com
> yahoogroups.com
> > attention either.
> > still my
> > another
> Does
> > > Dan Williams
> > > 88WB38
> > > Jackson, MS
> > > _____
> > yahoogroups.com
> > yahoogroups.com
> > > motor oil.
> > > interval. The
> > > on the
> > > know how
> the rear
> > > the dash
> > > > somewhere.
> > > > _____
> > > yahoogroups.com
> > > yahoogroups.com
> reservoir
> > you get
> with
> > also
> > > > WanderlodgeForum@
> > > > > Dan Williams
> > > > > 88WB38
> > > > > Jackson, MS
03-05-2009, 01:27
Kurt, Yes, I am going to change it.
10w/30 motor oil was recommended back in 1988 but there have been some
advancements in hydraulic fluid since then. I wonder what I should use now?
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Kurt Horvath
Sent: Thursday, March 05, 2009
1:41 AM
Dan,
"INDICATES THIS IS 20 WEIGHT OR EQUIVALENT OIL. OTHER ANALYSIS READINGS APPEAR TO BE
ACCEPTABLE.",
Kurt Horvath
95 PT 42
10AC
is
ELEVATED
> LEAD LEVELS ARE NOT
> READING)
> TREND.
MS
> _____
TX
92WB40
The
> bottom of the
> fleet
help
lab
> interested.
MS
> > _____
> yahoogroups.com
> yahoogroups.com
> > attention either.
TX
92WB40
But
> > still my
and in
> > another
months.
> Does
> > > Dan Williams
> > > 88WB38
> > > Jackson, MS
> > > _____
> > yahoogroups.com
> > yahoogroups.com
years
TX
92WB40
- 30
> > > motor oil.
> > > interval. The
red light
> > > on the
I don't
> > > know how
on
> the rear
be on
> > > the dash
> > > > somewhere.
> > > > _____
> > > yahoogroups.com
> > > yahoogroups.com
filter
> reservoir
airspace leaves
oil
> > you get
screw
> with
and oil
> > also
months as
> > > > > Dan Williams
> > > > > 88WB38
> > > > > Jackson,
MS
03-05-2009, 04:40
Dan,
I did a lot of research, there are a lot of new oils out there. I liked the new
biodegradable type but they do not hold up as well as the Dino. oils or Syn.
oils. I ended up going with the original recommended oil for my coach Rando
32AW. I just could not locate anything I though had any advantage to the Rando.
I've had this stuff around since the late summer. I am just now getting ready to
doing the service on it.
Kurt Horvath
95 PT 42
10AC
> Kurt, Yes, I am going to change it. 10w/30 motor oil was recommended back
> in 1988 but there have been some advancements in hydraulic fluid since then.
> _____
> Sent: Thursday, March 05, 2009 1:41 AM
> Dan,
> APPEAR TO BE ACCEPTABLE.",
> 10w/30 is what your coach should have in the hydraulic system.
> Kurt Horvath
> 95 PT 42
> 10AC
> is
> ELEVATED
> > LEAD LEVELS ARE NOT
> > READING)
> > TREND.
> > _____
> yahoogroups.com
> yahoogroups.com
> > bottom of the
> > fleet
> > interested.
> > > _____
> > yahoogroups.com
> > yahoogroups.com
> > > attention either.
> > > still my
> > > another
> > Does
> > > > Dan Williams
> > > > 88WB38
> > > > Jackson, MS
> > > > _____
> > > yahoogroups.com
> > > yahoogroups.com
> > > > motor oil.
> > > > interval. The
> > > > on the
> > > > know how
> > the rear
> > > > the dash
> > > > > somewhere.
> > > > > _____
> > > > yahoogroups.com
> > > > yahoogroups.com
> > reservoir
> > > you get
> > with
> > > also
> > > > > WanderlodgeForum@
> > > > > > Dan Williams
> > > > > > 88WB38
> > > > > > Jackson, MS
