Airbags, dry-rot
02-27-2009, 12:12
Airbags, dry-rot
my 90SP airbags are fine so far......I guess air bags are like a
roof.....when do u change roofing.....when it leaks...probably same
with the air bags.
slow day here.
Regards,
Hank
90SP36
--- In WanderlodgeForum@yahoogroups.com, "Juergen"
> David
> I have 1991 WLSP 36 which I bought in 1995 used. 20000 miles on it.
I
> just replaced the front airbags last fall, I finally got the rear
> airbags ready to go in this spring.
> I had no trouble with the bags, but figured they were OLD. I
examined
> the old front ones and they were cracked all along the edges. Yet
they
> worked perfectly. Therefore I cannot answer you question about how
old
> or how long you can use an airbag safely. Mine are 19 years old and
> still working, but I figured that it might be wise to change them
now.
> So, if yours still work, but you want to be absolutely safe, change
> them. And do NOT buy them from BB or their schoolbus division. CCC
> Truckparts have bags for coaches at 1/3 the cost of BB.
> I bought 1 from BB for $450 bucks (for a correct pattern) and the
> other 3 from CCC for $531.00 (BB wanted even more).
> Juergen in PA
> 1991 WLSP 36
> --- In WanderlodgeForum@yahoogroups.com, david brady
> > I was inspecting the coach the other day and noticed
> > that all my airbags are checked and cracked, similar
> > to the appearance of a dry-rotted tire. The bags are
> > 7.5 years old. Anyone have a feel for how long bags
> > should last, and how severely checked they can become
> > before replacement is necessary? I have visions of
> > installing new bags only to find the same checking one
> > year from now.
> > (Planning a cross country trip and want to be prepared).
> > David Brady
> > '02 LXi, NC
02-27-2009, 12:33
Airbags, dry-rot
Thanks everyone for your airspring input. For the time being
I'm going to carry a few spares, but will replace everything once
we return from the west coast.
David Brady
'02 LXi, NC
same
with the air bags.
slow day here.
Regards,
Hank
90SP36
"Juergen"
...> wrote:
> David
it.
I
examined
they
old
now.
> Juergen in PA
> 1991 WLSP 36
david brady
> > year from now.
> > David Brady
> > '02 LXi, NC
Checked by AVG. Version: 7.5.552 / Virus Database: 270.11.3 - Release Date: 2/22/2009 12:00 AM
02-27-2009, 13:39
Airbags, dry-rot
David- if you happen to be coming down I-20, we are 4 miles north of that with a complete full service campground, plumbing supplies, tanning booths, check cashing facility, and we tote the note on used vehicles. tongue firmly in cheek~
but we have space for a few birds here
83PT40
Wanderlodge
--- On Fri, 2/27/09, david brady wrote:
Subject: Re: [WanderlodgeForum] Re: Airbags, dry-rot
Date: Friday, February 27, 2009, 6:33 PM
David Brady
'02 LXi, NC
roof.....when do u change roofing..... when it leaks...probably same
with the air bags.
slow day here.
Regards,
Hank
90SP36
--- In "WanderlodgeForum%40yahoogroups.com", "Juergen"
> David
I
examined
they
old
> still
now.
> Juergen in PA
> 1991 WLSP 36
> --- In "WanderlodgeForum%40yahoogroups.com", david brady
> > year from now.
> > David Brady
> > '02 LXi, NC
02-27-2009, 15:04
Airbags, dry-rot
Hi all
I am posting as an X owner of an 86PT40. When I owned this bird I had the same
concerns. Little cracks here and there. They look a little scary. The best
advice I can give
is for each owner to contact an air bag mfg, such as Goodyear or Firestone and
speak to
the tech help area or ask for an air bag engineer. Once you learn how an air
bag is made
and how many layers it has, your concerns wil change direction. They are very
very hearty
little buggers. They will last beyond your wildest dreams. Try it, you'll like
it.
Carrying one of each type is good for the soul, but that's about all. Basically
they are good
until they start leaking. Damage by debris, it will not matter how old it is.
Dan Sunderland
2005 450LXi
San Marcos, CA
a
cashing
> Ernie Ekberg
> 83PT40
> Wanderlodge
> Weatherford, Tx
> From: david brady
> David Brady
> '02 LXi, NC
> with the air bags.
> slow day here.
> Regards,
> Hank
> 90SP36
> --- In WanderlodgeForum@ yahoogroups. com, "Juergen"
> > David
> I
> examined
> they
> old
> now.
> > Juergen in PA
> > 1991 WLSP 36
> > --- In WanderlodgeForum@ yahoogroups. com, david brady
> > > year from now.
> > > David Brady
> > > '02 LXi, NC
> Checked by AVG.
02-27-2009, 17:20
Airbags, dry-rot
Thanks for the invite Ernie. If we come thru that way I'll definitely
look you up. We normally head west on 40, but if the weather
is bad we'll scoot down to 20 (which is a much better road).
David
'02 LXi, NC
83PT40
Wanderlodge
--- On Fri, 2/27/09, david brady net>
david brady net>
being
David Brady
'02 LXi, NC
with the air bags.
slow day here.
Regards,
Hank
90SP36
> David
it.
I
examined
they
old
now.
> Juergen in PA
> 1991 WLSP 36
> > year from now.
> > David Brady
> > '02 LXi, NC
Checked by AVG.
02-28-2009, 06:57
Airbags, dry-rot
David, I have a 1985 PT40 that I have owned for 12 years and the air bags have looked that way as long as I have owned it. When I bought the coach 12 years ago it had about 100,000 miles on it, now it has about 160,000. I am not shure but I wonder if the bags have a thick outer protective layer that we see cracking on the outside and the actual bag sealing the air is a thinner moreplyable rubber on the inside?
Wayne
Sent: Friday, February 27, 2009 11:37:06 AM
Subject: [WanderlodgeForum] Airbags, dry-rot
year from now.
David Brady
'02 LXi, NC
02-28-2009, 09:53
Airbags, dry-rot
I note that I've twice had competent service providers "carefully inspect" the condition of my coach, and neither have indicated any concern about the air bags. They don't look horrible, but do have some checking and cracks on the outside. I take it that it's normal for the age of the bags.
While I have no way of knowing (I'm at least the 3rd owner of this coach), I doubt that any of the POs had the air bags replaced. The immediate PO never mentioned air bags, and the (incomplete) set of receipts he provided don't mention them either.
El Sobrante CA
"aeonix1@mac.com"
Wayne
To:"WanderlodgeForum@yahoogroups.com"
Sent:Friday, February 27, 2009 11:37:06 AM
Subject:[WanderlodgeForum] Airbags, dry-rot
year from now.
David Brady
'02 LXi, NC
02-28-2009, 10:07
Airbags, dry-rot
As other's have pointed out, there does appear to be an inner liner
built into today's air springs. I copied this following from
Firestone's
"Airide Design Guide":
"An air spring is a carefully designed rubber and fabric flexible
member
which contains a column of compressed air. The flexible member itself
does not provide force or support load; these functions are performed
by the column of air. Firestone air springs are highly engineered
elastomeric
flexible members with specifically designed metal end closures. The
standard two-ply version is made up of four layers:
(1) Inner Liner. An inner liner of calendered rubber.
(2) Frst Ply. One ply of fabric reinforced rubber with the cords
at a specific bias angle.
(3) Second Ply. A second ply of fabric reinforced rubber with the same
bias
angle laid opposite that of the first ply.
(4) Outer Cover. An outer cover of calendered rubber."
David Brady
'02 LXi, NC
age of the bags.
El Sobrante CA
"aeonix1@mac.com"
inside?
Wayne
11:37:06 AM
dry-rot
installing new bags only to find the same checkng one
year from now.
David Brady
'02 LXi, NC
Checked by AVG. Version: 7.5.557 / Virus Database: 270.11.3/1974 - Release Date: 2/26/2009 2:51 PM
02-28-2009, 10:40
Airbags, dry-rot
I dont think the bags on our bus are a bag in a bag its just one bag.
The cover inside and outside are the protective rubber keeping the
chords from the elements. Every rally I attend all you see are old
bags, something should be done. Even the description below is
confusing because ;a fabric is woven and ;bias is orientation at an
angel. if a fabric is situated on a bias , the angle is repeated
every 90deg. how could you arrange the second fabric on an oppisite
angle?
I need to go to a junk yard with a knife and check this out
http://www.airsprings.com.au/Airide_Definitions.cfm
Greg ofTim&Greg
Firestone's
member
itself
performed
> elastomeric
same bias
> David Brady
> '02 LXi, NC
any
some
for the
> > age of the bags.
this
The
of
> > Pete Masterson
> > <http://www.aeonix.biz/BBforsale.html
> > <http://www.aeonix.biz/BBforsale.html>>
> > El Sobrante CA
> > aeonix1@...
air
bought
has
thick
> >> actual bag sealing the air is a thinner more plyable rubber on
> >> inside?
> >> Wayne
> >> *From:* david brady >
> >> *To:* WanderlodgeForum@yahoogroups.com
> >> *Sent:* Friday, February 27, 2009 11:37:06 AM
> >> *Subject:* [WanderlodgeForum] Airbags, dry-rot
> >> year from now.
> >> David Brady
> >> '02 LXi, NC
> > Checked by AVG.
2/26/2009 2:51 PM
02-28-2009, 11:03
Airbags, dry-rot
They're trying to say the cords are arranged in a herringbone style.
David,
'02 LXi, NC
bag.
angle?
Greg ofTim&Greg
david brady "dmb993@..."
Firestone's
member
itself
performed
> elastomeric
same bias
> David Brady
> '02 LXi, NC
"carefully
indicated
any
have
some
normal
for the
> > age of the bags.
this
replaced.
The
set
of
> > Pete Masterson
> > El Sobrante CA
> > aeonix1@... <"aeonix1@"...>
and the
air
When I
bought
now it
has
have a
thick
outside and
rubber on
> >> inside?
> >> Wayne
> >> *From:* david brady ...>>
> >> *To:* "WanderlodgeForum%40yahoogroups.com"
> >> year from now.
> >> David Brady
> >> '02 LXi, NC
> > Checked by AVG.
Date:
2/26/2009 2:51 PM
