Protection valves
03-02-2009, 15:16
Protection valves
Hi group,
I want to replace the protection valves. I see Ryder has two types, two different numbers. A KN 31000 and a KN 31003. I can't see any difference between them. What ones have you put on? Bob Lawrence 84 PT36 Los Fresnos, Texas |
03-02-2009, 15:58
Protection valves
KN31000. Check with Ryder for difference.
Curt Sprenger On Mon, Mar 2, 2009 at 7:16 PM, Bob Lawrence <"bobandarlene@earthlink.net"> wrote:
03-02-2009, 18:08
Protection valves
I just installed a KN31000 which I think protected pressure in the system if there was an air leak at the bulk oil. Typical that everone only seems to have a airleak at the airleak protection valve. This is a common fail part and I think the problem is location not product it is too close to the manifold heat.
I dont think anyone will have the correct answer because they have been replaced with whatever over the years the BB parts list may have an answer in the filessection BB list the number 15759C which I guess is OEM N15759DC parts list also says 65psi and 3100 opens? at 65 Kn31003 crosses to OEM N15759DK KN31000crosses to OEM N15759DC Greg ofTim&Greg
--- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > KN31000. Check with Ryder for difference. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > *Read all about Southwest Bluebirds and Friends (SWBB) at > http://www.SOUTHWEST-BLUEBIRDS.ORG ...Then Join us. > "Host of the Annual Bluebird Quartzsite Rally" * > > > > On Mon, Mar 2, 2009 at 7:16 PM, Bob Lawrence bobandarlene@...wrote: > > > Hi group, > > I want to replace the protection valves. > > I see Ryder has two types, two different numbers. > > A KN 31000 and a KN 31003. > > I can't see any difference between them. > > What ones have you put on? > > > > Bob Lawrence > > 84 PT36 > > Los Fresnos, Texas > > > > > > > |
03-03-2009, 02:44
Protection valves
Thanks guys,
3100 it is. Bob Lawrence 84 PT36 (Still replacing stuff) Los Fresnos, Texas > > I just installed a KN31000 which I think protected pressure in the > system if there was an air leak at the bulk oil. Typical that everone > only seems to have a airleak at the airleak protection valve. This is a > common fail part and I think the problem is location not product it is > too close to the manifold heat. > > I dont think anyone will have the correct answer because they have been > replaced with whatever over the years the BB parts list may have an > answer in the files > <http://f1.grp.yahoofs.com/v1/YMesSdelrj0...yKxnrpi4MI LN\ > guUdB-y8rJvHKaPMc9dnsN0VfiLYJWulnys339Way0kqaIGitbDMY/1991_% 20to_1994_pt\ > _diagrams/DUAL%20AIR%20BRAKE%20ASSY%20-%20PARTS%20LIST.pdf> section BB > list the number 15759C which I guess is OEM N15759DC parts list also > says 65psi and 3100 opens? at 65 > > Kn31003 > <http://www.haldex.com/en/North-America/Applications- Products/Product-ca\ > tegories/Brake--Suspension-Systems/Valves/Pressure-Protection- Valves/Hal\ > dexMidland-NewRemanufactured/Pressure-Protection-Valve/KN31003? prodsearc\ > h=KN31003> crosses to OEM N15759DK > > KN31000 > <http://www.haldex.com/en/North-America/Applications- Products/Product-ca\ > tegories/Brake--Suspension-Systems/Valves/Pressure-Protection- Valves/Hal\ > dexMidland-NewRemanufactured/Pressure-Protection-Valve/KN31000? prodsearc\ > h=KN31000> crosses to OEM N15759DC > > Greg ofTim&Greg > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > > > KN31000. Check with Ryder for difference. > > > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, CA > > *Read all about Southwest Bluebirds and Friends (SWBB) at > > http://www.SOUTHWEST-BLUEBIRDS.ORG ...Then Join us. > > "Host of the Annual Bluebird Quartzsite Rally" * > > > > > > > > On Mon, Mar 2, 2009 at 7:16 PM, Bob Lawrence bobandarlene@...: > > > > > Hi group, > > > I want to replace the protection valves. > > > I see Ryder has two types, two different numbers. > > > A KN 31000 and a KN 31003. > > > I can't see any difference between them. > > > What ones have you put on? > > > > > > Bob Lawrence > > > 84 PT36 > > > Los Fresnos, Texas > > > > > > > > > > > > |
03-03-2009, 03:09
Protection valves
How many total do I have to buy?
I can't crawl under the bus to look so would like to know how many to buy. Bob Lawrence 84 PT36 (Wondering) Los Fresnos, Texas > > I just installed a KN31000 which I think protected pressure in the > system if there was an air leak at the bulk oil. Typical that everone > only seems to have a airleak at the airleak protection valve. This is a > common fail part and I think the problem is location not product it is > too close to the manifold heat. > > I dont think anyone will have the correct answer because they have been > replaced with whatever over the years the BB parts list may have an > answer in the files > <http://f1.grp.yahoofs.com/v1/YMesSdelrj0...yKxnrpi4MI LN\ > guUdB-y8rJvHKaPMc9dnsN0VfiLYJWulnys339Way0kqaIGitbDMY/1991_% 20to_1994_pt\ > _diagrams/DUAL%20AIR%20BRAKE%20ASSY%20-%20PARTS%20LIST.pdf> section BB > list the number 15759C which I guess is OEM N15759DC parts list also > says 65psi and 3100 opens? at 65 > > Kn31003 > <http://www.haldex.com/en/North-America/Applications- Products/Product-ca\ > tegories/Brake--Suspension-Systems/Valves/Pressure-Protection- Valves/Hal\ > dexMidland-NewRemanufactured/Pressure-Protection-Valve/KN31003? prodsearc\ > h=KN31003> crosses to OEM N15759DK > > KN31000 > <http://www.haldex.com/en/North-America/Applications- Products/Product-ca\ > tegories/Brake--Suspension-Systems/Valves/Pressure-Protection- Valves/Hal\ > dexMidland-NewRemanufactured/Pressure-Protection-Valve/KN31000? prodsearc\ > h=KN31000> crosses to OEM N15759DC > > Greg ofTim&Greg > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > > > KN31000. Check with Ryder for difference. > > > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, CA > > *Read all about Southwest Bluebirds and Friends (SWBB) at > > http://www.SOUTHWEST-BLUEBIRDS.ORG ...Then Join us. > > "Host of the Annual Bluebird Quartzsite Rally" * > > > > > > > > On Mon, Mar 2, 2009 at 7:16 PM, Bob Lawrence bobandarlene@...: > > > > > Hi group, > > > I want to replace the protection valves. > > > I see Ryder has two types, two different numbers. > > > A KN 31000 and a KN 31003. > > > I can't see any difference between them. > > > What ones have you put on? > > > > > > Bob Lawrence > > > 84 PT36 > > > Los Fresnos, Texas > > > > > > > > > > > > |
03-03-2009, 03:21
Protection valves
If I recall correctly...our coach has four of the valves...tag axle, drive axle, front axle, bulk oil fill.
Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA Read all about Southwest Bluebirds and Friends (SWBB) at http://www.SOUTHWEST-BLUEBIRDS.ORG ...Then Join us. "Host of the Annual Bluebird Quartzsite Rally" On Tue, Mar 3, 2009 at 7:09 AM, Bob Lawrence <"bobandarlene@earthlink.net"> wrote:
03-03-2009, 06:14
Protection valves
Thanks, Curt.
I'll order 3 of them. I don't have the bulk oil fill. Bob Lawrence 84 PT36 (Workcamping and loving it!) Laguna Atascosa NWR, Texas > If I recall correctly...our coach has four of the valves...tag axle, drive > axle, front axle, bulk oil fill. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > Read all about Southwest Bluebirds and Friends (SWBB) at > http://www.SOUTHWEST-BLUEBIRDS.ORG ...Then Join us. > "Host of the Annual Bluebird Quartzsite Rally" > > > On Tue, Mar 3, 2009 at 7:09 AM, Bob Lawrence > > > How many total do I have to buy? > > I can't crawl under the bus to look so would like to know how many to > > buy. > > Bob Lawrence > > 84 PT36 (Wondering) > > Los Fresnos, Texas > > > > > > I just installed a KN31000 which I think protected pressure in the > > > system if there was an air leak at the bulk oil. Typical that > > everone > > > only seems to have a airleak at the airleak protection valve. This > > is a > > > common fail part and I think the problem is location not product > > it is > > > too close to the manifold heat. > > > > > > I dont think anyone will have the correct answer because they have > > been > > > replaced with whatever over the years the BB parts list may have an > > > answer in the files > > > > > <http://f1.grp.yahoofs.com/v1/YMesSdelrj0...yKxnrpi4MI > > LN\ > > > guUdB-y8rJvHKaPMc9dnsN0VfiLYJWulnys339Way0kqaIGitbDMY/1991_% > > 20to_1994_pt\ > > > _diagrams/DUAL%20AIR%20BRAKE%20ASSY%20-%20PARTS%20LIST.pdf> > > section BB > > > list the number 15759C which I guess is OEM N15759DC parts list also > > > says 65psi and 3100 opens? at 65 > > > > > > Kn31003 > > > <http://www.haldex.com/en/North-America/Applications- > > Products/Product-ca\ > > > tegories/Brake--Suspension-Systems/Valves/Pressure-Protection- > > Valves/Hal\ > > > dexMidland-NewRemanufactured/Pressure-Protection-Valve/KN31003? > > prodsearc\ > > > h=KN31003> crosses to OEM N15759DK > > > > > > KN31000 > > > <http://www.haldex.com/en/North-America/Applications- > > Products/Product-ca\ > > > tegories/Brake--Suspension-Systems/Valves/Pressure-Protection- > > Valves/Hal\ > > > dexMidland-NewRemanufactured/Pressure-Protection-Valve/KN31000? > > prodsearc\ > > > h=KN31000> crosses to OEM N15759DC > > > > > > Greg ofTim&Greg > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > Curt Sprenger > > > > > > > > > > > KN31000. Check with Ryder for difference. > > > > > > > > Curt Sprenger > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > Anaheim Hills, CA > > > > *Read all about Southwest Bluebirds and Friends (SWBB) at > > > > http://www.SOUTHWEST-BLUEBIRDS.ORG ...Then Join us. > > > > "Host of the Annual Bluebird Quartzsite Rally" * > > > > > > > > > > > > > > > > On Mon, Mar 2, 2009 at 7:16 PM, Bob Lawrence bobandarlene@: > > > > > > > > > Hi group, > > > > > I want to replace the protection valves. > > > > > I see Ryder has two types, two different numbers. > > > > > A KN 31000 and a KN 31003. > > > > > I can't see any difference between them. > > > > > What ones have you put on? > > > > > > > > > > Bob Lawrence > > > > > 84 PT36 > > > > > Los Fresnos, Texas > > > > > > > > > > > > > > > > > > > > > > > > > > > > > |
