Roof Ac Circuit Board
03-08-2009, 08:48
Hello everyone. I have a Duotherm by Dometic that has stopped working. I think
I have narrowed it down to the circuit board on the unit. I'm thinking that some of you may be replacing your unit because it doesn't cool enough anymore. I was hoping that maybe you could throw it my way. My unit was cooling good when it appeared that I lost electrical power. If I can bring it back to life by replacing the circuit board, It will save me from having to purcahse a new unit. The circuit board is held in place by four small screws. It has a ribbon with an 11 pin connector soldered to the board. It is not difficult to remove from the unit. I would be willing to pay for it and certainly pay for shipping. Thanks for any help. Gus Rodriguez 89pt40 8v92 Pearland, Tx |
03-08-2009, 16:36
Gus,
What model do you have? I have an old Dometic Penguin SL135 unit I replaced with a new Penguin low profile. Glenn 1986 PT40 Marietta, GA |
03-09-2009, 11:23
--- In WanderlodgeForum@yahoogroups.com, "Glenn Allen"
> > Gus, > > What model do you have? I have an old Dometic Penguin SL135 unit I replaced with a new Penguin low profile. > > Glenn > > 1986 PT40 > Marietta, GA > Glenn, I have Duotherm Dometic Model number 610115.103. It may be the original. There are alot of other numbers on the name plate describing compressor. freon capacity, etc. but no simple model number. Thanks for the reply, Gus 89pt40 8v92 Pearland, Tx |
03-11-2009, 03:04
Gus,
You definitely have a different model. I don't believe the control boards are the same. Glenn 1986 PT40 Marietta, GA --- In WanderlodgeForum@yahoogroups.com, "gus2rod" > > --- In WanderlodgeForum@yahoogroups.com, "Glenn Allen" > > > > Gus, > > > > What model do you have? I have an old Dometic Penguin SL135 unit I replaced with a new Penguin low profile. > > > > Glenn > > > > 1986 PT40 > > Marietta, GA > > > Glenn, I have Duotherm Dometic Model number 610115.103. It may be the original. There are alot of other numbers on the name plate describing compressor. freon capacity, etc. but no simple model number. > > Thanks for the reply, > > Gus > > 89pt40 8v92 > Pearland, Tx > |
