FC Air System- info needed
03-17-2009, 13:03
http://www.cruisecontrolking.com/
Bill 88 FC Michigan
--- In WanderlodgeForum@yahoogroups.com, "Jon" wrote:
> --- In WanderlodgeForum@yahoogroups.com, cfsomers@ wrote:
> > Who makes an electric cruise control? Mine went out 4 years ago. How
> much
> > work is there to install?
> > Chuck
> > 81SBFC
> > Florida
> > > When my vacuum generator failed I did buy a couple of vacuum
> generators
> > > which I had planned to use to replace the original. My memory is
> that I
> > > chose not to use them because none of them had the built in shut off
> > > diaphragm like the Wanderlodge original. All the ones I could find
> would
> > > have been running constantly whereas the OE shut off when the
> appropriate
> > > vacuum level was reached. The OE was a part used on old Ford trucks
> as I
> > > recall. Perhaps an old Ford truck forum might have info on a
> suitable
> > > replacement. I looked for a long time for a vacuum generator with a
> built
> > > in shut off valve and couldn't find one. I'm sure that someone with
> the
> > > skills of a Cuban mechanic could adapt some kind of generator to
> work. I
> > > concluded an electric cruise control was a better option
> > > Kerry
> > > 82 FC 35
> > > Denver
> Kerry did you ever get your cruse control to work? I just took mine
> apart and cleaned up the internals and now it works perfect. But I
> don't think mine has any vacumm censor device that will turn it oft and
> on at a certain vacumm pressure. If there is such a device I have
> never seen it on my coach.
> Jon
> Rebel Bird
> Bremerton washington
03-17-2009, 14:48
I never use a cruise control on anything after a elderly women driver pass my
truck doing 70 in a Volvo sound a sleep. I dont have faith in my ability to
avoid the same. Good news was the rock she hit kept her reckless disreguard
personal.
Greg of Tim&Greg
94ptCa
--- In WanderlodgeForum@yahoogroups.com, cfsomers@... wrote:
> Who makes an electric cruise control? Mine went out 4 years ago. How much
> Chuck
> 81SBFC
> Florida
> > When my vacuum generator failed I did buy a couple of vacuum generators
> > which I had planned to use to replace the original. My memory is that I
> > diaphragm like the Wanderlodge original. All the ones I could find would
> > have been running constantly whereas the OE shut off when the appropriate
> > vacuum level was reached. The OE was a part used on old Ford trucks as I
> > recall. Perhaps an old Ford truck forum might have info on a suitable
> > replacement. I looked for a long time for a vacuum generator with a built
> > in shut off valve and couldn't find one. I'm sure that someone with the
> > skills of a Cuban mechanic could adapt some kind of generator to work. I
> > Kerry
> > 82 FC 35
> > Denver
03-17-2009, 15:40
> > much
> > > Chuck
> > > 81SBFC
> > > Florida
> > generators
> > that I
> > would
> > appropriate
> > as I
> > suitable
> > built
> > the
> > work. I
> > > > Kerry
> > > > 82 FC 35
> > > > Denver
> > Jon
> > Rebel Bird
> JON-
> Did you just do your vac generator or did you do the whole cruise mechanism.
Mine does not work either. Mechanic said it was not worth fooling with
(probably true at his rate). I need another project to put on the list.
> John Churchill
> 1980 FC33
> LARGE MARGE
> Sanibel, FL
Well it wouldn't hurt just to take it out and clean it up. Its not a very hard
job to do and what the hell maybe it might just start working again. Mine was
frozen up and just need the internal vains cleaned up and lubracated. Works
like a champ. The only thing wrong with these old cruise controls it just takes
it time to set the speed at which you want to set it at. If I want to set it at
60 mph I usally speed up to 65 and engage the cruse control and by the time it
starts to go on cruse control its usally at 60 mph. Jon
03-18-2009, 02:03
The diaphragm that shuts off the vacuum generator once adequate vacuum is acheived is not visible. It is inside the vacuum generator itself and finding it is likely to damage the vacuum generator irreparably. I took mine off and disassembled it because it was constantly leaking air. In retrospect it was most likely leaking air because it was operating all the time due to a vacuum leak somewhere in the cruise control system. I didn't understand how it worked when I began taking it apart.
Rostra makes the electric cruise control I used. I think Chuck Wheeler also used one if my memory serves me correctly. There are others out there but Rostra is the least expensive.
Kerry
82 FC 35
Denver
