genset maintenance
06-05-2005, 15:27
genset maintenance
I have a 12.5Kw Kohler/Perkins Genset and I want to change the oil
filter, air filter, and fuel filter. I have the Bluebird part numbers, does anyone have a conversion part number I could use at the local auto parts store? Would anyone recommend using synthetic oil, if so which one? When I change the fuel filter what is the best way to release the pressure on the line, and after I'm finished will the system re-prime automatically, or will I need some kind of pump? SORRY to ask so many questions at once, but you know how us newbies are!! Thanks Bruce Campbell 83'FCSB "formerly Rainbow Chaser" sorry Arley! |
06-05-2005, 16:01
genset maintenance
Syn. oil has done well for me, be sure it is a diesel oil. Not
necessary, just extra protection. No need to release fuel pressure, there is no pressure with the engine not running. Priming is fairly simple, there is a handle on the fuel pump to prime manually (pump up-down). I have always just loosened the line out of the fuel supply pump on the engine, primed until no bubbles there, have never had to use the procedure in the manual to prime further. - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, "fl_bluebird_1983" > > I have a 12.5Kw Kohler/Perkins Genset and I want to change the oil > filter, air filter, and fuel filter. I have the Bluebird part numbers, > does anyone have a conversion part number I could use at the local auto > parts store? Would anyone recommend using synthetic oil, if so which > one? When I change the fuel filter what is the best way to release the > pressure on the line, and after I'm finished will the system re-prime > automatically, or will I need some kind of pump? SORRY to ask so many > questions at once, but you know how us newbies are!! > > Thanks > Bruce Campbell > 83'FCSB > "formerly Rainbow Chaser" sorry Arley! |
06-06-2005, 10:02
genset maintenance
bruce,just get the numbers off the filters that are on the coach,then go to napa
or your favorite parts store! randydupree93wb ----- Original Message ----- From: fl_bluebird_1983 To: WanderlodgeForum@yahoogroups.com Sent: Sunday, June 05, 2005 11:27 PM Subject: [WanderlodgeForum] genset maintenance I have a 12.5Kw Kohler/Perkins Genset and I want to change the oil filter, air filter, and fuel filter. I have the Bluebird part numbers, does anyone have a conversion part number I could use at the local auto parts store? Would anyone recommend using synthetic oil, if so which one? When I change the fuel filter what is the best way to release the pressure on the line, and after I'm finished will the system re-prime automatically, or will I need some kind of pump? SORRY to ask so many questions at once, but you know how us newbies are!! Thanks Bruce Campbell 83'FCSB "formerly Rainbow Chaser" sorry Arley! ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-06-2005, 10:57
genset maintenance
Bruce,
The oil filter for the Perkins is a NAPA Gold # 1268. The air filter on mine is an oil coated wire mesh that you just clean, not replace. I'll have the fuel filter later, as I don't have that in front of me. This will get you started. George Witt 81 FC 35 Lincoln, Nebraska --- In WanderlodgeForum@yahoogroups.com, "fl_bluebird_1983" > > I have a 12.5Kw Kohler/Perkins Genset and I want to change the oil > filter, air filter, and fuel filter. I have the Bluebird part numbers, > does anyone have a conversion part number I could use at the local auto > parts store? Would anyone recommend using synthetic oil, if so which > one? When I change the fuel filter what is the best way to release the > pressure on the line, and after I'm finished will the system re-prime > automatically, or will I need some kind of pump? SORRY to ask so many > questions at once, but you know how us newbies are!! > > Thanks > Bruce Campbell > 83'FCSB > "formerly Rainbow Chaser" sorry Arley! |
06-06-2005, 14:05
genset maintenance
George,
That's interesting NAPA sold me a #1806 for the oil filter. Any idea Why? The fuel filter they sold me was a #3166. Both are on the genset and working fine at least to the best of my knowledge. I also have the oil bath air cleaner. Chet Geist 1981 FC33, Austin, Texas -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of mrdonut12 Sent: Monday, June 06, 2005 5:58 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: genset maintenance Bruce, The oil filter for the Perkins is a NAPA Gold # 1268. The air filter on mine is an oil coated wire mesh that you just clean, not replace. I'll have the fuel filter later, as I don't have that in front of me. This will get you started. George Witt 81 FC 35 Lincoln, Nebraska --- In WanderlodgeForum@yahoogroups.com, "fl_bluebird_1983" > > I have a 12.5Kw Kohler/Perkins Genset and I want to change the oil > filter, air filter, and fuel filter. I have the Bluebird part numbers, > does anyone have a conversion part number I could use at the local auto > parts store? Would anyone recommend using synthetic oil, if so which > one? When I change the fuel filter what is the best way to release the > pressure on the line, and after I'm finished will the system re-prime > automatically, or will I need some kind of pump? SORRY to ask so many > questions at once, but you know how us newbies are!! > > Thanks > Bruce Campbell > 83'FCSB > "formerly Rainbow Chaser" sorry Arley! ---------------------------------------------------------------------------- -- Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-06-2005, 15:34
genset maintenance
Thanks George and Chet, the numbers on my filters were barely
readable, but after reading your posts it does look like 1806 & 3166 are what I have. The air filter is the wire mesh type. The air filter has a sticker on the side that is hard to read but it looks like it says use SAE 20 oil, but the manual says SAE 40. What do most of you use. I live in Florida what weight oil would you sugest for the generator motor (4 cylinder Perkins) the manual isn't clear. Thanks For all the help Bruce Campbell 83FCSB 12.5 Kohler/Perkins "Bus formerly known as Rainbow Chaser" sorry Arley! --- In WanderlodgeForum@yahoogroups.com, "Chet Geist" wrote: > George, > > That's interesting NAPA sold me a #1806 for the oil filter. Any idea Why? > The fuel filter they sold me was a #3166. Both are on the genset and > working fine at least to the best of my knowledge. I also have the oil bath > air cleaner. > > Chet Geist > 1981 FC33, Austin, Texas > -----Original Message----- > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of mrdonut12 > Sent: Monday, June 06, 2005 5:58 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: genset maintenance > > > > Bruce, > The oil filter for the Perkins is a NAPA Gold # 1268. > The air filter on mine is an oil coated wire mesh that > you just clean, not replace. > I'll have the fuel filter later, as I don't have that > in front of me. This will get you started. > > George Witt > 81 FC 35 > Lincoln, Nebraska > > --- In WanderlodgeForum@yahoogroups.com, "fl_bluebird_1983" > > > > > I have a 12.5Kw Kohler/Perkins Genset and I want to change the oil > > filter, air filter, and fuel filter. I have the Bluebird part numbers, > > does anyone have a conversion part number I could use at the local auto > > parts store? Would anyone recommend using synthetic oil, if so which > > one? When I change the fuel filter what is the best way to release the > > pressure on the line, and after I'm finished will the system re- prime > > automatically, or will I need some kind of pump? SORRY to ask so many > > questions at once, but you know how us newbies are!! > > > > Thanks > > Bruce Campbell > > 83'FCSB > > "formerly Rainbow Chaser" sorry Arley! > > > > > > -------------------------------------------------------------------- -------- > -- > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] |
06-06-2005, 23:02
genset maintenance
WILL THEY DELIVER THAT WHOLE DRUM, OR DO YOU HAVE TO GO PICK IT UP????
DAY IN WARM SUNNY JAX FLA 83 PT-40 [Non-text portions of this message have been removed] |
06-06-2005, 23:16
genset maintenance
Napa also sells a 1268 oil filter for the 3208, it is at least one
inch smaller, the screw on threads may be the same, but the filter element is clearly smaller. I stick with only the big yellow Cat filters for the 3208. "all things that appear the same may not be the same" (someone wiser than I said this) ![]() Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "Chet Geist" wrote: > George, > > That's interesting NAPA sold me a #1806 for the oil filter. Any idea Why? > The fuel filter they sold me was a #3166. Both are on the genset and > working fine at least to the best of my knowledge. I also have the oil bath > air cleaner. > > Chet Geist > 1981 FC33, Austin, Texas > -----Original Message----- > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of mrdonut12 > Sent: Monday, June 06, 2005 5:58 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: genset maintenance > > > > Bruce, > The oil filter for the Perkins is a NAPA Gold # 1268. > The air filter on mine is an oil coated wire mesh that > you just clean, not replace. > I'll have the fuel filter later, as I don't have that > in front of me. This will get you started. > > George Witt > 81 FC 35 > Lincoln, Nebraska > > --- In WanderlodgeForum@yahoogroups.com, "fl_bluebird_1983" > > > > > I have a 12.5Kw Kohler/Perkins Genset and I want to change the oil > > filter, air filter, and fuel filter. I have the Bluebird part numbers, > > does anyone have a conversion part number I could use at the local auto > > parts store? Would anyone recommend using synthetic oil, if so which > > one? When I change the fuel filter what is the best way to release the > > pressure on the line, and after I'm finished will the system re-prime > > automatically, or will I need some kind of pump? SORRY to ask so many > > questions at once, but you know how us newbies are!! > > > > Thanks > > Bruce Campbell > > 83'FCSB > > "formerly Rainbow Chaser" sorry Arley! > > > > > > ------------------------------------------------------------------- --------- > -- > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] |
06-07-2005, 00:06
genset maintenance
Bruce,
D'oh!!! The 1268 NAPA oil filter is the the 3208na Cat engine. Sheesh. The oil filter for the Perkins is 1806 in NAPA Gold. I use 15W40 oil in the Cat and the Perkins. I think I used 10w30 oil in the air cleaner for the Perkins (didn't have any straight weight oil, if I did I'd use 20w). George Witt 81 FC 35 Lincoln, Nebraska --- In WanderlodgeForum@yahoogroups.com, "fl_bluebird_1983" > > Thanks George and Chet, the numbers on my filters were barely > readable, but after reading your posts it does look like 1806 & 3166 > are what I have. The air filter is the wire mesh type. The air filter > has a sticker on the side that is hard to read but it looks like it > says use SAE 20 oil, but the manual says SAE 40. What do most of you > use. I live in Florida what weight oil would you sugest for the > generator motor (4 cylinder Perkins) the manual isn't clear. > > Thanks For all the help > > Bruce Campbell > 83FCSB 12.5 Kohler/Perkins > "Bus formerly known as Rainbow Chaser" sorry Arley! > > --- In WanderlodgeForum@yahoogroups.com, "Chet Geist" > wrote: > > George, > > > > That's interesting NAPA sold me a #1806 for the oil filter. Any > idea Why? > > The fuel filter they sold me was a #3166. Both are on the genset > and > > working fine at least to the best of my knowledge. I also have the > oil bath > > air cleaner. > > > > Chet Geist > > 1981 FC33, Austin, Texas > > -----Original Message----- > > From: WanderlodgeForum@yahoogroups.com > > [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of mrdonut12 > > Sent: Monday, June 06, 2005 5:58 PM > > To: WanderlodgeForum@yahoogroups.com > > Subject: [WanderlodgeForum] Re: genset maintenance > > > > > > > > Bruce, > > The oil filter for the Perkins is a NAPA Gold # 1268. > > The air filter on mine is an oil coated wire mesh that > > you just clean, not replace. > > I'll have the fuel filter later, as I don't have that > > in front of me. This will get you started. > > > > George Witt > > 81 FC 35 > > Lincoln, Nebraska > > > > --- In WanderlodgeForum@yahoogroups.com, "fl_bluebird_1983" > > > > > > > > I have a 12.5Kw Kohler/Perkins Genset and I want to change the > oil > > > filter, air filter, and fuel filter. I have the Bluebird part > numbers, > > > does anyone have a conversion part number I could use at the > local auto > > > parts store? Would anyone recommend using synthetic oil, if so > which > > > one? When I change the fuel filter what is the best way to > release the > > > pressure on the line, and after I'm finished will the system re- > prime > > > automatically, or will I need some kind of pump? SORRY to ask > so many > > > questions at once, but you know how us newbies are!! > > > > > > Thanks > > > Bruce Campbell > > > 83'FCSB > > > "formerly Rainbow Chaser" sorry Arley! > > > > > > > > > > > > ------------------------------------------------------------------ -- > -------- > > -- > > Yahoo! Groups Links > > > > a.. To visit your group on the web, go to: > > http://groups.yahoo.com/group/WanderlodgeForum/ > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service. > > > > > > > > [Non-text portions of this message have been removed] |
06-07-2005, 00:06
genset maintenance
AFTER THINKING ABOUT IT, THAT 55 GALLON DRUM WOULD SIT THERE QUITE A
WHILE BEFORE IT WAS ALL USED,,,, AND ANYTHING COULD HAPPEN TO IT BEFORE THEN,,, I THINK I WILL GO WITH THE CASE OF OIL,,,, DAY IN SUNNY JAX FLA 83 PT-40 [Non-text portions of this message have been removed] |
