gfci still tripping
03-24-2009, 15:19
gfci still tripping
Well, I've completely removed both my PowerWatch reverse polarity indicators to
re-do them. Decided to check the coach with them removed and the GFCI still trips when I plug the 30 amp cord in. It trips when I plug it into either of the two 30 amp receptacles on the coach. (I do not own a 50 amp cord.) Trips even though all the breakers are off including individual circuits, main breaker and the separate 30 amp disconnect breakers. If I switch the master shore power switch to off, gen or 50 amp it does not trip. It does trip if this switch is set at 30 amps. If I start with everything at off, then gradually flip switches it seems to barely hold, but if the switches are on and I plug in the cord, the GFCI trips, suggesting I am right at the trip point. One possible problem area is the genset which has been replaced in the past, but does not ever seem to have been run prior to my getting the coach. I am looking for advice on the proper troubleshooting technique for this problem. John Churchill 1980 FC33 LARGE MARGE Sanibel, FL |
03-24-2009, 16:48
gfci still tripping
John,
There are some active circuits even when all breakers are off. They are involved in the circuit that warns you if you turn the ignition on with shore power applied. Turning off the breakers only breaks the "hot" side. If there is a cross between Neutral and ground it will still be there even with the breakers off. That is why I had to disconnect the neutrals in order to isolate my problem. There may be a different or better way,but this was the only way I could think of.
- Chuck Wheeler-
1982 FC 31SB Fort Worth TX
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Robin Sent: Tuesday, March 24, 2009 9:19 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] gfci still tripping way Well, I've completely removed both my PowerWatch reverse polarity indicators to re-do them. Decided to check the coach with them removed and the GFCI still trips when I plug the 30 amp cord in. It trips when I plug it into either of the two 30 amp receptacles on the coach. (I do not own a 50 amp cord.) Trips even though all the breakers are off including individual circuits, main breaker and the separate 30 amp disconnect breakers. If I switch the master shore power switch to off, gen or 50 amp it does not trip. It does trip if this switch is set at 30 amps. If I start with everything at off, then gradually flip switches it seems to barely hold, but if the switches are on and I plug in the cord, the GFCI trips, suggesting I am right at the trip point. One possible problem area is the genset which has been replaced in the past, but does not ever seem to have been run prior to my getting the coach. I am looking for advice on the proper troubleshooting technique for this problem. John Churchill 1980 FC33 LARGE MARGE Sanibel, FL |
03-25-2009, 04:26
gfci still tripping
