Broken Microphor toilet
03-25-2009, 10:56
I need to replace my Microphor toilet. Has anyone else replaced one with a
different type? They wanted over $1400.00 from a distributor to purchase a new
one. There must be a better option somewhere.
Thanks
Nelson Slinkman 1994 40'
03-25-2009, 11:37
If I were ever to replace my toilet I would see if one of the Manuel toilets would work; the kind that was in the 1980+ models. It idiot proof and requires no maintenance. I have never been able to see the advantage of the Microphor.
Wallace Craig
95 WLWB 42
Azle, Texas
--- On Wed, 3/25/09, nslinkman wrote:
Subject: [WanderlodgeForum] Broken Microphor toilet
Date: Wednesday, March 25, 2009, 4:56 PM
I need to replace my Microphor toilet. Has anyone else replaced one with a different type? They wanted over $1400.00 from a distributor to purchase a new one. There must be a better option somewhere.
Thanks
Yahoo! Groups Links
<*> Your email settings:
(Yahoo! ID required)
mailto:WanderlodgeForum-digest@yahoogroups.com
mailto:WanderlodgeForum-fullfeatured@yahoogroups.com
03-25-2009, 11:50
Thanks for the information. Do you know the brand name of the ones in the older buses.
Thanks
Nelson
--- On Wed, 3/25/09, Wallace Craig wrote:
Subject: Re: [WanderlodgeForum] Broken Microphor toilet
Date: Wednesday, March 25, 2009, 6:37 PM
Wallace Craig
95 WLWB 42
Azle, Texas
Thanks
Yahoo! Groups Links
http://groups. yahoo.com/ group/Wanderlodg eForum/
http://groups. yahoo.com/ group/Wanderlodg eForum/join
mailto:WanderlodgeForum- digest@yahoogrou ps.com
mailto:WanderlodgeForum- fullfeatured@ yahoogroups. com
WanderlodgeForum- unsubscribe@ yahoogroups. com
http://docs. yahoo.com/ info/terms/
03-25-2009, 12:59
The advantage of the Microphor is that it does not need to be _directly_ over the black water tank. Most RV toilets drop straight down into the tank. The Microphor, using air (or electric) assisted methods uses little water (about 2 quarts per flush) and may be positioned more conveniently with respect to the location of the black tank. This compares to the most common, newer home toilets that use nearly 7 quarts per flush.
As for replacing a Microphor, I understand it is possible to get a fairly complete "rebuild" kit that might be all that's needed to solve the problems Nelson is having.
In a replacement toilet, the manual toilet would have to be directly above the black tank. If your coach does allow this kind of installation, then one of the other brands would work just fine. But if the pipe has _any_ sloping segments, then you will have to stay with a Microphor or some other brand (but probably expensive) toilet that allows offset installation.
El Sobrante CA
"aeonix1@mac.com"
Wallace Craig
95WLWB42
Azle, Texas
To:"WanderlodgeForum@yahoogroups.com"
Thanks
Yahoo! Groups Links
03-25-2009, 13:28
The name is "Thetford". If you google thetford you will find that they have a web site.
Wallace Craig
95 WLWB 42
Azle, Texas
Date: Wednesday, March 25, 2009, 5:50 PM
Thanks
Nelson
Wallace Craig
95 WLWB 42
Azle, Texas
Thanks
Yahoo! Groups Links
03-25-2009, 15:04
> Thanks
We are considering a Thetford Aria Classic RV toilet as a future purchase. Ralph Fullenwider suggested this.
Regards,
Jack and Liz Pearce
Fulltiming in a 1993 Wanderlodge WB40
D'Hanis, TX
Buena Vista, CO
03-26-2009, 02:58
We also considered replacement. A big plumbing hassle and not very efficient
when you compare the water usage with the other options. Too bad they didn't
mount it right over the black tank. For about 325.00, including shipping, we
got a re-build kit from Microphor. Foretravel of Texas will do the rebuild, a
little over an hours work.
> Thanks
03-26-2009, 05:09
--- On Thu, 3/26/09, luckyron1 wrote:
Subject: [WanderlodgeForum] Re: Broken Microphor toilet
Date: Thursday, March 26, 2009, 9:58 AM
We also considered replacement. A big plumbing hassle and not very efficient when you compare the water usage with the other options. Too bad they didn't mount it right over the black tank. For about 325.00, including shipping, we got a re-build kit from Microphor. Foretravel of Texas will do the rebuild, a little over an hours work.
> Thanks
03-26-2009, 05:11
Thanks alot. Someone mentiones a Sealand but in the Camping World remarks is was not rated very good.
Thanks Again
Nelson
Date: Wednesday, March 25, 2009, 10:04 PM
> Thanks
Regards,
Jack and Liz Pearce
D'Hanis, TX
Buena Vista, CO
03-26-2009, 05:15
Thanks, That will take the place of the Microphor. I see some people mentiones some toilets need a plumbing change. I sure don't want go do that. I just want one that I can bolt to the floor and connect the water line.
Thanks
Nelson 1994 40'WB
Date: Wednesday, March 25, 2009, 8:28 PM
Wallace Craig
95 WLWB 42
Azle, Texas
Thanks
Nelson
Wallace Craig
95 WLWB 42
Azle, Texas
Thanks
Yahoo! Groups Links
