Michelin 12R 22.5 XZ2 Tires
04-03-2009, 07:35
I have a badly weather-checked left front tire. Tire dealers tell me that
Michelin has discontinued 12R 22.5 XZ2 tires. I was hoping to just replace the
one bad tire; but if I buy anothere brand, presumably I'd have to replace at
both front tires.
Has anyone else run into this problem? If so, what's the alternative?
Best regards,
Gary Van Tassel
2004 M380
Verde Valley, AZ
04-03-2009, 07:43
The standard Michelin 12R22.5 for several years has been the XZE* That asterisk
is not a typo - the tires themselves have a star, but in the literature it is an
asterisk, and you will not find 12R22.5 in the regular XZE listings.
>that Michelin has discontinued 12R 22.5 XZ2 tires. I was hoping to just
>replace the one bad tire; but if I buy anothere brand, presumably I'd have
>to replace at both front tires.
>Best regards,
>Gary Van Tassel
>2004 M380
>Verde Valley, AZ
04-03-2009, 08:24
Does this mean that the XZE* is a direct replacement for the XZ2?
Best regards,
Gary Van Tassel
2004 M380
Verde Valley, AZ
asterisk is not a typo - the tires themselves have a star, but in the literature
it is an asterisk, and you will not find 12R22.5 in the regular XZE listings.
> >Best regards,
> >Gary Van Tassel
> >2004 M380
> >Verde Valley, AZ
04-03-2009, 09:44
"Direct replacement" it certainly is. Whether it is the same tire is hard to say
- the XZ2 no longer exists so it is hard to find specifications for it.
I believe that when the XZ2 was made, it was the only Michelin RV tire with a
12R22.5 size. The XZE* is currently the only Michelin RV tire with a 12R22.5
size. That tells me that Michelin expects it to be the correct replacement, and
it has been for at least 2-1/2 years.
>Best regards,
>Gary Van Tassel
>2004 M380
>Verde Valley, AZ
>literature it is an asterisk, and you will not find 12R22.5 in the regular
>XZE listings.
>have
>> >Best regards,
>> >Gary Van Tassel
>> >2004 M380
>> >Verde Valley, AZ
>Yahoo! Groups Links
04-03-2009, 10:06
It's generally recommended that like tires be mounted on the steer axle. If the second tire is still OK, you can mount in on the tag axle* or hold it as a spare. If the tire is still safe to use (date wise), you may be able to sell it as a used tire. Often a trucker can make good use of used bus tires. You won't get a lot for it, but the $100 or $150 is sure better than nothing.
*if you have one.
El Sobrante CA
"aeonix1@mac.com"
On Apr 3, 2009, at 12:35 PM, garyvant55439 wrote:
I have a badly weather-checked left front tire. Tire dealers tell me that Michelin has discontinued 12R 22.5 XZ2 tires. I was hoping to just replace the one bad tire; but if I buy anothere brand, presumably I'd have to replace at both front tires.
Best regards,
Gary Van Tassel
2004 M380
Verde Valley, AZ
04-03-2009, 10:12
Pete,
Thanks. Sounds like a plan.
Best regards,
Gary Van Tassel
2004 M380
Verde Valley, AZ
> *if you have one.
> Pete Masterson
> El Sobrante CA
> aeonix1@...
> > Best regards,
> > Gary Van Tassel
> > 2004 M380
> > Verde Valley, AZ
04-04-2009, 10:33
Don,
Thanks for the info. I'll see if I can find two of them.
Best regards,
Gary Van Tassel
2004 M380
Verde Valley, AZ
say - the XZ2 no longer exists so it is hard to find specifications for it.
> >Best regards,
> >Gary Van Tassel
> >2004 M380
> >Verde Valley, AZ
> >XZE listings.
> >have
> >> >Best regards,
> >> >Gary Van Tassel
> >> >2004 M380
> >> >Verde Valley, AZ
> >Yahoo! Groups Links
