Unidentified drain hole under 8V92
04-05-2009, 10:11
Found something I hadn't noticed before while working under the coach
today. Just in front of the 8V92's oil pan, there is another oil-pan-like object with a threaded hole much like the oil pan drain plug. However, this hole doesn't have a plug screwed into it - it's just open to the outside world. I took pictures: http://www.ryanwright.com/tmp/bus1.jpg http://www.ryanwright.com/tmp/bus1close.jpg Anyone know what this is? Hopefully it's supposed to be unplugged? Thank you! -Ryan '86 PT-40 8V92 |
04-05-2009, 11:11
Looks like the drain hole in the bell housing, it lets any oil leaking
out of rear of engine to escape. Leave it open. Elmer in Sebring 86 PT 38 --- In WanderlodgeForum@yahoogroups.com, Ryan Wright > > Found something I hadn't noticed before while working under the coach > today. Just in front of the 8V92's oil pan, there is another > oil-pan-like object with a threaded hole much like the oil pan drain > plug. However, this hole doesn't have a plug screwed into it - it's > just open to the outside world. I took pictures: > > http://www.ryanwright.com/tmp/bus1.jpg > http://www.ryanwright.com/tmp/bus1close.jpg > > Anyone know what this is? Hopefully it's supposed to be unplugged? > > Thank you! > > -Ryan > '86 PT-40 8V92 > |
04-05-2009, 11:13
> > Found something I hadn't noticed before while working under the coach > today. Just in front of the 8V92's oil pan, there is another > oil-pan-like object with a threaded hole much like the oil pan drain > plug. However, this hole doesn't have a plug screwed into it - it's > just open to the outside world. I took pictures: > > http://www.ryanwright.com/tmp/bus1.jpg > http://www.ryanwright.com/tmp/bus1close.jpg > > Anyone know what this is? Hopefully it's supposed to be unplugged? > > Thank you! > Richard Carter here 89WB-40 8V92, I believe your looking at an inspection hole for your timeing in the tranny. I have the same hole an was told it at some time had a cover for it. They didn't tell me to cover it. > -Ryan > '86 PT-40 8V92 > |
04-05-2009, 11:28
Thanks Richard & Elmer!
-Ryan '86 PT-40 8V92 On Sun, Apr 5, 2009 at 4:13 PM, dctrcarter >> Richard Carter here 89WB-40 8V92, I believe your looking at an inspection >> hole for your timeing in the tranny. I have the same hole an was told it at >> some time had a cover for it. They didn't tell me to cover it. |
